Question about HP PSC 1315 All-In-One InkJet Printer
Wifi setup I want to set up my printer to work with my wifi
  • 98 Answers
Install the printer on one of your computers, then share it. Then install the printer on your laptop using the option "A network printer, or a printer attached to another computer". If your computers are in the same Workgroup, your laptop will find the printer attached to the other PC. Now, your PC will need to be on every time you want to print from your laptop through your wireless network.
Posted on Nov 27, 2007
How do i setup my dell wireless printer?
Its very easy to setup dell printer by own.You just need to follow some simple steps.Steps are already explain with images you can check this How Do Set up Dell Wireless Printer Install Dell Wifi Printer Fixotip
Jan 03, 2018 | Dell Office Equipment & Supplies
I am setting up my wifi on the printer and my password has _ how do I inserrt this on my printer
You connect to your wifi from your printer settings > WiFi setup wizard. It should ask your wifi password when connecting.
Check your manual. If you don't have one here's the link.
Epson WorkForce 435 All in One Printer
Jun 09, 2015 | Epson WorkForce 435 All-in-One Printer -...
Wifi set up pin #
Just checking, could that be the passcode (PIN) to access your Router WiFi set up? That could be found on the sticker on the bottom/side of your WiFi Router. I didn't see where the setup procedures from Canon address this.
Apr 21, 2013 | Canon PIXMA MP495 InkJet Printer
I think I accidently cleared my wireless wifi on my printer.... the wifi light is orange instead of green so not connecting
Try to print the network settings page to determine if your printer is still connected to your wireless network or not. On the printer operator panel, press the Setup button -> Network Setup -> Print Setup Page. Check the SSID if the printer is still registered to your wireless network. If not, you may need to reset your printer's wireless network adapter. Press Setup -> Network Setup -> Reset Network Adapter. The wifi light on your printer will then momentarily turn off. Once it turns on solid orange again, you may reconfigure your printer to connect to your wireless network.
If your printer is still registered to your wireless network, then it could be just a slight communication problem. Try to unplug and replug your printer into the power outlet to reset it. Doing this usually fixes minor communication issues.
May 03, 2011 | Lexmark X4690 Wireless InkJet Printer
My lexmark x4650 printer is connected to the wifi, but the orange light is blinking. And nothing is able to print. When I look at the printers activity it shows the document that im trying to print but...
When you installed your printer, you had to install the software on your PC. So go to your PC's start menu, go to Programs, select Lexmark software, select Tools and then select Wifi Configuration Utility. It will open a window which will give you step by step instruction on re-configuring your wifi settings. When you are doing this, make sure your printer is connected to your PC via the USB cable.
Apr 07, 2011 | Lexmark X4650 InkJet Printer
My wifi for my epson nx515 is not working with my laptop.
Obtain the IP address of your printer. Go to Setup > Network Settings > Confirm Settings If it starts with 192, that's good. If it's 169 or 0, do the ff : --- 1. Reset the Network settings. Go to Setup > Restore Default Settings > Network Settings 2. Run the Wireless LAN Setup. Go to Setup > Network Settings > Wireless LAN Setup 3. Make sure you can see your network name or SSID which is provided by the router manufacturer. 4. Enter your network key and enter it as it is (CaSe sensitive). 5. Obtain the IP address. Make sure it starts with 192. 6. Now run the software on your computer and add the printer.
Dec 08, 2010 | Epson Office Equipment & Supplies
How to turn on wifi
Configuring the optional internal wireless print server
If you purchased the optional internal wireless print server after your printer was already set up, follow these steps:
1 Install the internal wireless print server into the printer. For more information, see "Installing an optional internal
wireless print server" in the "Setting up the printer" chapter.
2 Click Start Programs or All Programs Lexmark 3500-4500 Series.
3 Click Wireless Setup.
4 Click Start.
5 Follow the instructions on the computer screen.
6 Click Finish to complete the installation.
Also here is the link to the setup guide and user manual
click here
configuring the wireless is in the setup guide
Oct 18, 2010 | Lexmark X3550 All-In-One Printer
Canon mp620 not connecting to my wifi laptop
This could happen if the port that you are using is not the right one.
When you are using a printer wireless, you need to use the Standard TCP/IP port, to setup a printer port, do the following
Right click on printer icon, select properties
Click on Add port, select new port
Enter the IP address of the printer, this can be obtained by printing the settings page from the printer.
Note: please setup a static IP for your printer, else everytime you restart you may endup with a new IP
Let me know if this works,
Jul 29, 2009 | Canon PIXMA MP620 All-In-One InkJet...
I am having difficulty setting up the wifi function on the lexmark X6570 printer that I have purchased recently. I have installed the printer to the Apple Mac using a USB wire and it all seems to work...
Press the white settings button once. Then press the right arrow button 4 times ( next to the red x) The display will say network setup. Press the check mark once. The display will now say network setup. Press the check mark once more and the display will read print setup page. Press the right arrow button one time and the screen will read wireless setup. Press the check mark once more and you will begin the wireless setup configuration for your network.
Good Luck, John
Jun 09, 2008 | Office Equipment & Supplies
HP PSC 1315 All-In-One InkJet Printer Logo
57 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
