Directv Plus DVR DTV Receiver / 100-Hours Video Recorder Logo
Posted on Aug 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My r15-100 died suddenly. I believe the drive itself is fine, but the box is dead. Is there reco a way to salvage my recordings to another r15 100, 300, or 500?
  • 83plus Aug 07, 2009
    I have a new one, but I want to know about salvaging my recordings from the old dvr. Also, I do not understand what you mean by "Mathomagitionesnoteingentienloaderwastakedo"
Anonymous
Level 2:
  • Expert 56 Answers
  • Posted on Aug 07, 2009
Anonymous
Expert
Level 2:
Answers
56
Questions
Helped
22800
Points
123
Buy A New One If It Died Or Call A Mathomagitionesnoteingentienloaderwastakedo
2answers
2008 F250 manual climate control head issue
manual hvac fuses-undefined-undefined-0.jpg These fuses are for manual hvac. Not only check the fuses, use a test light and check voltage at fuses. One fuse is hot all the time, the other two go hot with key on. Also, check ground at hvac unit, black wire, not shown in picture. good luck.
My dvr worked fine for several months and then all of sudden it stopped recording Could it be that the hard drive just stopped recording because of failure?
the HDD is a common component to fail in a DVR.
The DVR Itself should actually tell you the status of the storage device if you navigate the menu.
I could probably assist you remotely to find out if you like?
2001 v70 t5 wagon. auto all of a sudden dies while driving along. when i try to restart, battery is dead. no indicators or trouble codes are recorded in the system.
First thing would do is check just how securely the battery leads are attached to the battery. Next have a look at the earth strap from engine to car frame connections. A complete cut out as you describe can only occur if there is sudden complete shut down of the electrical system, this would also account for the ECU not recording trouble codes, it needs at least to be on before it can record anything. The next check point would be the main fuse and starter relay and then the starter switch itself; there has to be break/loose connection somewhere in the 'on' circuit. This is not a 'short' otherwise the main fuse would have blown.
2helpful
4answers
Maxtor 3200 was working fine. Suddenly my
Try connecting it to another computer.
If it is not detected, then either the disk-drive "inside" the unit is dead, or the "adapter" (USB-to-Disk-Drive) inside the unit is dead.
If the latter, disassemble the case, remove the disk-drive, and attach it as an "internal" hard-drive to your computer.
2helpful
My 5 yr old Palm Tx suddenly started trying to
I did a warm reset and it worked. Just hold the up key and reset!! good luck
1helpful
Suddenly went completely dead!
I have a Sharp Carousel that got zapped once during a thunderstorm. Since it was dead, I opened it up to see what I could salvage. Turned out there is a main fuse inside, it is a ceramic cylinder with metal ends, like the old glass car fuses but ceramic instead. Bought a replacement from Digi-Key and it has worked fine ever since.
1helpful
My 2005 Audi A4 just died. It was driving fine and then the rpm just dropped off and everything went dead. It tunrs over fine, but will not start. Any ideas? Thanks.
Sounds like sudden electrical failure,likely causes are crank shaft position sensor or engine control relay failure both are common,could be bad earth connection
Top Directv Televison & Video Experts
Alexander
Ngoro
john h
Are you a Directv Televison and Video Expert? Answer questions, earn points and help others
