Question about Kenmore Washing Machines
Kenmore Elite Oasis He Model: 110.27062602 Type: 580 Why does top loader get stuck on C8 in diagnostic test mode? Removed the basket, nothing is obstructing it from spinning. Spins freely manually.
1. Our top loader would not begin a regular wash cycle or rinse cycle. Seemed as though it would not fill while there was a motor or pump sound as if it were attempting to. 2. Ran diagnostic test and it completed all steps through C8 and got stuck. 3. Water filled fine. 4. Seemed to skip C7 or not sure what C7 was supposed to do. 5. Water drains on C8. The agitator started moving back and forth. The basket spun a few times and stopped. Once water was drained completely it sounded like the pump was continuing to run dry or the motor was trying to spin and wouldn't engage. Could not tell which. What can we do?
SOURCE:
catriver
  • 878 Answers
SOURCE: drain pump starts and stops prior to final spin cycle
Jayron, is the motor jogging? start to spin, stop, start to spin stop. If so, your motor is jogging between the high and low start windings. The motor during spin should start on the high speed windings and stay there until most of the water is drained. GE came out with a new motor, harness and run cap because of this. If you have a meter, there should be a white and white/red wire going to the motor. If you have a steady 120V and it's doing this jogging, replace the motor with the kit...Let me know if this the issue, Catriver..post back.
Posted on Nov 05, 2006
  • 22 Answers
SOURCE: Fisher Paykel GWL10 US spin cycle issue
check out another website. ths.gardenweb.com/forum/laundry for other fix it tips on FPaykel.
Posted on Oct 21, 2008
  • 1028 Answers
SOURCE: Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Posted on Oct 25, 2008
SOURCE: stopped mid wash cycle,no drain,no spin, will not go to next cycl
water pump blocked with nylon stuffing from old pillow.removed front panel from hinges under the lid. water pump at the right hand corner removed hose then removed 2 cups of nylon threads and stuffing forced into pumps small openings where it was compacted to a solid mass.
Posted on Jan 06, 2009
  • 1122 Answers
SOURCE: Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Posted on Apr 24, 2009
Will not spin out, just hums
Probably a capacitor problem, see Amazon.
Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums
? 6:42
https://www.youtube.com/watch?v=WMvHOtTaTZ4
Feb 26, 2014 - Uploaded by canyonman1963
Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums - Testing ..... It does not do this every time but about every 3 outof 5 times.
Kenmore Washer Diagnostic - Hums, Will Not Run After ...
? 3:34
https://www.youtube.com/watch?v=C5F-_U0_hYw
Jun 29, 2013 - Uploaded by ApplianceVideo.com
Repair your own Kenmore Washer with these following problems:Hums, Will Not Run After Filling Only at ... Find out why. Close ... Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums- Testing Capacitor, Waterpump ...
Dec 10, 2015 | Kenmore Washing Machines
I have a top loader kenmore elite washer t won't finish a load without rocking
You may have an item between tubs:
Service Manual
If this ain't yer model look around the blog for yours. American made stuff is what I do. Cheers
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 21, 2012 | Kenmore Elite Oasis 27052 Top Load Washer
My Kenmore Elite Oasis washer unbalanced signal seems to be very sensitive. Only after several tries of readjusting the load to get it really even that the washer will spin without stopping. I made sure...
If the washer throws an UL error code with out any clothes in the washer then the issue must be concerned with the mechanical alignment inside the machine or a bad CCU.
The most common problem which can cause this is some sort of mechanical hinderance which does not allow the basket to move freely.
The suspension system which holds the basket in its place might be faulty and causing the unbalancing. In this model i think there are plastic ring at the bottom of the basket . Even if they are worn out or moved out of position it may cause the UL error code you are facing
Nov 09, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore oasis elite He, I am unable to get the washer into the manual diagnostic test mode. A couple of days ago, when I first started trying to figure out the f-51 error code, I was able to enter manual...
F51 is a RPS sensor code .The computer thinks the motor is drawing excessive current to rotate the basket. In repairing these units 8 out of 10 times their was no part failure, the problem was clothing got under the basket causing excess draw.Try taking your hand and spinning the basket it should rotate very smoothly and not have any dragging,if it hangs up at all you can easily remove the basket and get out the clothing that got in there.....
Sep 16, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore elite oasis top loader 27062
See the following Whirlpool / Kenmore service manual for the Whirlpool Cabrio washer. The Kenmore Oasis is basically the same.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Also see the Sears Parts site for your washer.
Enter the full (###.########) model number and you should see descriptions of the major components and parts lists.
May 04, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
My oasis kenmore elite keeps flashing f 50
The machine control through the rotor position sensor (RPS) cannot detect the motor running. The rotor is stuck, the rotor position sensor is faulty, or the machine control is malfunctioning. Open the lid and turn the drum manually. If it turns freely, activate the Manual Diagnostic Mode Test to check the functionality of the rotor position sensor and the machine control. If it doesn't turn freely, let us know to guide you in troubleshooting and repairing it.
