Question about Kenwood Audio Players & Recorders
How to hook up kenwood equalizer GE-46, tunner KT-56, cassette deck KX56W and amplifier KA-76 with each other
  • Kenwood Master
  • 587 Answers
Hello Pandit, the sequence of connections that I suggest, is the following, you connect the tuner KT-56 in the Tuner input of the KT-76 amplifier, the Cassettera deck in the Tape 1 connections of the KT-76, and the GE- equalizer 46 on the Tape 2 connections
I sent you the link to download the KT-76 user manual
on the third page there is a description of the connections, in your case instead of cassette 2 you will connect the GE-46 equalizer
I hope you manage to interconnect all the equipment and enjoy good music
Greetings Franco Dosil
Hola Pandit, la secuencia de conexiones que te sugiero, es la siguiente, conectas el sintonizador KT-56 en la entrada Tuner del amplificador KT-76, la Cassettera deck en las conexiones de Tape 1 del KT-76, y el ecualizador GE-46 en las conexiones de Tape 2
Te env?o el link para que descargues el manual de usuario del KT-76
en la tercer pagina hay una descripci?n de las conexiones, en tu caso en vez de la cassettera 2 conectaras el ecualizador GE-46
Espero que logres interconectar todos los equipos y disfrutes de buena m?sica
Saludos Franco Dosil
https://data2.manualslib.com/pdf3/78/7752/775116-kenwood/ka76.pdf?6a142b74fc7e4a25b8f7a8d010836b1f&take=binary
Posted on May 02, 2019
Testimonial: "Thanks for the help friend, but my amplifier is not having in built equalizer. my equaliser is a separate unit GE-46. Pl.can you help for the same."
  • Franco Dosil
    Franco Dosil May 02, 2019
    Hello Pandit, thanks for your comments, I will try to assist you so you can interconnect your Kenwood GE-46 equalizer, with your Kenwood KA-76 amplifier
    The Kenwood GE-46 equalizer has two sets of RCA connections on its rear panel, one is Line In and another Line Out
    The first, Line In, is connected to the Kenwood amplifier KA-76, on the rear panel, to the RCA connection, Rec Out of Tape2, the second, Line Out, is connected to the Kenwood KA-76 amplifier, on the panel later, to the RCA connection, Play In of Tape2,
    This way you can connect your GE-46 equalizer with your amplifier KA-76
    To be able to hear the sound processed by the equalizer, you must press the Tape2 key on your KA-76 amplifier
    I hope that you have been more understandable my comment
    enjoy your Kenwood sound system
    Hola Pandit, gracias por tus comentarios, tratare de asistirte para que puedas interconectar tu ecualizador Kenwood GE-46, con tu amplificador Kenwood KA-76
    El ecualizador Kenwood GE-46 tiene en su panel posterior dos juegos de conexiones RCA, una es Line In y otra Line Out
    La primera, Line In, va conectada en el amplificador Kenwood KA-76, en el panel posterior, en el juego de conexi?n RCA, Rec Out de Tape2, la segunda, Line Out, va conectada en el amplificador Kenwood KA-76, en el panel posterior, en el juego de conexi?n RCA, Play In de Tape2,
    De esta manera podr?s conectar tu ecualizador GE-46 con tu amplificador KA-76
    Para poder escuchar el sonido procesado por el ecualizador, debes presionar la tecla Tape2 en tu amplificador KA-76
    Espero que te haya quedado mas comprensible mi comentario
    disfruta de tu sistema de sonido Kenwood
    javascript:openreq(http://www.usersmanualguide.com/manuals/...')
SOURCE:
dunnbiker
  • 8546 Answers
SOURCE: I have an old kenwood
Connect the RCA Outputs of the Tuner to the RCA inputs for Tuner on the amp.
Connect the output of the Tape Deck to the Tape Input on the amp.
Connect the input of the Tape Deck to the Tape Output on the amp.
Select Tuner on the amp to listen to the tuner.
Select tape Monitor to hear the Tape Deck(s).
Posted on Dec 30, 2010
SOURCE: I HAVE A OLDER KENWOOD
i have fisher rs727 recevier and a kenwood km-106 amp and adc stereo eq sound shaper two how do i plug it together
Posted on Apr 19, 2011
dunnbiker
  • 8546 Answers
SOURCE: I want tohook up a Kenwood KA-88 Amp. to a KT-58
Find the manuals or go by the basic INs to OUTs rule. REC = OUT, Play = IN. "Tuner" and "Aux/CD" are not literal. They're for anything BUT a turntable. But remember ONLY a turntable would ever use "PHONO".
This picture shows the rear of the KA-88
http://www.canuckaudiomart.com/view_images.php?cat=Amplifiers&catnick=amplifiers&cfid=168328&image_id=1469879
Register and download the CD manual for free at retrevo.com
http://www.retrevo.com/support/Kenwood-DP-M5540-CD-Players-manual/id/479ag101/t/2/
Posted on Jun 28, 2011
dunnbiker
  • 8546 Answers
SOURCE: No Problem Yet with Kenwood
Outs go to Ins. Turntable goes to PHONO. Tape Deck goes into Tape REC and Playback. All other inputs are Line Level and interchangeable despite the labeling. RCA cables all.
