Hi
the best way to hook up the printer is to put the cd first and follow the steps.
If something has gone wrong ,do not worry .
there are some of the things we can check to make sure that the printer is properly configured on the computer.
1>goto start->run->(type there) devmgmt.msc
thsi should bring the device manager
in the device manager check the printer entries,and also the universal serial bus entries at the bottom.
if they have any yellow exclamation mark showing a fault.
youmay update the drivers by right clicking the entry and choosing the update drivers option.
this wil bringthe wizard and then you need to browse to get the exact location of the drivers ,which should be located on the cd
Thanks and regards
Techbuddy247
Please follow the following steps.
1) Turn off the printer.
2) Shutdown the PC to which the printer is connected.
3) Remove the USB/Serial cable through which the printer is
connected to the PC and reconnect it back.
4) Now switch ON the PC(only PC and not the printer)
5) Let the PC boot up and login to windows.
6) Now switch on the printer, PC should detect the printer
automatically now.
Now you will be able to print.If not then follow the following steps.
Please be informed that any
Printer Driver software depends upon the hardware make and Operating System.
You need to know all these information's to do get going.
Please find the Driver software's of your printer inside the installation disk
provided with the Printer at the time of purchase. As you have not mentioned
your Printer make I am unable to give you the direct download link. However you
can download the same by visiting the website of the company that manufactured
the Printer.
Even here you need to be careful
to download the correct software for your PC. You need to be exact with the
Printer Model number and the OS that you are using.
To install just Double clock on
the driver setup.exe file and go on clicking 'Next' until you get the 'Finish'
option and restart the PC.
If you feel that my answers have helped you getting
solution to your problems then please give a vote for best answer.
Thanks.
Check your printer in the Control panel if it is ONLINE.
