Question about Frigidaire FSC23F7DSB Stainless Steel Side by Side Refrigerator
Water dispenser ice maker works fine but water dispenser is frozen. How do you unfreeze it
  • Anonymous Nov 29, 2007
    Water settled and freezes at bottom of freezer about one quarter of an inch every three days
Disconnect the water line at the bottom front of the frig. Press the lever to dispense water. If you get water out of the line, then the water line to the water dispenser is frozen inside the door. Leave the freezer door open for a few minutes to soften the ice. Use a length of plastic line from a string trimmer to push into the water dispenser and force the ice out the bottom of the water tube.
Posted on Jan 10, 2008
  • 44 Answers
Hello, If you can see the water line inside the freezer case you might try using a hair blow dryer to try to thaw it out to get water flowing again? Good Luck! Dr. Know
Posted on Dec 23, 2007
Model #WSF26C2EXY02. Why is ice maker not making ice?
When the ice-tray is full it pushes 'UP' a lever that shuts the water supply off. When you move the lever down all goes back to normal.
Oct 14, 2015 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker isn't working. Water is not filling the tray but the water dispenser in the door works fine.
could be frozen water fill tube to Icemaker. or solenoid water valve is not opening when ice maker calls for ice. there are 2 separate solenoid valves : one for dispenser another one for ice maker.
Mar 28, 2015 | Refrigerators
ED0GTQXMQ00 water dispenser
Hi. We are sorry that the ice maker is not working. Hereis a link to schedule a service call: . I hope this information is helpful. Sincerely, Melaine, Whirlpool Socail Media.
Apr 15, 2012 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
No ice being made. The water is not eing supplied to the ice tray. The water dispenser in the door is working fine.
Well since water is making it to your door the line itself is functioning. You might want to check and see if the fill tube to the ice maker is frozen. Also try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear. If it does then the ice maker is at fault.
Mar 19, 2011 | Refrigerators
Water dispenser stopped dispensing water but ice maker is still working fine
I had the same problem. Ice maker works fine. Removed the kick plate at the bottom of the fridge to expose the water line. I disconnected it and then pressed the dispense button. Water pumped out of the line so i know water was getting all the way to the freezer door. I went overkill but it worked. I removed the freezer door and placed it outside. (disconnected the power to the door by disconnecting the plug at the top. and then removed two screws/bolts at the top and the door lifts up and off) I set the door on a patio table with the bottom facing up. I picked up some 16 gauge wire ($6 at Home Depot) and ran it up the water tube from the bottom of the door. The bottom is more of a straight shot up the water line. I also took a turkey syringe used to inject juice into a turkey and i shot very hot water up the line with the door upside down. This allowed water to run up the line and unfreeze it if it was frozen. I let it sit outside for 30 minutes and put the door back on and now it works like a champ. The line was either frozen or it was obstructed. The water line is surprisingly small. Took less than an hour and I now have water again. Not tough at all...
Oct 06, 2010 | Whirlpool GS6SHEXNL Side by Side...
Ice maker no longer works. It has been working for years and all of the sudden the ice tray does not fill up with water, however the water dispenser dispenses water just fine....
The unit uses a dual water and possibly the side which supplies the ice maker has become defective. Also check to see if the fill tube has frozen.
Apr 30, 2010 | Thermador KBUIT4260A Stainless Steel
Water dispenser not working
I had the same problem. Your water line is frozen. Turn off your freezer and the water line will unfreeze and it will work. You can see about putting in a heater on your water line. There have been mixed reviews on whether or not it works. The water line just froze again, so I may try the heater.
Apr 28, 2010 | Viking DDSB483 Side by Side Refrigerator
Ice Maker Works, Water Dispenser Doesn't
I have a whirlpool side by side. water and ice in front. ice working and water not. the hose is not frozen and it is not humming when you push the water dispenser. It would give us water and quit but now we have nothing.
Jun 25, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker stopped working
if the water dispenses from the water dispenser I would say its the. Ice maker control module...try here and the link is on the guru guy on the left
Jun 15, 2009 | KitchenAid Superba Architect KSCS25INSS...
Water dispenser fine but ice maker not working
Hi. A good way to check the ice maker water solenoid valve is to swith the wire lead from the dispenser water solenoid valve to the ice maker water solenoid valve. Now push the water dispenser lever and water should come out your ice maker fill tube. If not, either the fill tube is frozen or the ice maker water solenoid valve is bad. Take the 1/4 inch tube that runs up the back of your freezer off at the ice maker water solenoid valve and blow thru it. If you can't, the tube is frozen. If you can, the valve is bad. Good luck, Mack
Jan 31, 2008 | Refrigerators
Frigidaire FSC23F7DSB Stainless Steel Side by Side Refrigerator Logo
859 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