One speaker pair per speaker post set. Stripped ends of lamp cord suffice. Don't short anything or make any changes with power on.
It ain't rocket science.
You might find manuals at the manufacturer's support site, by using a common search engine or these guys...
retrevo.com
audio.manualsonline.com
hifiengine.com
usermanualguide.com
vinylengine.com
Search Engine of your choice: "(product) manual"
Posted on Sep 15, 2011
AJIN G
  • 6694 Answers
SOURCE: Don't know how to hook up kenwood ka-994
Check the bellow link for the user manual of kenwood KA-994. In page number 4 of the user manual You can see how to make the connections to the receiver
Manual
Ajin
Posted on Mar 10, 2012
On a kenwood KR597 reciever, where do i hook up my KE597 graphics equalizer. Also must i remove my DP-R797 cd player to hook up my Maeantz PMD520 Cassette deck? Finally divorced
If you only have one set of tape in/out connectors, then hooking up two tape decks and an equalizer is going to be difficult. You could hook the "tape out" to one tape deck, that tape's output to the second tape, and the second tape's out to the equalizer, connecting the output of the eq back to your receiver....
Nov 01, 2014 | Audio Players & Recorders
I have a 1987 model kenwood home stereo system ihave a graphic equalizer ge 76 control amplifier kc206 synthesizer tuner kt76 power amp km206 how does the RCA connections hook up which ones go to...
First connect all sources like tuner, cassette player, Cd player into the proper RCA inputs of the control amp, then connect the output of the control amp into the input of the equalizer. Then connect the output of the equalizer into the input of the amplifier. This is how to get the best performance and proper outputs to all the right equipment. The speaker outputs of the amplifier would then go to the speakers.
Let me know if you need more help from me by addressing your post to me, or if you wish to communicate with another expert you can address your post to them I.E. @tech48 or @whoever
Thanks and good luck,
Dave
Sep 27, 2008 | Kenwood Audio Players & Recorders
KENWOOD KX56W/CW
I have a KX-56W. I can get the user manual for you if you still need it
Jul 02, 2013 | Audio Players & Recorders
Kenwood ka 996 integrated amp. The standby light will dont turn off. I also need to see if someone will tell how everything should be hooked up.
the standby light should be on if the unit is not 'ON' if you want the 894 to turn on when you power up the 996, then you will have to plug the ac for the 894 into the 'switched' ac outlet on the back of the 996
what specific problems do you have with this system
Mar 07, 2013 | Audio Players & Recorders
I just got a Kenwood system, i would like to know how to hook it up, it has, Kenwood power amplifier km207, kenwood stereo control amplifier kc 207, disc player dp-m 97, cassette deck ky-77 cw, stereo...
That's a pretty standard setup. RCA cables from the KM207 to the preamp (KC207), and RCA cables from all of the other components into the KC207. Speakers connect into the KM207
Nov 01, 2012 | Master DE Kenwood with Housing...
Manual
Ajin
Mar 09, 2012 | Audio Players & Recorders
I want tohook up a Kenwood KA-88 Amp. to a KT-58 Tuner to a DP-M5540 disc player and KA-68W Cassette deck. how do I do it?
Jun 28, 2011 | Audio Players & Recorders
I have an old kenwood stereo system I forgot how to hook up it is a ka-87 amplifier a kt-57 tuner and a double deck cassette player kx-57w .Can anyone help?
Dec 30, 2010 | Audio Players & Recorders
I HAVE A OLDER KENWOOD STACK HOME STEREO SYSTEM WITH OUT MANUALS OR REMOTES AND NEED TO KNOW HOW TO HOOK ALL THE COMPONENTS TOGETHER. KC-206 STEREO CONTROL AMP KT-76 TUNER KX-96W CASSETTE DECK KM-106...
start with the tuner, hook up the equalizer to the tuner, then on the rear of the equilizer hook up all the peripherals except the amps which will go to the tuner outputs and all will feed thru the tuner to the amps and out to the speakers
Oct 23, 2009 | Audio Players & Recorders
Kenwood stereo intergrated amplifier a-76
The only tricks to power up again are this:
Amp to Equalizer : Use the "Connector " of the Amplifier - IN and OUT and connect them to the Line IN and Line Out of the equalizer;
All modules: Use the system control cable like in serie, for example the lowest connects to the above and from thsi one to the other above and so on;
Regarding Power: both CD, Deck and Tunner have different colors to connect to the Amplifier power source, you can't miss it;
Audio Cables, just follow the IN and OUT with correct colors and you are done!
Rgds,
TrepaTrepa
Feb 21, 2008 | Audio Players & Recorders
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
rigger094
Mike Duncan
Mike Duncan
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
