Question about Whirlpool AWM5145/2 Front Load Washer
Whirlpool awm 5145/4
Machine starts to spin then stops.I have to select seperate spin programe to get full spin and this works fine .
Any help will be appreciated,thanks
  • Anonymous Mar 27, 2014
    I have a whirlpool AWM 7100 that does not that performs the whole program (no matter what program is selected). It stops the cycle and remains at the same stage until the controller is manually rotated (fully mechanical)
    Champion:
  • 249 Answers
FILTER MAY BE BLOCKED IRE CLOSE BYE
Posted on Nov 28, 2007
My awm 5145/4 has stopped working! There is still power going to it but when you select a programme it does nothing,but it will drain,someone has suggested the brushes,where are these located on this...
Could well be the Carbon Motor brushes that are worn they last round 5 years hen need replaced..I lie under the machine to do this but you may find it simpler to remove the motor they are located at the side and are secured by two screws, parts cost around £25 per set.....
Feb 27, 2011 | Whirlpool AWM5125/1 Front Load Washer
How do i open the filter cover for my whirlpool awm 5145/3 washing machine?
Tip is back a hair and remove the screws and bottom panel then grab the cap045bec0.jpg7d5c207.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 13, 2010 | Whirlpool Washing Machines
Whirlpool washer AWM 5145/5 water wont drain/stops on B
I had same problem twice, the first time there was a sock in the filter at the front adjoining the pump, the second time a sock had got in the pipe under the drum which is more awkward to get to but is possible if you have the tools to remove the back plate and are ok at diy, there is a spring tension clip on the pipe which comes off quite easily with a pair of pliers.
Jan 14, 2009 | Whirlpool AWM5145/2 Front Load Washer
I have whirlpool awm 5145 the counter turnsbut nothing happens
Check the lid switch. There should be a small pin on the lid that will push the lid switch down when it is closed. There are two wires going to the lid switch, jump these two wires together and if it works then replace the switch.
Unplug the washer before doing any work.
Dec 16, 2008 | Whirlpool Washing Machines
Whirlpool Washing Machine AWM 029 is not draining
Hi.
I assume you have checked to see if the pump is working,
Select drain and spin, if water does not go away, then you have a pump problem, which will stop the programme completing.
Please leave feedback.
Thanks
Nov 25, 2008 | Whirlpool Washing Machines
Whirlpool awm 5145-2
The filter area permanantly holds water, this is correct,suggest that you have a faulty inlet valve. Regards Engineer
Jul 26, 2007 | Whirlpool AWM5145/2 Front Load Washer
Awm 5145
Possible your hoses into the dispenser box hv a problem; plug off wall. Open the top of the machine to examine the hoses.....
Jun 24, 2007 | Whirlpool AWM5145/2 Front Load Washer
Whirlpool AWM5145/2 Front Load Washer Logo
458 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
