Question about Bosch Kitchen Ranges
My HEI7282C Bosch range is 50F below temp (i.e. when set to 350, actually 300). I can compensate for 25 degrees through the control panel, but that's the limit. What component might be defective?
SOURCE:
catriver
  • 878 Answers
SOURCE: Digital Control (for oven temp and clock adjustment) not working
Puzzeled, usually when there is a stuck or shorted keypad there will be an error code. First let's see if we can tell if we are in Centigrade or Ferenhiet. Press the bake and broil button together for 2 or 3 seconds. SF should appear in the display. Press the broil pad again and C or F will be displayed. Toggle to F and press start. See if that was the problem. If not try to increase the speed of the + and - keypads. Press bake and broil together for 2 seconds until SF displays. Press the + keypad increase the speed of the control. It should toggle from 1 to 5, 5 being the fastest. Press start and see if that works. If niether works..then have someone remove the keypad ribbon cable from the control board and clean the ends with an eraser. See if that solves the issue...Catriver..post back and let me know.
Posted on May 12, 2007
philbran
  • 242 Answers
SOURCE: Oven won't reach proper temperature and hold
If the element glows its ok , if you have replaced the sensor with a new one it can only be the control board. in some cases you can adjust the temp. through the control , it should list directions to do so in the manual. Good luck
Posted on Dec 30, 2008
SOURCE: Whirlpool Electronic Gas Range temperature adjustment?
I found the answer on another website.
Posted on Feb 07, 2009
milten1
  • 1304 Answers
SOURCE: We have a digital controll that is not accurate on
on most modesl this is called a clibration adjustment
most have a code that you can enter into the erc
if you still have your book, it is in the directions
most work this way
push and hold bake for 5 sec
you should get a double 00
then use the up arrows to adjust the temp
if this does not work send me the model number
ill send you the directions
Posted on Oct 27, 2009
BarrettDenCo
  • 1772 Answers
SOURCE: I have a Maytag Gemini
Sorry to read about your problem, I hope this helps you out.
OVEN TEMPERATURE ADJUSTMENT
If you think the oven is operating too cold or hot, you can adjust it. Bake several test items and then adjust the temperature set- ting not more than 10° F at a time.
To Adjust: 1. PresstheBAKEpad(upperorlower
oven) and enter 550° F.
2. PressandholdtheBAKEpad(upperor lower oven) for several seconds until TEMP ADJ is displayed.
3. PresstheAUTOSETpad-eachpress changesthetemperatureby5°F. The control will accept changes from -35° to +35° F.
4. Iftheovenwaspreviouslyadjusted,the change will be displayed. For example, if the oven temperature was reduced by 15° F, the display will show -15° F.
5. When you have made the adjustment, press the CANCEL pad and the time of day will reappear in the display. The oven will now bake at the adjusted temperature.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Posted on Dec 24, 2010
Oven temp fluctuates
It is normal for the thermal device to turn on and off. Obtaining a steady temp is not always possible. When setting a temperature on some ovens, they have what is called a tolerance point. That means a set temperature has a range of a few degrees up or down. At the Down point, the oven is triggered to energize the coils and bring the interior of the oven back to the settings desired. The other factor is opening the oven and allowing cool air to enter, or in some cases a leaking door seal allows air to enter and heat to escape.
Feb 26, 2014 | Kenmore 30" Slide-In Electric Range...
I have a frigidaire stove that heats to 50 degrees hotter than the know setting. Can it be adjusted to read correctly?
There is a calibration method to adjust the oven thermostat plus/minus 35 degrees if it is a digital display. The method varies depending on the model range. This calibration method is used to adjust the thermostat if it is not keeping proper tempature. For example if you are setting the oven to 350 and the actual temp it is keeping is 325 then you could use the calibration method to adjust it plus 25 degrees to correct the temp. Just so you know electric ovens will keep a pretty even temp but gas ovens will vary by 40 or more degrees to keep an "average" temp. For example the burner will come on when the oven is 330 degrees and turn off at 370. 330+370 then divide by 2=350. So a oven thermometer may not show you the temp you set it at in a gas oven but does not mean the oven temp is off.
Jan 14, 2010 | Ovens
My GE Profile Spectra oven is taking approximately 10-15 minutes to preheat to 350 degrees and does not seem to fully bake food as per instructions. It takes an extra 5 to 20 minutes to bake anything. ...
18 mins from room temp to 350 is factory standard,
you may need to calibrate the range, most now adays come factory set at -25 degrees for safety
depending on your model number in your instruction manuel should be a part about recalibrating it sounds like your about 25 degrees off
Oct 02, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Does not hold oven temperature
I have the same problem. I had a repairman come out and they told me it was the control panel and thermo sensor. Replaced both and still didn't fix the problem! Can't return the parts and now into the stove for over $370! I wish I had put that money towards a new stove :-(
Mar 29, 2009 | LG LRE30453ST (Electric) Stainless Steel...
Dec 30, 2008 | Kenmore 91112 / 91114 / 91117 Electric...
Whirlpool sf368leps
can hold down bake the and adjustment comes up can adjust in 10 degree steps 30 degree up and 30 degree down use the temp up and down to make the adjustments
Dec 22, 2008 | Whirlpool SF368LEPS Stainless Steel Gas...
Wall oven too hot,at 350 setting is almost 400 degrees burns food
I have a very old GE wall mount oven. Original to around 1960. You can take the temp control knob off and there is an adjustment on the back of it. Easy peasy and only need a screwdriver.
Dec 05, 2008 | Frigidaire Kitchen Ranges
Oven temp set at 350. only heated to 310 after 1 hour! Set to 390 before reached 350. What to do?
Use an oven thermometer Try to figure out if by setting it to 390 it will maintain 350 accurately. (A 25 degree change while it cycles is normal. It will probably overshoot before going off and undershoot a little before cycling on.) If so the thermostat has just drifted. Pull off the control know and look usually there is an adjustment on the shaft to change the temp showing on the knob. set it up 50 degrees. If the knob can't be changed just know that you have to adjust yourself. If it won't maintain a steady temp the thermostat is bad and will need to be replaced. The thermostat will be over $100 it may not be worth it. If this is a computer controled unit (pushbutton temp selection) the sensor needs to be replaced. This is a lot cheaper than a thermostat.
Jul 03, 2008 | KitchenAid Kitchen Ranges
Incorrect temperature in oven
the computer needed replacement. i just purchased another range instead.
Mar 27, 2008 | Amana ACS3350AS Gas Kitchen Range
Kitchen Ranges Logo
Top Bosch Kitchen Ranges Experts
William Miller
William Miller
Marvin
Marvin
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
