Question about Clarion DRB2475
Wiring The yellow wire from the connector(White) has come out, How can i fix it back in, is there a way or do i have to replace the whole harness, Also my car battery has been running out, is it because this wiring is loose, has the +12v constant power got to do with the battery power leakage??
  • 709 Answers
If you can fish the connector out of the white block and it is not broken, you may be able to recrimp to it and pop it back in the original connector.
If you have something staying on all the time, that will kill your battery. Sometimes, it is a trunk light or Brake light staying on. If you had these wires opull out and ground, yes, that will kill your battery.. You may need to get on Ebay and get you a new connectors and or wiring harness for your head unit.
Posted on Nov 27, 2007
Specifically I'm trying to identify the wire on the spark plug coil assembly to which I should connect the signal wire of a Tachometer to. The wire colours are, red, yellow, green/white, and blue.
It says the tachometer wire is Yellow/Green, you do not have that listed. You will find it in the list below, it is highlighted..
WIRING INFORMATION 2001 Subaru Legacy
WIREWIRE COLOR LOCATION
12V CONSTANT WIRE WHITE Ignition Harness
12V IGNITION WIRE GREEN Ignition Harness
12V ACCESSORY WIRE YELLOW Ignition Harness
STARTER WIRE WHITE/BLACK Ignition Harness
POWER DOOR LOCK (-) WHITE Harness In Driver's Kick Panel
POWER DOOR UNLOCK (-) GREEN/RED Harness In Driver's Kick Panel
PARKING LIGHTS (+) ORANGE At Light Switch
DOOR TRIGGER (-) PINK/BLACK In White Connector Behind Fuse Box
TRUNK TRIGGER (-) YELLOW/BLUE In White Connector Behind Fuse Box
TRUNK RELEASE (5-wire) LT.GREEN/YELLOW At Motor In Tail Gate
FACTORY ALARM ARM (-) Factory remote only
FACTORY ALARM DISARM (-) Factory remote only
TACHOMETER YELLOW/GREEN At Ignition Coil
BRAKE WIRE (+) WHITE/BLACK At Brake Pedal Switch
HORN TRIGGER (-) RED/GREEN Harness At Steering Column
LEFT FRONT WINDOW UP BLUE/RED At Driver Window Motor Inside Door
LEFT FRONT WINDOW DOWN BLUE At Driver Window Motor Inside Door
RIGHT FRONT WINDOW UP BLUE/RED Harness In Driver's Kick From Driver Door
RIGHT FRONT WINDOW DOWN BLUE Harness In Driver's Kick From Driver Door
LEFT REAR WINDOW UP BLUE/RED Harness In Driver's Kick From Driver Door
LEFT REAR WINDOW DOWN BLUE Harness In Driver's Kick From Driver Door
RIGHT REAR WINDOW UP BLUE/RED Harness In Driver's Kick From Driver Door
RIGHT REAR WINDOW DOWN BLUE Harness In Driver's Kick From Driver Door
Feb 07, 2016 | 2001 Subaru Legacy
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1996 Honda Civic This...
This FixYa Tip is for the purpose of installing an Alarm, Remote Starter, Cruise Control, and / or Car Stereo into the vehicle listed in the subject line.
The wires listed are the ones you will need to successfully complete the task.
Some vehicles require additional relays and / or modules to bypass factory security. If they are required - it will be in the NOTES section below the wiring colors.
