Question about Belkin (F5D72304F5D7000) Router
Connection cant be established.
My router was workingfine for a couple weeks an now all of a sudden my psp tells me theres been and error and to check the security settings for the network. Not sure what it wants me to do. Any help?
  • 193 Answers
Might be teh router fire wall block the connection between the play station-2 to the router so login to ur router inter face and disable the fire wall>and enable DMZ for teh ip address of ur PS2 u can serch for the ip address in teh DHCP client table what ip is assigned to teh PS2 and enable teh DMZ for teh particular ip address and reboot the router and PS2 then check it will work rate me solved if its helps thx
Posted on Nov 27, 2007
My psp keeps saying that a connection error has occured and that the connection to the accespoint timed out. what do i do?
Most likely this is a security issue. Be sure that you are inputting the router password in correctly and are choosing the correct security. If you believe you are and still can't get connected, try logging into the administration console on the router and disabling the security password and try connecting with your PSP again. If it works, it's definitely an issue with the security on your PSP.
If it still doesn't work then the problem lies elsewhere. Is Mac filtering enabled on the router per chance? You may have to call Sony support at 1800mysony for help. When you call tell them that you have already explored the router security avenue because that will be the first thing they have you try.
I hope this helps! If this did help you, please give a thumbs up!
Thank you for choosing FixYa!
Jul 08, 2011 | Sony PlayStation Portable (PSP) Console
I have a PSP 1001 and i can't find the error code 80410E80 whut dose it mean and why cant i connect to my wierless router witch is 2 feet away from me and the psp keeps timing out after a min or two...
Sounds like there is something going on with the security key which is usually WEP or WPA and the psp may not be accepting it. Make sure on your wireless router that you don't have a key enabled on it. Best best on most routers. Hold down the reset button for 30 seconds and let go, this will reset your router to factory defaults.
Now that your router has no security on it. Try connecting the PSP to the router again. If it connects then you know the security key was corrupt. Now you can go ahead and put the security key back in. Make sure your PSP is configured to use the key so it can connect.
May 29, 2011 | Sony PlayStation Portable (PSP) Console
Sony psp error code 80410418
The error is caused of wrong setting on your psp. You need to know the settings stored on your router so that you will be able to connect you psp to the internet. I've listed the steps on how to get the information on your router and Connecting your psp to the internet.
How to access the Router:
1. You need to know the ipaddress of your router. You can refer to the manual or check the Default Gateway of your computer (Make sure that you connect the computer to the router using an ethernet cable for you to get the Default Gateway). Click on START then RUN. Type CMD on the small box on the lower left of the screen. Type IPCONFIG on the black window and get the value of your DEFAULT GATEWAY (it starts with 192.168.x.x)
2. Open a Browser, Type the DEFAULT GATEWAY on the address bar of your Browser. It will ask you for a username and password. (Refer to the manual of your router or post a reply so that i can provide you the username and password of your router)
3. Go to the Wireless Settings Page of your router. Look for the SSID or the Network Name and the Network Key or Passphrase. You can personalize it so that you can easily remeber the details.
4. Make sure you connect to your SSID and enter the Network Key to make it secure.
How to connect your PSP
1. Open Psp
2. Go to Network Settings
3. Go to Infrastructure Mode
4. New Connection (then select available connection)
5. Under Wlan Setting choose Enter Manually or Scan your SSID
6. SSID (Select your SSID)
7. Wlan Security Setting (WEP/WPA/WPA2)
8. Enter you Network Key
9. Test Connection Settings
and lastly Rate me if this helps so i can help others.
Thanks for using Fixya.
Jan 31, 2011 | Sony PSP (Piano Black)
I have a new psp 3000. I can't get internet access. It finds the SSID, good reception=75%. WLAN on, but its saying "a connection error occurred. Connection point could not be established. Check...
Hi stagedoorste,
You may notice that sometimes connecting your PSP to your network seems like a hard thing to do. But if you're aware of the basic configuration you can say that it's not a complicated thing. If your experiencing hard time connecting to the internet please make sure to check on the error. Based on what you have mentioned it says that you need to check the security setting. You may try following the steps below for the basic configuration on how to connect your PSP to your router.
1. First step is to make sure to turn on your PSP as well as the wireless/WLAN switch. 2. Then Navigate to " Network Setting". 3. Select "Infrastructure Mode". 4. Now Select "New Connection" and Name this connection as you deem appropriate. 5. Navigate to "WLAN Settings" Select "Scan". 6. Your router should now be listed. 7. Please go to "WLAN Security Setting". If you did not select encryption in ROUTER SET-UP, then leave the option as "None" 8. But if you selected encryption in ROUTER SET-UP, then select the appropriate WEP, or WPA. 9. Then navigate to "Address Settings". Select "Easy" 10. Go to "Setting List". Verify that your settings are correct. 11. Navigate to the next screen and press X to save your settings. You should get a message that says "Save Completed. Test Connection". Press X. 12. You should get two quick display messages. The first should say "connecting to access point." The next should say "obtaining IP address".
From this point you already established a connection and using your PSP you can now browse the net.
Hope this information will be helpful.
Thank you for using FixYa.
Jan 09, 2011 | Sony PlayStation Portable (PSP) Slim...
My psp won't connect to the internet. it says, a commection error has occured. a connection to the access point could not be established. check the security settings for the network and try again.
First of all check if your wireless router requires (WEP KEY) to establish a connection then you will have to put same (WEP KEY) in PSP WLAN security setting and if your wireless router is set without (WEP KEY) then in PSP WLAN security setting it should be set to None. kindly refer to the following image.3782ff8.png
Oct 20, 2010 | Sony PlayStation Portable (PSP) Console
Cant connect my ps3 psp go to the internet using
Check to see if your router has backwards compatibility to wireless G because the N router uses 256bit encryption coding while the G uses 128 bit encoding. PS3,and PSP use the 128 encryption coding also. If the router does not support 128 bit encoding you will never connect with it.
Nov 22, 2009 | Sony Playstation 3 (PS3) Console
When i go online it wont let me
Check your connection strength and it has to be 30%or more to work.
Nov 14, 2009 | Rainbow Six Vegas for PSP
Can't connect to the internet
you need to go into your routers settings and lower the security settings, with things like PSP's and DS's you need to have a lower access the wi-fi
May 28, 2009 | Sony PSP (Piano Black)
IP adress dosent work.
You need to match the security settings on the Wifi router. I do not know what security is set up on your Wifi, so I cannot accurately solve this problem. I have my router set to WEP with a passcode. On the PSP, I tell the network setup that the wifi is WEP and put in a passcode to match the Wifi routers security. If you have the passcode wrong, the IP address part will fail. Just find out the security type and passcode, then set up the PSP's network connection to match.
Dec 30, 2008 | Sony PlayStation Portable (PSP) Console
Belkin (F5D72304F5D7000) Router Logo
64 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
