Question about Kenmore Washing Machines
I have a Kenmore Elite HE 4t. When it spins you can hear that the motor or something is loose. Is this accessed from the front bottom panel or by removing the stop panel.
SOURCE:
SOURCE: kenmore elite he 4t washer
I have the he4t and everytime I wash I get an f02 error. The washer wont drain and spin unless you cancel and restart the washer. What can I do to fix this?
Posted on Oct 17, 2008
SOURCE: torn seaL ON KENMORE ELITE WASHER
i have a kenmore elite washer the red lite is lit on controlles locked how do i solve this
Posted on Mar 23, 2009
  • 5 Answers
SOURCE: my kenmore elite smartwash quiet pak 9 he 4t seems to be off
have you tried lower spin speeds? I found with heavy items such as towels and jeans it is best to lower the spin speed. also washing like heavy items on a certain wash cycle is best - i.e. towels on bluky/bedding.
hope that helps.
Posted on Apr 09, 2009
jsrock516
  • 5911 Answers
SOURCE: removing front panel from kenmore elite HE-3 front load washer?
If you've removed the screws and the panel sticks, tapping on each side will knock it loose. The panel should drop down, then off. You can also try propping the two front feet of the washer up slightly for better access. A 2x4 works real well. This will allow more room for the panel to drop and gives better access to the screws. The washer is very heavy, so you may need some assistance to lift the front. Either lift from the bottom, or place your hands on the front facing of the cabinet to push the washer back. DO NOT push on the door or control panel.
If you still need assistance, please let me know. I hope this helps you.
Posted on Jul 05, 2009
  • 92 Answers
SOURCE: Loud banging/thumping during spin cycle on my kenmore front load
this sounds like this could be the bearings,to check for this,open door and with yourhand lift the inner chrome drum and let it fall then lift again and if you feel a knocking sound and a lot of play in it then its the bearings,i know there should be movement in the drum but this will feel more of a knocking.
Posted on Jul 07, 2009
Replace washer spin basket kenmore elite 110
sounds like a bad bearing on the rear of the tub. If you remove the rear access panel you will see a large pulley and belt. That attaches to the inner drum (basket) and spins it. It floats on a bearing just behind the pulley. If the bearing is bad then you will be able to move it up and down about .25 to.50 of an inch.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Jun 25, 2014 | Kenmore Elite 45986 Front Load Washer
Removing front panel from kenmore elite HE-3 front load washer?
Jul 05, 2009 | Kenmore Elite 45986 Front Load Washer
My kenmore elite smartwash quiet pak 9 he 4t seems to be off
hope that helps.
Apr 08, 2009 | Kenmore Elite 45986 Front Load Washer
Removing panel cover
Sounds like your drain pump is clogged.
Nov 22, 2008 | Kenmore Elite 45986 Front Load Washer
Something rattling under the drum
Strangely enough, I found the problem to be in the motor. If the noise becomes pronounced during the high speed spin cycle, then that is the problem. I had a repairman out for mine and they wanted to replace the drum, however when I took off the back and removed the belt, I could turn the drum separate from the motor and could hear that the problem was in the motor bearing, not the drum. Hope this helps.
Nov 18, 2008 | Kenmore Elite 45986 Front Load Washer
Not spinning
motor you hear is probably pump motor ..remove bottom cover remove acess port on pump and clean
Nov 16, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE 4T
HE 4 front load remove bottom panel 3 screws once remove now you have access to pump get towels and bucket oper lint filter and remove debris from inside ,,,,, and that its F2 long drain,,,,,,
Oct 13, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Kenmore HE2 Elite is making groaning noises and then error messages 5D and/or F
did you clean pump out by removing acess port on front end of pump? also you can ckd pump impeller by removing screws around pump body impeller will free wheel but should have some resistance to turning by hand if no water in tub reinstall pump put in drain spin to see if drum will spin if it does forget main motor ..motor is most reliable par on those washers
Aug 06, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 4t
Try the diagnostic test by pressing Drain/Spin button then press the Prewash button four time within five seconds. It will start to ignitiate the sequence for the inlet valve. The cold then hot then wash  then drain then spin. Hope this will clear the brain of the machine and you are good to go.
F&H means you have a drain clogged, or bad pump or bad inlet valve or pressure switch or the worst ccu.
Oct 25, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite problem
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%^@#
Apr 28, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Jim Chinnery
Jim Chinnery
Level 1 Expert