The following FixYa TIP is good for all Honda Civics for the following production years:
1996
STEREO WIRING COLOR CHART:
Constant 12V+: Blue/White
Switched 12V+: Yellow/Red
Ground: Black
Illumination: Red/Black
Dimmer: n/a
Antenna: Driver's Pillar
Front Speakers:
Left Front (+) Blue
Left Front (-) Gray/Black
Right Front (+) Red/Green
Right Front (-) Brown/Black
Rear Speakers:
Left Rear (+) Blue/Yellow
Left Rear (-) Gray/White
Right Rear (+) Red/Yellow
Right Rear (-) Brown/White
NOTES: Retain Keyless entry with secondary Harness Listed Below
Additional Accessories:
Metra Brand Dash Kit: 89-30-7891 - 99-7891 - 99-7898
Metra Brand Wiring Harness: 70-1720 W/Keyless Entry # 70-1720T
Metra Brand Antenna Adapter: n/a
ALARM / REMOTE START WIRING CHART:
Constant 12V+: White - Ignition Switch Harness
Starter: Black/White - Ignition Switch Harness
Ignition: Black/Yellow - Ignition Switch Harness
Ignition 2: Yellow - Ignition Switch Harness
Accessory: White/Black - Ignition Switch Harness
Tach: Blue - Coil
Brake Switch: Green/White - Brake Switch
Trunk Pin: Blue/Black - (-) Driver's Kick Panel
Parking Lights: Red/Black - (+) Driver's Kick Panel
Head Lamp: Red/White (L) Red/Blue (R) - Steering Column
Hood Pin: n/a
Door Trigger: Light Green/Red - (-) Above Fuse Panel
Door Lock: Green/White - (-) 2 pin connector taped to blue connector behind fuse box
Door Unlock: Green/Orange - (-) Module Behind Radio
Horn: Grey - Steering Column or GREEN connector behind radio
NOTES: - none -
CRUISE CONTROL:
Constant 12V+: White - Ignition Switch Harness or Use Hot Side of Brake
Switched 12V+: Black/Yellow - Ignition Switch Harness
Ground: Use Chassis Near Cruise Control Module
Hot Side of Brake: n/a - Brake Switch
Cold Side of Brake: Green/White - Brake Switch
Tach: Blue - Coil
VSS Wire : Blue/White - Driver's Side Dash Footwell, Grey connector.
NOTES: PPM - 4000PPM
ROSTRA Control Arm # 250-3421/250-1483
ROSTRA Throttle Adapter #250-4249
Vehicles with Manual Transmission require Clutch Switch.
Some vehicles may require a speed signal generator and/or other parts/adapters not listed above.
Rostra® Cruise Control module switch settings may differ if you use a speed signal generator or magnets and a pick up coil.
Thanks for using FixYa!! Please see my other tips on GPS, Car Audio, Large Appliances, and more.
on Apr 03, 2010 | Honda Civic Cars & Trucks
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1995 Honda Civic This...
1995
Ground: Black
Dimmer: n/a
Front Speakers:
Left Front (+) Blue/Green
Rear Speakers:
NOTES: - none -
Metra Brand Dash Kit: n/a
Accessory: Yellow - Ignition Switch Harness
Tach: Blue - Distributor
Trunk Pin: Green/Black - (-) Above Fuse Panel (Blue Connector)
Parking Lights: Red/Black - (+) Above Fuse Panel
Head Lamp: Red/White - Steering Column
Hood Pin: n/a
Door Trigger: Light Green/Red - (-) Driver's Running board
Door Unlock: Green/Red - (-) Driver's Door at Door Lock Module
Horn: Blue - Steering Column (Relay Required)
Windows UP: LF=Red/Blue RF=Blue/Yellow
Windows DOWM: LF=Red/Yellow RF=Blue/Green
NOTES: - none -
CRUISE CONTROL:
VSS Wire : Yellow/Blue - Driver's Side Dash Footwell, Grey connector.
NOTES: 4000PPM
My speedometer not working? is it cause of the after-market radio i put in be the reason.. mitsubishi galant 2002 6 cylinder
So we can rule out the speed sensor and its circuit to the PCM.
I just checked through another area of my database and it seems the speed sensor is systated as on the side of transaxle, near firewall, maybe you can dheck that out to confirm, just out of curiosity and for future reference and some portion of testing requires unplugging the conections.
Anyway I will provide a complete diagnostic pocedures for you to check through and hope an answer is found.
PS. After going through the diagnostic procedure, I believe your radio is the cause of the problem. Refer to # 10
SPEEDOMETER DOES NOT WORK
1. Connect scan tool to data link connector, check for Diagnostic Trouble Code (DTC). If DTC P0500 (Vehicle Speed Sensor) is set, diagnose this DTC first. Go to step 6 . If DTC P0500 is not set, go to next step.
2. On Eclipse, if trip odometer is not working normally, go to next step. If trip odometer is working normally go to step 5. On Galant, if tachometer is not working normally, go to next step. If tachometer is working normally, go to step 5
3. Disconnect instrument cluster connector. Turn ignition switch to ON position. Connect DVOM between ground and instrument cluster connector terminal No. 52 (Black/White wire) on Eclipse or terminal No.29 (Black/White wire) on Galant. If battery voltage is present, go to next step. If battery voltage is not present, check harness connectors and harness wiring between instrument cluster and ignition switch for damage. Repair as necessary.