The machine should be in standby mode when activating diagnostic test mode. That is, the machine is plugged in will all indicators off, or with only the Clothes Clean indicator on.
Choose any single button except Start, Stop, and Power. Press and hold the chosen button for 3 seconds and release it for 3 seconds; press it again for another 3 seconds and release it for another 3 seconds; press the same button again for another 3 seconds and release it (press, release, press, release, press; 3 seconds each).
The indicators will all light up for 5 seconds with 88 displayed in the Estimated Time Remaining display if the test mode has been successfully entered.
Repeat the procedure if the test mode is not activated. You may choose another button. Let us know if it cannot be activated after multiple attempts failed.
Press the same button chosen above before the indicators turn off (5 seconds). A single beep sounds and the two-digit console ID number is displayed. After 3 seconds the display is cleared (00) and the Add a Garment indicator flashes.
Open the lid and rotate the basket manually. The Wash, Rinse, and Spin status indicators should toggle on and off according to the rotation of the basket.
Press and release the 2nd Rinse button to lock the lid and the lid lock indicator turns on. Press and release the Rinse Speed button. The basket should spin slowly; pressing it again will raise the spin speed. The motor turns off and the basket stops the fourth time the Rinse Speed button is pressed.
With the basket stopped, press the Soil Level button to activate the Gentle wash action. Press it again to activate the Normal wash action. Press it again to activate the Heavy wash action. Press it again to turn off the motor and stop the basket.
Let us know the result of the test for us to guide you in troubleshooting the problem and eventually repair it.
Feb 22, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Water is not pumped away, or stops in the middle of a cycle and displays one of a several error messages
Recall the error codes by activating the Automatic Diagnostic Test Mode to determine the cause of the problem. Select any one button, except Power, Start, and Stop, and follow this:
Press and hold the button for 3 seconds>Release the button for 3 seconds>Press and hold the button for 3 seconds>Release the button for 3 seconds>Press and hold the button for 3 seconds
All of the indicators on the console will light up for 5 seconds while 88 is displayed on the Estimated Time Remaining display. If not, repeat the step. Let us know if it cannot be activated.
The program then checks for any saved error codes after 5 seconds. List down the codes and post it back here. The console indicators will turn off then on with the 88 displayed if no error codes are recalled. After 5 seconds, the automatic test begins. The program performs a four-minute automatic test to check major washer functions. Press the same selected button in activating the automatic test above to advance through the automatic test steps.
  1. C0: The motor goes to a slow spin.
  2. C1: Warm water fills through the fresh dispenser and basket floats then disengage.
  3. C2: Cold water fills through the bleach valve for 10 seconds.
  4. C3: Hot water fills through the fabric softener valve for 10 seconds.
  5. C4: Warm water fills through the detergent valve for 10 seconds.
  6. C5: Agitates for 15 seconds.
  7. C6: Recirculates for 10 seconds.
  8. C7: Drains to engage basket and drain further for 10 seconds.
  9. C8: Drains and spins slowly.
  10. C9: Coasts to stop.
  11. Press the Stop or Power button to cancel/exit the test.
Inform us about the result of the test for the repair guide if necessary.
Feb 10, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
I hadn't washed any laundry for a couple days and then my Kenmore Elite Oasis starting beeping in the middle of the night. My husband had to unplug it because it wouldn't stop. The next morning I did some...
According to the Whirlpool Cabrio (Sears Oasis) manual, this code indicates a "stuck key"
Keypad/User Interface Failure
F then 2 flashes when in:
• Diagnostics Test mode if a stuck key is detected.
• Standby mode if there is a user interface mismatch.
Following is the PDF of the manual.
Sep 22, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite oasis model 27082605 type 580 has f51 code what can i do
The F51 error code indicates that the control is not sensing proper motor movement through the signals from the RPS (rotor position sensor) circuit. This can be caused by several different problems. Make sure that you are not overloading the washer. Overloading can cause this problem. A toy or foreign object could be under the washer that is interfering with motor rotation. With the washer empty, spin the basket inside the washer tub to see if it spins relatively easily. If not, you could an item caught between the spin basket and the tub. You could have a wire harness problem causing signals to not be transmitted properly between the RPS and the machine control board. A failed RPS sensor or a failed control board could also cause this problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 25, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Need diagnostic test for Kenmore Elite Oasis HE top load washer it is making beeping noises and has a mind of its own
pick any button but power or pause (spin works ok) pres and hold 3 sec release 3 sec hold 3 sec release 3 sec hold 3 sec this will put intio diagnostics usually if a fault code is stored this will show first press same button to step through post fault code if any asap and will try to help may to try several times to get into diagnostics
Jun 21, 2008 | Washing Machines
Washing Machines Logo
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Gordon Richard...
