Question about HP Compaq nx6110 PC Laptop
My compaq laptop freezes after 30 minutes
From last 2 days my compaq laptop freezes after 20 minutes and some time it takes lot of time to boot and some time it doesnot boot what is the problem
    Problem Solver:
  • 14 Answers
It sounds like an overheating problem. When it is booted, does it run ok other than just being slow? Check your cooling fan and make sure it is running and not stopped up. That is a number one symtom of overheating is freezing and rebooting by itself. Have you expierenced that problem also? There is a free program called "Motherboard Monitor 5" that will monitor the temp for you and set off an alarm when it is getting to hot. Check that problem first. Hopes this helps!
Posted on Nov 28, 2007
I have a pc Compaq nx 6110.
After push for mistake 'display switch' my pc does not boot.
If i power on ,on the screen i see only the logo:
'hp invent' and 'F10=ROM Based Setup' and 'intel inside'.
Nothing more.
Any help is appreciated.
Posted on Dec 13, 2007
My compaq is power on for 2 second and off , how to fix is thank you
You need to print this out-on someone else's computer. Hope it works for you!
Remove the battery and charger/ac adapter/power cord from your Compaq Presario F700 laptop, press and hold the power button for 20 seconds to discharge any residual current inside the Compaq Presario F700 . This clears your RAM and is like a hardware reset. Replace the battery and charger/ac adapter/power cord and turn your Compaq Presario F700 laptop on.
Boot in "safe mode". As it starts up press F8, the computer ask you if you'd like to start in safe mode. Highlight "safe mode" and press enter. See if your laptop is booting up ok .
If your Compaq Presario F700 boots ok, do the following,
Try System Restore first,
Start Menu->All Programs->Accessories->System Tools->System Restore. Choose the most recent date before you the encountered problem. If it doesn't work, try the next date.
If System Restore does not fix it, as a last resort, you might need to fdisk, reformat your laptop hard disk clean and reinstall OS, that usually fixes all bugs. Before going that route, try following,
Uninstall unnecessary programs and applications.
Scan with a antivirus program
Scan with a spyware/malware program
DEFRAG C:
CHKDSK C:
Clean up and repair registry problems with registry repair software of your choice
If the problem persists, did you check if it could be your Compaq Presario F700 laptop power cord or power source problem? Defective or insufficient power supply might cause error messages that are misleading. Take the battery out and power on your laptop with the charger only. Make sure your Compaq Presario F700 power jack and charger plug tip are securely connected. Did you notice the power jack loose? You can find laptop power jack on ebay. Fixing and soldering the power jack requires professional skill though. The charger green/blue LED should be on. If not, replace the defective charger. Compaq Presario F700 laptop battery charger, especially its power cord/cable, lifespan is limited and does not last forever, consider buying a lifetime warranty charger online from company like www.topmic.com
Dec 29, 2012 | ASUS K52n-a1 Notebook
My compaq presario cq60 will not charge I plug it in and no lights. At boot up here lately it says battery needs to be replaced I have had this computer for less than 2 years
Good day, please double check your adapter. Maybe your adapter is defective. If not you need to go to the nearest service center. Maybe your laptop has an internal problem w/ the power. tnx
Aug 18, 2011 | Compaq Computers & Internet
When i boot up, my Compaq CQ20 displays the message that the battery has low storage capacity. Battery time is now down to 15 to 20 minutes at full charge.
If you laptop is more than two years old then it is possible that the battery is faulty as many of the compaq laptops have poor back up battery orr quality retained.
Check the adapter on the PC , check if the adapter charges the battery to full capcity , now if this charge wont lat more than 20 minutes , you might need a new one.
Discharge the battery fully and charge few times as the last resort.
Feb 23, 2011 | Compaq Computers & Internet
When I start up my Compaq 6720s up after I have typed on the password the screen stay black, it does come to life after about 20/30 minutes and is all ok, shuts down, then the same thing the next time I...
You might have an extremely slow boot up. Try tapping F8 the next time you boot to start up in Safe Mode. If Safe Mode boots up faster then you should try removing some of the Startup items that you find when you run msconfig from the Run box.
Oct 17, 2010 | HP Compaq 6720s Notebook
Computer worked fine last time i used it about 2 months ago, now it will not power up, any suggestions? compaq armada e500
Sounds like the you might need to replace the battery. Also check the power supply reconnect make sure connection are tight etc... its a long shot but make sure wall outlet is also active as well! Sometime it takes 20- 30 mins for an old battery to begin to recharge:)
Jul 25, 2010 | Compaq Armada E500 Notebook
My sony has started turning itself off after 20-30 minutes, each time you turn it back on it will turn itself off after a shorter and shorter run time. Leave it over night and it will start the next day...
It might be over heating. If there is a lot of dust
inside of the back of the T.V. you should take it outside and blow it out with an air compressor.
good luck
Aug 06, 2009 | Sony KV-36XBR400 36" TV
Compaq Presario v2000 notebook reduced battery life
you may try:
1) check the battery alarm at windows power managment, to set 5-10% alarm level.
2) discharge the battery to the empty then charge longer time, you need monitoring how long it charged (see charge lights change), need to change new one if charging time much less then before(less then 10-20 minutes)..
3) plug-in AC adapter monitoring charging current,
this step you need a current meter to make a series connection in the circuite, the battery is over life cycle if the current less then 500mA.
May 02, 2009 | Computers & Internet
Compaq Presario R4000 Notebook won't boot
Seem to be a problem with your power switch doing malfunction or bad motherboard connector or your computer has been setting at hibernate mode. Check those settings going to >> Start >> Control Panel >> Power Options..........Set your droplist to "never: and also UNCHECK the hibernate mode.
Another tip, take out the battery, and see what happen (only connected with AC)
Oct 13, 2008 | Compaq Presario R3000 Notebook
IT ALWAY FREEZES AFTER 20-40 MINUTES OF THE COLD BOOT (FIRST BOOT)
this might be some problem with your registry.. There are plenty of software can check this.. I suggest you try to look into below link to further understand the registry issue.
http://etech.maiila.com/?p=24
May 16, 2008 | Toshiba Satellite A135-S4527 Notebook
Laptop freezes
"I never shut it off " Hope u r hibernating the laptop.. It seems that ur lap is junked with a lot of registery files and starup files.. so it takes a lot of memory to perform its operations and subsequently it hangs up.. and i hope u have installed norton anti viurs. this antivirus needs a lot of resources. better u install Mcafee. The best thing u can do is to install a fresh copy of windows. this will solve ur problem.. and remember keep the startup items to the min level.
Sep 03, 2007 | HP Compaq Presario V2555US Notebook
HP Compaq nx6110 PC Laptop Logo
1,033 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
