Question about iLO (2 GB) MP3 Player
INTERNAL CHECK DISK &SWITCH OFF
CGH
  • 8,596 Answers
This is the worst mp3 player ever invented - i have to tell you this up front. There is no driver, the company does not support the product anymore - I would return it now while you still can.
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on Jul 05, 2008
A disk is stuck in my Harmon Kardon player. The door will open and close and I can see the disk but cant' get it out.
turn on the unit and then tried to press the play button while the cd tray is in place. if doesn't work, unplug the dvd player then open the cover to access the internal part. look for a broken limit switch for cd tray mechanical assembly or check weather the cd not in proper place in the tray that is why an error occur.
Sep 02, 2012 | Televison & Video
NOT APPEARING IN MY COMPUTER
If the Floppy Drive is not appearing in my Computer, open the PC and check that the cables are connected to the drive properly.
Also open Device Manager and check under Floppy Disk Drives that the drive actually appears there.
Aug 30, 2010 | NEC FD1231M 144MB 35" Internal Floppy Disk...
We had a lightning strike which hit the house phone wire and knocked it out. the tv and dvd player didn't get hit. we turn the dvd player on it plays but no picture. the input button on remote won't switch...
Check the TV internal fuse. If fuse is OK check the SMPS. Lightning damage could harm any part and step by step only it can be found.
If you have insurance for your TV and other appliances, you can claim.
Better contact the authorised service provider for assitance.
Aug 27, 2010 | Zenith DVB712
Read the internal disk
I don't understand how your router crashing and your files on disk are connected.
The internal disk will not be affected by the router. There will be another reason for this.
Check that your master and slave jumper settings are correct. The main bootable disk should be master, and the secondary disk slave. Ensure that you're using the correct IDE lead (master black, slave grey). Alternatively use CableSelect.
Feb 28, 2010 | ASUS WL-700gE Router
Hoow do you open gateway MX6440. No audio. Bootup
Typically, a computer tries to "boot" from several devices:
1. 3.5-inch diskette
2. internal CD-ROM
3. internal disk-drive
4. USB memory-stick
5. network (if a "boot-server" can be found on the network)
6. external diskette
7. external CD-ROM
8. external disk-drive
So, in your case, either
* the "boot-order" _EXCLUDES_ your disk-drive,
* your disk-drive is not connected,
* your disk-drive is connected, but is "dead" (not responding)
Not being able to boot from the disk-drive, your computer probes, via the network, for a "boot-server". Finding none, your computer reports, in a strange way, that "network cable is not connected to a boot-server".
So, the "check cable" means that the Ethernet cable between the network-port on your computer and the boot-server may be "unconnected".
What this could mean is that your disk-drive is "dead".
Take the computer to a qualified technician, for more trouble-shooting.
Nov 18, 2009 | Gateway MX6440 (6585) PC Notebook
Compaq 701tu cd drive does not spin
check if the green light comes on when you insert a disk,if no?
1. switch off the pc,
2. open the case cover
3. check the power cable is connected to the device"compaq 701tu cd drive"
4. if still not working
5.try other cd device and if that work,it means your compaq 701tu cd drive is faulty and to be replace.
Jul 31, 2009 | Sony CDU 701 (CDU701-10) Internal 32x...
Sony Mavica FD75 shows NO DISK when disk has been inserted
The floppy driver has an internal switch that detects when the floppy disk is protected or not.
It is likely such switch is damaged.
It is necessary to open the camera and the floppy drive to fix it.
If you have experience and skills in fixing electronic devices, or want to try it, then you can try its repair.
The alternative is to pay to have repaired, but is more likely that the quote you will receive is to replace the whole floppy drive, which costs around $40.00 plus the repair labor.
Regards,
Jan 21, 2009 | Sony Mavica MVC-FD75 Digital Camera
Ffh k juu cgh kmll ioiui
Is this English or your own language????? I only understand English.....
Nov 12, 2008 | Office Equipment & Supplies
WHITE SCREEN
change the flex cable and that should take care of the problem
Dec 11, 2007 | Samsung SGH-t629 Cellular Phone
iLO (2 GB) MP3 Player Logo
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Allen Benge
Level 1 Expert
Jon Piercy
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
