Question about Philips DVP-3005 DVD Player
No video, only audio
My Philips DVD player does not show any video output. But the audio output is working fine. Also when I plug in the the video out cable to the progressive video out port, the video shows up in TV although in black and white format.
Any pointers ?
Regards,
Hiten
  • nikunj Jan 18, 2008
    i have the same problem. but i know there is problem in dvd main processor i.c. but its cost is very high. but i also do not know this i.c. number. if any one know mail me on nikunj_it007 @yahoo.com
  • 70 Answers
With the first problem i would check the Scart lead to make sure both ends are pushed all the way in, if the lead is in at an angle that can cause loss of colour or picture, and that none of the pins are bent. Failing that try another Scart lead.
Most DVD players need to have progressive scan enabled in the settings menu, are you using a HDMI lead or Video Composite, (5 phono plugs)? HDMI is the better of the two!
Posted on Feb 17, 2008
Philips slc4
Check to make sure your Video and Audio are plugged into the same source input on your TV and the Output on your DVD player. (Ex. Audio/Video input 1) You could have your audio on 1 and your video on 2
Sep 01, 2014 | Televison & Video
Philips hts 3265
hi,lg lh d6230a home theater player display show the dvd error but not opening cd room .why this wrong please help me.send me reply
Jan 15, 2014 | Audio Players & Recorders
Hello, I recently bought an Onkyo HT-S9300 home theater system. I am trying to get it to work with my DVD player using optical cable for the sound, since the DVD player does not have HDMI output, but I...
In your DVD player audio setup change the digital output to bitstream. You have not mentioned which DVD player you are using.
Some players it will be given
Digital Out - Off/ On select On
Dolby Digital - Dolby / PCM select Dolby
DTS - On/Off select ON
Jun 19, 2011 | Audio Players & Recorders
Trying to connect my magnavox with the TV. I can hear the audio, but I can't see the video. The DVD side works fine.
See if the output on the back that you have it connected to is only for the dvd..there may be another on that puts video out no matter what is playing
Dec 27, 2010 | Philips Magnavox DVD/VCR Dual Player
Can you put a phillips dvdr610 onto a television with built in freeview and then record from it. If so how?
If your TV has an OUTPUT MONITOR Output Jacks, Yellow, (Video) Red (Audio) & White (Audio) FEMALE RCA Jacks.Then these will output WHATEVER is showing on the TV screen. And can be used as an Output for any Recording Viewing device. There will be other, FEMALE RCA Jacks,AV, Yellow, (Video) Red (Audio) & White (Audio) and possibly also The Composite Video, Red, Green, Blue, all Video, These are INPUTS, they will be there also. Make sure.
Feb 16, 2010 | Philips DVDR610 DVD Recorder
Karaoke not working
Hi, got this info from philips customer service. Was desperately trying to get the karaoke function to work for 2 weeks! Plug in your microphone. Press "KARAOKE" button until you see "MIC OFF" text, and immediately press RIGHT button. It will now shows "MIC ON"! "ECHO", "KEY" options will now shows up when pressing "KARAOKE" button repeatedly. However, microphone sound will not be available on digital output, you'll have to use the audio RCA. Happy singing!
Dec 31, 2009 | Philips Televison & Video
Setting up mintek 100 dvd player to cable box to tv
Newer TVs have multiple inputs. Mr Mark is correct, you generally do not daisy-chain Audio/Video units unless you are using a recording device. Cable box to Cable input on TV. DVD player to other inputs.
Let's get some terminology out of the way. Specifically for the Mintek DVD-1600. There are NO inputs.
Coaxial Audio out (orange) is for digital audio only. Usually connects to stereo reciever for Dolby 5.1 surround sound. Not for TV.
S-Video (black w/4 small holes, 1 square) is for better quality video than composite. Use this to TV instead of Composite if you have a S-Video input on your TV.
Composite (Yellow) Older video input type. Works just fine. Connect to TV.
Audio Output ( Red & White) for analog stereo only. Goes to TV. Red=right, White=left channels.
Component Video Out (Blue, Green White) is the newest video output type in this unit. Better than S-Video. Use this option if available on your TV instead of S-Video or component.
Feb 13, 2009 | Mintek DVD-1600 DVD Player
I have a philips DVD home theatre system HTS8100. Its fine except that NO dvds play in synch. I have checked them on my normal DVD player & they are fine. The synch button on the remote sometimes fixes...
Synch problems on Philips machines can be caused by the video output setting.
Usually there are 3 options for video output:
  • PAL
  • NTSC
  • AUTO
PAL & NTSC force playback in that setting, regardless of DVD format, and sometimes cause a time delay in the conversion.
Try changing this option to AUTO. IF you have a modern TV, it should allow both PAL & NTSC playback.
May 12, 2008 | Televison & Video
DVP642 DVD Player is only working in Audio mode
Mine does the same. Cannot get a picture using the Yellow RCA output. Use an S-video cable if you can - it should still work. If you get a black and white picture using the S-video output, go to MENU > VIDEO page and change the output from PyBywhateveritis to S-video and the color will come back. I only found out mine was broken when I needed to use the s-video cable for something else and tried switching to the Composite Video (RCA) to no avail no matter how many cables or TV inputs I tried.
Mar 15, 2008 | Philips DVP642 DVD Player
Dvp 320 no composite video output
CHEEK THE VIDEO SECTION.AND JACK. LATTER OUTPUT DC VOLTAGE FOR VIDEO PORTION.BUT NOT SLOVE THE PROBLEM. SO THE VIDEO CHIP AND CHANGE.
Jan 14, 2008 | Philips DVP320 DVD Player
Philips DVP-3005 DVD Player Logo
117 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
