HP DeskJet 932c InkJet Printer Logo
Posted on Aug 07, 2009
One color does not print
One color (blue) does not print. Replaced cartridge with new one and it still does not print.HP 932C,
Anonymous
Level 1:
  • Contributor 38 Answers
  • Posted on Aug 07, 2009
Anonymous
Contributor
Level 1:
Answers
38
Questions
0
Helped
9292
Points
99
Turn off printer and allow print carriage to park. Unplug printer. Using a cotton swab and rubbing alcohol gently clean the interface gold looking ribbon where the ink cartridges plug in. Allow to dry. Test printer with a test sheet. If that doesn't work, replace the control board. It might be just as cost effective to replace.
Printer will not print in color, only black. We just replaced the cartridges.
If its an HP inkjet printer you may have set it to print in black and white. To change this setting go to "control panel", then "printers and devices", right click on your printer, then "printing preferences", "advanced", then uncheck "print in greyscale"......Good luck !
Color cartridge runs out even though I'm only printing b&w typed scripts. Any way to shut it off? Only have use for color printing once in a blue moon Hewlett Packard HP DeskJet Printer #932C
Even though you print a b/w document... unless you say 'black cartridge only' in your printing preferences, all the colors get used.
Find 'black cartridge only' in your printing preferences, or 'print in greyscale' and then print your document. You must specify this for your printer to know that it must use the black only.
Hello, My HP 932C has suddenly started printing photos in pink. I have tried cleaning all the cartrdge contacts, reinstalling the software, a new cartridge. No change. Any ideas?
Your cartridge may need to be replaced. If your tri-colour cartridge has run out of yellow and cyan and only has red left this could be the cause.
I have just installed a new color cartridge into my HP Deskjet 932C. The only colors printing is pink. What can I do to solve this problem?
will you get to change the print color and by doing that you have look for the ink then when you fing go get ride of and put now one or I get any other way let me thing..
2answers
Hpdeskjet932c quit printing yellow & blue
Just try with replacing the color cartridges may be it is dry.
Hp 932 c prints from the color cartridge only
Was it working and now stopped working ?? If so, could be a faulty black cartridge. Remove the color cartridge and see if the black prints. if a new black cartridge, the strip may need to be removed or remove and reinsert black cartridge.
My printer has an almost full black cartridge but will not print.
Check the ink lines, the printer head might be clogged, If thats not fixing anything then check your printer settings on the computer and remove the color option. Changing it to black and white can somtimes just be from color, not just black.
Hp deskjet 932c does not print cartridge light keeps on blinking
First suggestion is to install a new cartridge. The #45 black and #78 color have a small circuit board that registers with the printer. That circuit board may not be doing its job.
2helpful
2answers
k24674
Grand Canyon Tech
Grand Canyon Tech
