Question about Toshiba 55H70 55" Rear Projection Television
I have a Toshiba 50D9UXA rear projection
I have read the convergence problems others are having it seems their problems are with the red my problem is with Blue it wont blend into the cross hairs is it tha same fix as with the red? or is Blue worse? thanks for any help
  • TIM777 Nov 27, 2007
    my with red
  • 934 Answers
Same problem - - needs convergence amps replaced and low ohm resistors tested for change in value.
Posted on Nov 27, 2007
I have a toshiba tv model tp50g90 I have replaced the convergence chips stk392-110 convergence was corrected but I have a problem yet red not managed to focus on the user menu in the option of...
Thats the way it works. You have to adjust the other colors to the red. You adjust the red from the back of the set using the convergence magnets on the tubes. Then you adjust the other colors to match the red. It's much easier if you have the plastic screen from Toshiba used to align this set.
Feb 20, 2011 | Toshiba TP50G90 50" Rear Projection...
57HX81 projection tv,color is mostly red and picture is double.
This is a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$300
Sep 28, 2009 | Toshiba 57H81 57" Rear Projection...
Toshiba 42wh46p convergence problem
Yes Replace Both STKs also CK all low ohm resistors.
Feb 15, 2009 | Toshiba 50H82 50" Rear Projection...
Convvergence problem w/ Toshiba 50H82
You need to replace following ICs, may be 2 pieces in your tv for convergence problem.
IC, STK392-110T
Toshiba Part Number: 23135090X
Please search on net for availability in part stores
Sep 27, 2008 | Toshiba 50H82 50" Rear Projection...
Convergence problem???
Check the resistors by the STK ic's, should be 2.2 ohms. Under the heat sink, also check the 1.8 Ohm 1W, fusible resistors found around the area as well.
Good Luck.
Feb 05, 2008 | Toshiba 50H72 50" Rear Projection...
Still can't get into the convergence mennu
You may need the original remote. This is normaly needed to access this menu
Jan 24, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
Toshiba 65NH84
You might have burned out the red color crt. In projection TV's there are 3 CRT's (one for blue one for red, and one for green). If you have the other 2 colors but no red I would assume this is your problem. You should be able to get it fixed for around $150.
Jan 13, 2008 | Toshiba 65HX81 65" Rear Projection...
Convergence problem- right side red out?
As long a the picture is not bowed you may have a convergence module bad or have to enter convergence service menu to adjust If bowed at all the convergence ic's are bad or just a resistor in the convergence circuit is out of its value. These are possibilities but it still could be the ic's
Jan 02, 2008 | Toshiba 40H80 40" Rear Projection...
Nov 23, 2007 | Toshiba 50H72 50" Rear Projection...
Toshiba 55H70 55" Rear Projection Television Logo
169 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
