Apr 23, 2002 - Mine takes 6 including 1 for the filter. This is what everything I've read says too. -------------- [font color="green"]1995 F-150 Supercab XLT ...
CarGurusJun 6, 2009 - 06 ford Ranger 4.0L v6- how much oil does it take? ... 3.75 qts if manual, 5.5 gal antifreeze capacity, 2.2 qt capacity in front and rear differential, ...Missing: 300 6cid
It is very important to change the filter in the pan, at the valve body, even if you have an inline magnetic filter for the ATF and I will tell you why.
My transmission mechanic Gaby, at Jul's Transmission in Hollywood, Ca. showed me last week a 2005 Ford Expedition 4wd automatic transmission's pan filter that was completely plugged/blocked, where the owner had installed an aftermarket drain plug in the transmission oil pan so that he could do regular ATF fluid changes to keep his transmission running longer.
He did not drop the transmission pan and change the filter inside at anytime. All he did was kill his ******* sooner by having a plugged up pan filter and the valve body was heavily layered in wear materials from the transmission.... His transmission crapped out at 38,000 miles. His FORD dealer had warned him that prior to installing the drain plug in his transmission oil pan, that his warranty was void on the transmission if he did that.
You're absolutely right about keeping ATF fluid clean and that inline magnetic filter for the transmission from BOSS products sounds like a great idea! I am planning to check it out and install one on my newly rebuilt 4R55E 2wd transmission. Thanks for the tip! :-)
Change the ATF fluid and pan filter and put on a new pan gasket once a year/12,000 miles. If you have a 4x4 (4WD) and do alot of offroading or if you do a lot of towing with your 4x2 (2WD) you should check your ATF even sooner and change as necessary due to it being burned or a high content of worn materials (friction material, metal, etc.) suspended in the ATF oil.
The filter in the pan mounts right at the valve body and also there is a magnet in the pan itself. That is another reason to once a year (or as driving conditions warrant) drop the pan and change the filter and clean the pan magnet.
Should be directly below the engine at the oil drain pan. It should be a larger drain bolt that screws into the oil drain pan.
The transmission pan may be next to it but won't have a drain plug. The transmission fluid pan has several small bolts that hold it on and the whole pan has to be dropped to change that fluid.
Good luck on finding hte oil drain plug for the 2003 Buick LeSabre.
buy a tube of sealer called Right Stuff
1. Remove the flexible exhaust pipe
2. Disconnect the downstream catalyst monitor sendor (OXYGEN SENSOR)
3. Drain engine oil
4. Remove the 15 bolts and the oil pan
5. Clean pan & surface area.
6. Apply sealer 10mm (0.40 inch) diameter of sealer
7. Position oil pan and hand-tighten the oil pan bolts
8. Start with front of oil pan tighten each bolts going around oil pan till all are tighten up.
9. Install exhaust flexible exhaust pipe
10. Connect OXYGEN SENSOR connector
11. Lower the vehicle.
12. Fill oil 5w20 (Spec)
drain out hte old oil, Remove oil pan bolts, remove old oil pan gasket, install new gasket, install oil pan, tighten oil pan bolts to 17 ft. lbs. DO NOT OVER TIGHTEN as this will distort the gasket and cause another leak.
It only has 1 oil pan which is call a dual resreve. One oil plug is a the bottom of the pan the other is at the front of the oil pan. Look at the front of the oil pan for the other drain plug. Make sure on how many quarts of oil it takes. ( I know 5.0 take 5 quarts including oil filter. But then again its a van double check)
I can't imagine what 'inline' oil filter should be; your engine is an 'inline 6' though.
This term applies to any engine that is not in a 'V' configuration.
Here is a quote I found while trying to find an illustration:
"It's a pain on the 02 4.3L . The damn thing is right next to the oil pan. It's probably half inch off the pan. Sometimes i wonder who design that idea."
