Question about Pioneer DJM-600 Silver Professional DJ Mixer with Auto Beat Cou Home Equalizer
Mixing knob problem
I turn the mixing knob all the way to Master and I hear nothing on the headphones. I have to select the Master in the headphones cue.
How can i fix it? what can be the problem?.
Please somebody help me!! is too expensive to expensive to repair it?
What do you mean you put the master to cue to hear something from the master? You should be ableto hear the master at all times then choose wha channel you are cuing up. Sounds like a pot. problem on the switch or board.
Posted on Nov 28, 2007
Is it possible to make headphone's fader before the master's fader?
May 11, 2014 | Alto ZMX122FX
How can I use my headphone by a Peavey 14 compact mixer.Which switch do I needs to use.
With the headphones plugged in, and the headphone level turned up you should be able to hear whatever is coming through the main mix. If you cannot hear anything, make sure the buttons marked 'TAPE TO CTRL/ HP' and ' TAPE TO MIX' are not pushed down.
Sep 15, 2011 | Peavey Electronics Peavey 00512140 PV 14...
I can hear the myself in the headphones and it is recording but i cant hear the audio when i play it back.
Make sure you've adjusted the Mix knob correctly. The Mix knob is above the Output knob. Turning it counter-clockwise allows you to hear more of your input and turning it clockwise lets you hear more of your playback. Try adjusting the knob clockwise to get more of your playback feed.
Mar 25, 2011 | M-Audio Fast Track Pro External Sound...
A new DM7 drum set line out has very low output. It is connected with drum combo Stagg EDA40 and if combo drum inputs are used there is practically nothing to hear . With combo maximum volume there is...
The sound on all the stock kits I found to be too low. What I did was create a custom kit and altered the dynamics of all the pads and cymbals - once you're in the dynamics settings, just hit the pads/cymbals the hardest you normally would and save that setting!
Dec 29, 2010 | Alesis DM7 USB Electronic Drum Kit
How to hear a selected tracks using headphones without passing through to the main mix
Select desired tracks with the PFL buttons. This solos those tracks to the headphones.
Dec 28, 2010 | Behringer XENYX 2442FX Mixer
Speaker no sound
Restart the computer, plug in and unplug some headphones as the AC'97 has a silly little "remember what volume the headphones were at" feature. Go into the sound mixer (start > run > sndvol32) click options > select advanced controls. If a button exists under the "Master Volume" channel inthe mixer, click it and make sure nothing that would turn off the built-in speakers is checked.
Dec 09, 2010 | Computers & Internet
Marshall MG50 DFX amp line out/headphones not working
Contrary to what's posted above, the Marshall MG series does not pass the speaker power output through the headphone jack, and inserting the headphones into the jack does not disable the speaker. The headphone amp is a separate circuit and it's input is taken before the master volume. So Jan's post is exactly right. Turn off the master volume and turn up all the other gain/volumes as high as they will go. The other issue is that the headphone jack's output does not drive low efficiency headphones well, so you need some headphones similar to Sony's MDR-V700s to hear it well. Earbuds just don't cut it.
Mar 07, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
Djx700 Headphone (cue) Problem. Please help.
Have a look at page 4 of your manual under the Monitor section, mode switch. Manual is here: The mode switch may be faulty or the mix control may be faulty.
Feb 02, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
Carver CT-28v Tuner preamp - Has a hum/buzz (soundls like a ground loop) that is heard as soon as the unit is turned on. Does not increase with volume, just stays the same and is continuous. Changing...
Reverse the polarity of the AC plug and try it. Is there a headphone jack on the preamp? Try headphones with the preamp standalone without the amp attached.
Are you sure the preamp is the problem? I assume you also have an amp or you wouldn't hear anything. Power up the amp with nothing but speakers attached. Hum??? It's in the amp. No Hum? Attach just the preamp with no external components. Hum now? It's the CT-28. Turn it off an exercise every switch and knob throughout its range numerous times. Try again. Still humming? Manipulate source selections, Tape Monitor, everything.
Nov 19, 2009 | Audio Players & Recorders
Mbox 1 no ouput from protools
Double check and Ensure your headphones work.
Ensure that the master level is turned all the way to the right (Playback). I would also check that the main audio out of the Mbox is functioning so use two TRS 1/4" [balanced] cables to and amp and speakers to ensure master output jacks give you the same result. If they do chances are the Mbox is bad, if not it could be just the headphone preamp is bad
Nov 11, 2008 | Digidesign Mbox External Sound System
99 people viewed this question
Top Pioneer Audio Players & Recorders Experts
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