4. Using a DVOM, check resistance between ground and instrument cluster harness connector terminal No. 34 (Black wire) on Eclipse or terminal No. 30 (Black wire) on Galant. If resistance is less than 2 ohms, replace instrument cluster printed circuit board or speedometer and tachometer. If resistance is greater than 2 ohms, check instrument cluster connector and harness wiring. Repair as necessary. If connector and wiring are okay, go to next step.
5. Disconnect vehicle speed sensor connector and instrument cluster connector. Turn ignition switch to ON position. Connect DVOM between ground and harness side of instrument cluster connector terminal No. 29 (White/Blue wire) on Eclipse or terminal No. 16 (Yellow/Black wire) on Galant. Voltage should be 5 volts. If voltage is okay, repair or replace instrument cluster printed circuit board or speedometer and tachometer. If voltage is not 5 volts, check instrument cluster connector and harness wiring. Repair as necessary. If connector and wiring are okay, go to next step.
6. Disconnect vehicle speed sensor harness connector and connect DVOM to harness side. Check vehicle speed sensor power supply voltage between terminal No. 1 (Black/White wire) on Eclipse or (Black/Blue wire) on Galant and ground. Battery voltage should be present. If voltage is okay, go to next step. If voltage is not present, check vehicle speed sensor harness connector and wiring. Repair as necessary.
7. Using DVOM, check resistance between ground and vehicle speed sensor harness connector terminal No. 2 (Black wire). Resistance should be less than 2 ohms. If resistance is greater than 2 ohms, check instrument cluster connector and harness wiring. Repair as necessary. If connector and wiring are okay, go to next step.
8. Disconnect vehicle speed sensor harness connector. Connect DVOM between ground and harness side terminal No. 3 (White/Blue wire) on Eclipse or (Yellow/Black wire) on Galant. If 9 volts are not present, check vehicle speed sensor harness connector and wiring. Repair as necessary. If 9 volts are present, go to next step.
9. Check harness wiring between vehicle speed sensor connector to radio and tape player connector, auto-cruise control ECU ECM (M/T) or PCM (A/T) connector and instrument cluster connector. If connectors or wiring are damaged, repair as necessary. If connectors and wiring are okay, go to next step.
CAUTION: To prevent damage to scan tool, always turn ignition off before connecting or disconnecting scan tool.
NOTE: If ECM (M/T) or PCM (A/T) is replaced, immobilizer-ECU should also be replaced. Each ECM (M/T) or PCM (A/T) has an encrypted code for immobilizer-ECU, and is registered in immobilizer-ECU.
10. Connect scan tool to data link connector. Turn ignition switch to ON position. Read DTC. Disconnect radio and tape player connector. If DTC P0500 does not reset, replace radio and tape player. If speedometer does not work, disconnect auto-cruise control ECU connector. If DTC P0500 does not reset, replace auto-cruise control ECU. If speedometer does not work, disconnect instrument cluster harness connector. If DTC P0500 does not reset, replace instrument cluster. If DTC P0500 resets when any connector is disconnected, replace ECM (M/T) or PCM (A/T).
9_6_2012_10_56_48_am.gif9_6_2012_10_57_03_am.gif9_6_2012_10_57_17_am.jpg9_6_2012_10_57_28_am.jpg9_6_2012_10_57_39_am.jpg9_6_2012_10_57_52_am.jpg9_6_2012_10_58_05_am.jpg9_6_2012_10_58_16_am.jpg
Sep 06, 2012 | Cars & Trucks
I need diagram to wire defy 600s hob and oven , can you help please
Hi Gary The hob connectors have colour coded plug ins. They are starting from right to left the red connector is for the front right plate, the white is for the back right plate, the blue is for the the back left plate and the black is for the front left plate. Now I am not sure of the config in your country but another way to look at this is that The red dot 2000 W (large plate) is connected to the black harness and the red dot 1500 W is connected to the blue harness. The std large plate 1500 W is connected to the white harness and the red harness is for the 1000W small plate. The wiring onto the actual plates should be accrording to the colour codes as follows: The harnesses are all 4 wires and are colour coded blue white ( wiring block 1) , yellow white(block 2), white ( wiring block 3) and the red white block 4. The actual plates are numbered from left to right as 1,2,4,3. But my wiring write up takes it as standard 1 to 4 so do mot worry about the numbers on the plates as some plates have no numbers. Hope this helps.
