Home | Danby | DDR586R Dehumidifier - 58 Pints Dehumidifier | Compressor stopped wor...
Danby DDR586R Dehumidifier - 58 Pints Dehumidifier
Problem for Danby DDR586R Dehumidifier - 58 Pints Dehumidifier
Compressor stopped working after two days
By b_medd on Aug 07, 2009
Fan works fine
Compressor worked well for two days, now it tries to start but can't, then tries again every 20-30 seconds.
Solution #1
posted on Aug 07, 2009
Not Rated)
hvacwork757
Rank: Apprentice
Rating: 0%, 0 votes
Usually a capacitor going bad will cause something of that sort but if the compressor has age it may require a super boost capacitor to help it start. Both of these items have to be purchased from a distributor. I have access to the parts if you want to try that other than that I hope the info helps.
Was this helpful?
Yes
No
Solution #2
Not Rated)
blvl777
Rank: Guru
Rating: 89%, 89 votes
It could be one of four things, a bad run capacitor, start capacitor, start relay or the
compressor is locked up.
I would think it's either the run capacitor. A lot of times you can look at it and if it's bulging even slightly then it's bad, if not it's probably the start capacitor and relay I add the relay in because when you change one you should change the other also..
Was this helpful?
Yes
No
Popular Solutions for Danby DDR586R Dehumidifier -
Questions and Unsolved Problems for Danby DDR586R Dehumidifier -
Do you recommend Danby DDR586R Dehumidifier - 58 Pints Dehumidifier?
Answer
Answer
i recently had a brown-out and have had damage to a number of appliances. this occurrance blew the... (More)
Answer
how could i use my ddr586r dehumidifier because i lost my instraction
Answer
Danby Dehumidifier Model # DDR586R Serial # 6763858666 (only 28 months old) - Does not collect water... (More)
Answer
tank does not fill with water at all. How to adjust humidty levels? what does the temp grad mean?... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Danby DDR586R Dehumidifier -...:
Top Dehumidifier Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dehumidifier Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
