GMC 1995-1997  Yukon Ignition Starter Alarm Switch
Problem for GMC 1995-1997 Yukon Ignition Starter Alarm Switch
My 99 yukon will run fine some days and sometimes
By rockbottomku on Aug 07, 2009
my 99 yukon will run fine some days and sometimes I will park it go into a store or whatnot and it will start for two seconds then turn off . I usually have too put fuel in the intake about 3 time to get it to fire up then run fine. does anyone know why.
Best Solution
posted on Aug 07, 2009
Helpful)
MNfisherman
Rank: Wiz  GMC Expert
Rating: 85%, 2831 votes
Plugged fuel filter, or faulty fuel pressure regulator. Last possibility would be bad pump but since it does run, it I would first change fuel filter, then regulator if necessary
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Very Helpful)
VtToolMan
Rank: Guru
Rating: 97%, 656 votes
You might want to take a look at a Haynes manual, as I believe there are two (2) fuel pumps in the Yukons and Suburbans. I had one fail and because of that, it would hard start after some trips and other times it would be fine.
MIght well be worth the small price to buy a repair manual at your local auto parts store, just for the troubleshooting guide and pictures showing the location of all the key parts.
Hope this helps and best regards!
Was this helpful?
Yes
No
Solution #3
Not Rated)
stitches71
Rank: Guru
Rating: 85%, 19 votes
either your fuel pump is going bad or the relay to the fuel pump. Have you changed you fuel filter lately.
Was this helpful?
Yes
No
Popular Solutions for GMC 1995-1997 Yukon Ignition
Questions and Unsolved Problems for GMC 1995-1997 Yukon Ignition
Do you recommend GMC 1995-1997 Yukon Ignition Starter Alarm Switch?
Answer
Answer
turns over wont start no power to coil and no check engine light
Answer
when I unlock the door on my 1999 Yukon with the wireless, it will not start. I have to unlock it... (More)
Answer
can a bad ignition switch cause the transmission to slip and give a 1870 code for the check engin... (More)
Answer
gmc yukon shuts down after driving for a long time when chech fuses found that the ecm1 fuse is... (More)
Answer
new starter does not engage in my 1999 GMC yukon
Describe your Car Security Systems problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Car Security... Experts
Top Audio & Video Equipment Repairmen
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