Nov 09, 2010 | Stoves 1100ESIDLa Electric Kitchen Range
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1994 Honda Civic This...
1994
Ground: Black
Dimmer: n/a
Front Speakers:
Rear Speakers:
NOTES: - none -
Hood Pin: n/a
NOTES: - none -
CRUISE CONTROL:
NOTES: 4000PPM
on Apr 01, 2010 | Honda Civic Cars & Trucks
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1993 Honda Civic This...
1993
Constant 12V+: White/Blue
Ground: Black
Dimmer: n/a
Front Speakers:
Rear Speakers:
NOTES: - none -
Parking Lights: Red/Black - (+) Above Fus Panel (White Connector)
Hood Pin: n/a
Factory Disarm: Disarms with Unlock
Door Trigger: Green/Red - (-) Driver's Running board
Door Lock: Green/White - (-) Driver's Door at Door Lock Module
Horn: Blue/Red - Steering Column (Relay Required)
Windows UP: LF=Red/Blue RF=Orange/White
NOTES: - none -
CRUISE CONTROL:
NOTES: 4000PPM
No trailer right turn signal or brake light
Hey Boon,
The pinouts for a 7-way plug are as follows:
Seven wire Trailer plugs:
Horse, stock or utility trailers:
White = Ground - 1
Blue = Electric Brakes - 2
Brown = Tail and clearance lights - 3
Black = Battery, aux power - 4
Yellow = Left turn/Brake - 5
Green = Right turn Brake - 6
Orange or Purple (not both) = Auxilliary or Reverse - 7
Recreational Vehicle:
White = Ground - 1
Green = Tail and clearance lights - 3
Red = Left turn/Brake - 5
Brown = Right turn Brake - 6
Yellow = Auxilliary or Reverse - 7
In both cases 4 is battery and 7 is reverse, aux or not used.
Double check your wiring using these lists as a reference.
Click here for my post on Trailer wiring
This should get us closer to the answer.
Best regards,
Mike
Sep 08, 2009 | 2004 Dodge Ram 2500
Wiring diagram to hook-up remote starter on 1996 dodge caravan
Constant 12V+ Red or Pink/Black - Ignition Switch Harness
Starter Yellow - Ignition Switch Harness
Ignition Dark Blue - Ignition Switch Harness
Ignition 2 Black/White - Ignition Switch Harness
Ignition 3 Dark Green/Red - Ignition Switch Harness
Accessory Black/Orange - Ignition Switch Harness
Tach Gray Or Blue/Tan PCM Coil 2.4 Liter - Engine
Neutral Safety Wire Black/White - Power Control Module
Brake Switch White/Tan - Brake Switch
Trunk Pin Tan/Black - 40 Pin Connector at Fuse Panel
Parking Lights Light Green/White (-) - Head Light Switch Harness left of Column
Head Lamp Green/Orange - Light Switch
Factory Disarm White/Dark Green - (665 Ohm) left Connector bottom of Fuse Panel
Door Trigger Brown/White (-) - Lower right Gray Connector at Fuse Panel
Door Lock White/Dark Green - BCM at Fuse Panel
Door Unlock White/Dark Green - White Connector B58 Connector
Horn Wire Black/Red - Steering Column
Windows Up LF=Light Green, RF=Brown/White, LR=Blue, RR=Gray
Windows Down LF=White, RF=Purple/White, LR=Red/White, RR=Dark Green
Your R/S instructions should tell you what goes where.
Thanks for using FixYa - a FixYa rating is appreciated!!
Jan 31, 2009 | Vehicle Parts & Accessories
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1992 Honda Civic This...
1992
Ground: Black
Dimmer: n/a
Front Speakers:
Rear Speakers:
NOTES: - none -
Hood Pin: n/a
Windows DOWN: LF=Red/Yellow RF=Blue/Green
NOTES: - none -
CRUISE CONTROL:
VSS Wire : Yellow/Red - Driver's Side Dash Footwell, Grey connector.
NOTES: 4000PPM
Car Audio & Video Logo
132 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
