Question about Philips 15PF5120 15 in. LCD Television
Using the TV as a vista computer monitor.
When i hook up my pc to my monitor the only resolution I have is 640*480 resulting in huge icons. Are there driver updates ?
  • 476 Answers
If you have connected to the TV via the DVI input, the TV should allow you to go to 1024x768.
S-Video, CVBS (composite) or scart connections will only allow 640x480 as these inputs are only standard def.
Posted on Feb 16, 2008
    President:
  • 1,284 Answers
Try a different refresh rate as well.
Posted on Nov 28, 2007
Element tv problems hook to computer get no signal
I'm assuming you are using this as an only monitor for the PC...
What resolution is the screen (max) and what are you trying to put into it? If the video output of the PC is too much it won't 'see' it sometimes... try lowering the PC resolution to that of the screen.
If it's a second monitor, you have to go into the screen settings on the PC and tell it to either 'mirror' (or duplicate) the existing monitor on it or extend the screen on another monitor.
Sorry I can't be more specific as I don't know what the screen or PC (computer) is...
Apr 23, 2014 | Element Electronics Televison & Video
I hook up my pc to lg lcd it always says invalid format any solution
What cable connection are you using? What resolution was the computer sending to the video graphics adapter before you connected the two?
The TV can only support
VGA Resolution: 720x400, 1360x768, 640x350, 640x480, 800x600, 1024x768, 1280x768, 1360x768 or 1366x768
HDMI to DVI: 640x350, 640x480, 800x600, 1024x768, 1280x768, 1360x768 or 1366x768
For best results you should use 1360x768.
Try resetting this when the Input is set to that for the computer. Press Menu and select Picture. Press Enter and select Screen (RGB-PC) (use the Up/Down arrows). Press Enter and select Resolution. Then press Enter and select the desired resolution. Then press Enter again.
If you like there is a Auot-config option in the Screen menu, that may set the TV properly.
If the above doesn't help, use another monitor and check the output resolution and then reconnect to the TV.
I hope this helps.
Feb 04, 2011 | LG 32LG30 32 in. LCD HDTV
I have a new Acer 23" LCD monitor - the desktop icons, my email, my word documents - everything is HUGE - I cannot read anything without going back and forth, up and down and it is impossible to type...
You need to change the monitor resolution setting in your operating system. If you are using Windows then go to Control Panel and look for Display Settings (or something similar depending on the version of Windows). Adjust the Resolution setting (probably using a slidebar on screen) to match the optimum setting of your monitor. If you don't have the monitor instructions try the highest setting first and move down one step at a time until you get a correct resolution on the display.
Jan 04, 2011 | Acer Computers & Internet
I have upto now been using my LG Flatron L1919S monitor as a tv with a separate tuner. today i replaced it with an LCD tv and was going to use the monitor for my computer. however when i connected it up...
It means your PC video output resolution is too high for the LG monitor to display (your old monitor (CRT) can handle higher resolution than this LG LCD monitor), you need to set the PC video resolution to native resolutionof this monitor which is 1280 x 1024 @60Hz. You may have to use the old monitor (CRT) to set the resolution to 1280 x 1024@60Hz, then hook up the LCD monitor.
Mar 27, 2010 | LG Flatron L1919S LCD Monitor
Hello, I have a 22'' ASUS VK222H Monitor hook up to my computer. I had Vista Business and everything was good. I installed Windows 7 today. Now I see only about 3/4 (three fourth) of the screen is occupied...
i would go to asus or computer manufacture's site, or microsoft and find and download the driver manually. Then install it by double-clicking the downlaoded driver file.
I also recommend right clicking on screen, go to properties or display properties, and only use the windows 7 them and not a modified or customized theme.
Jan 30, 2010 | ASUS VK222H Monitor
Monitor not supported
Well the monitor not being support is not the issue. the issue is the video card cannot produce a signal that is supported for the monitor. Its doing this to let you know also to lower your resolution because the monitor will pop if the resolutions is to high. the monitor itself does not matter if you had Vista as lond as the monitor agree with the signal your cool if it don't it will do this. Try lowing the res using another monitor then put the orginal back on and you should be good.
Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 24, 2009 | HP dc7700 PC Desktop
Invalid format message when trying to use the RGB(PC) port
Honestly, that sounds like one of two things happened. Either the resolution of your computer video card changed or (I'm not sure with your specific TV) the TV's resolution changed.
If through the TV menus you can adjust PC resolution, I would try changing the resolutions. In the LG 47LB5DF TV, press Menu, then go to Picture, then go down to Screen. On the screen menu, you will see Resolution, Position, Size, Phase, and Reset. First try adjusting the Resolution to some of the options you see. If that doesn't work, try to reset the screen settings.
If adjusting those settings on your TV does not help, then you will have to change the resolution through the computer. Try connecting a monitor to the computer. If you get a picture through the monitor, on the desktop right click and select Properties. If using XP go to the setting tab, if using Vista/7, select Display Settings. Lower the resolution to something you think the TV will be able to handle, then connect the PC to the TV again. If you are using an HDMI connection to the TV, you may have to turn off the computer, connect the cable, then turn the computer back on with the TV on the correct input.
If the monitor doesn't show the picture or if you don't have another monitor, you can try adjusting the picture in safe mode, by pressing F8 after you press the power button, before you see the Windows loading screen. Press if multiple times if necessary. You should see a screen that gives you a few startup options. Select Safe Mode. After Windows boots up, you should still see the screen as the resolution would have been reduced. From there try changing your display settings.
Hopefully that info has helped. I noticed that you asked this question 2yrs ago, so I hope you have already figured out how to fix your problem. I simply wished to post this in case it would help you or anyone else had a similar problem. Good luck and take care.
Dec 15, 2008 | Philips Magnavox 42MF521D/37 Television
Out of Range
Usually with the resolution your computer's set resolution for ur display is to high for the screen
try using a different screen to change the frame refresh rate and resolution to ur monitor
Oct 21, 2008 | X2Gen MG19MY 19" LCD Monitor
Thoshiba SATELLITE A200-1Z3 Laptop
It could be that the screen is at the correct resolution, but the icons are just set to display larger (Vista allows this). Right-click on the desktop (NOT over any icons), and select "View". there you can select the size of the desktop icons.
Sep 04, 2008 | Computers & Internet
Pc and lcd tv
that's really easy. just plug in a VGA or DVI cord from the PC to the Sova TV (those are both regular cables that normally would go the computer monitor). then press the source button on the remote (not too fast, it takes a second to detect the signal), until you see VGA or DVI, and your computer screen should show up. use the display settings on your computer to get the best resolution on the tv. depending on your computer, you may have a program that can save different screen resolution profiles for you (since the Sova TV resolution and the computer's optimized resolution using a different screen (such as the built in screen on a laptop -- or a different monitor with better resolution than the Sova TV), this way you can easily toggle between settings depending on what monitor you use.
Jul 29, 2007 | Sova DSV32P112 32 in. LCD Television
Philips 15PF5120 15 in. LCD Television Logo
140 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
