Question about ViewSonic VA800 17.4" Flat Panel LCD Monitor
Frequency problem of LCD monitor
I am using fedora core 6 with nvidia GF 7200GS graphichs card.But LG Flatron L1730S giving the error out of range 92.8KHZ/58HZ when I am attempting to go in graphics mode.
  • phunghp Dec 28, 2007
    My LCD monitor T705 have just got a trouble. After a while it appears "Luminance
    contrast..."
    I control it and Exit (because press Enter button at the bottom screen no action happend)
    some minutes late the funtion contrast appaer again. Even it reduce contrast automatic.
    Thank for reading.
  • bugkate Dec 05, 2008
    Just bought a used 2002 flatscreen monitor. The "window" started at midline and ran beyond the left side of the monitor.
    Changed the resolution to low, and the window centered, but the image is bad.
    Any ideas?
  • 585 Answers
Bugcafe: LCD monitors work best when you system is set for the native resolution of the monitor, and at not more than about 75 Hz refresh. For a 15 inch LCD that's 1024 x 768 and for a 17 inch it's 1280 x 1024. In windows you would right click on the desktop, select settings, and select the "display settings" tab. This is where it gets fuzzy for me as I am not Windows user. I believe there will be an advanced button you can select to manually enter the settings. You can also do this in windows "safe mode" which should get you a better screen in which to perform the operation if doing it with the LCD connected. Enter safe mode from a reboot by using the "F8" key.
Posted on Dec 14, 2008
I dont have driver flatron l1730s lcd monitor . usb driver monitor
You may be able to download the driver from these WEB sites.
http://totallydrivers.com/device.php?id=74496&show_devs=a
http://www.bravofiles.com/driver-LG-FLATRON-L1730S.html
Apr 06, 2011 | LG L1730SF 17" LCD Monitor
Lg FLATRON LCD L1730S (L1730SSNTM-AL**E power
Here are the service manuals, please look through them. Please note that if the power supply is not made by LG, it will not show the information in the service manuals.
http://elektrotanya.com/?q=showresult&megnev=LG&megnev2=L1730&kategoria=&kat2=schematics
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 19, 2011 | LG L1730SF 17" LCD Monitor
I didn't get disply on my lg flatron l1730s lcd monitor
Connect it to a different computer, to see if the monitor works at all.
Connect a different monitor to your computer, to see if your computer's video-adapter is working.
Nov 06, 2010 | LG L1730S 17" LCD Monitor
I have lg flatron l1730s lcd black color monitor. I have problem with this. Power not come. some time when i connect it power LED blinking once then no display. Some time when i connect it power LED...
Oct 14, 2010 | LG L1730S 17" LCD Monitor
GF 8600 GT graphichs Driver for Windows 2003 Server Standard
http://www.nvidia.com/Download/index.aspx?lang=en-us
you can ghet driver from here select your model here.
Thanks for using fixya.
Pleaseratesolkution if it helps.
Jul 25, 2009 | XFX NVIDIA GeForce 8600 Graphics Card
How can I restore factory settings on our LG Flatron LCD Monitor?
press menu button it is in middele of lcd.
Ten go to setigns and u can fine reset buton press ok.
Jun 13, 2009 | LG L1730S 17" LCD Monitor
Dual monitor, Intel 82915G & nVidia RIVA TNT2 64, FC6, Dell Gx520
Here is a little guide for setting up dual monitors with fedora core 6: http://blog.taragana.com/index.php/archive/how-to-setup-dual-monitors-on-linux-fedora-core/
I haven't had to use duals monitors with Linux yet but if this doesn't work let me know and I'll run some tests as I can easily set this up at work (we use the same computers and similar cards).
Jan 12, 2009 | Dell OptiPlex GX280 PC Desktop
My lg flatron L1730S, the screen shows some different color
1. Solder the neck board dry points (cromo IC )
2. display cable connector.
Dec 20, 2008 | LG Flatron 915FT 19" CRT Monitor
My monitor lg flatron l1730s keeps going into powersave mode
check your powersaving options in windows>control panel>power options
there is a bunch of options in there that could make your monitor go into power saving mode.
also check your video card options and menu of the monitor itself all could possibly contain a sort of powersafe option.
most likely indicated with amount of minutes untill... either power off screen blank or screen saver.
Dec 19, 2008 | LG Flatron 915FT 19" CRT Monitor
ViewSonic VA800 17.4" Flat Panel LCD Monitor Logo
220 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
