Question about Frigidaire GLMB209D Microwave Oven
Where is the fuse?
My Frigidaire Microwave oven doesn't heat, but everything else works fine. I want to check the fuse. Where do I find it? Thanks.
  • 2 more comments
  • EricG Dec 10, 2007
    I've read that some microwaves have a separate fuse for the magnetron. I knew that if there was just one fuse that everything would be off.
  • Anonymous Apr 07, 2009
  • Anonymous Mar 19, 2014
    Changed fused but it still doesn't turn on checked the wires and everything seems fine
    Everything is working right on my 700 watt Hamilton Beach counter top microwave. Panel works fine ,beeper at end works fine ,timer works fine. Just will not heat.
  • Frigidaire Master
  • 9,098 Answers
It won't be the fuse. If the fuse were out, it would be completely dead.
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya:
You can usually find helpful exploded view diagrams and order parts by entering your full model number here:
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Nov 28, 2007
Fuse location
Good Afternoon Friend, that's a great question!
Depending on the model of your Frigidaire microwave, the fuses are typically on located behind the control console, on the magnetron or on the oven capacity. However, if your microwave does not heat, you may possibly have a faulty control panel, magnetron, or experiencing an issue with the power supply. Please confirm that your microwave is plug into its own outlet and that you are not using a GFI outlet. Hope this helps! - Z
Sep 01, 2014 | Frigidaire FGMV174KF Microwave Ovens
Frigidaire microwave plate won't turn
The motor for the rotator is bad. It has to be replaced.
May 06, 2013 | Frigidaire Microwave Ovens
Maytag microwave problem everything seemingly works but does not heat. Help
see this causes and fix it. God bless you
Diode The high voltage diode converts the A/C power output of the transformer to D/C, doubling the voltage to nearly 5,000 volts. This high voltage powers the magnetron which emits the energy that cooks the food. If the diode burns out, a lower A/C voltage reaches the magnetron, which is not sufficient to power the magnetron. When the diode fails it is often visibly burned out. If it appears to be good, it can be tested with a volt-Ohm meter capable of testing diodes. High voltage diodes frequently fail and are one of the most common points of failure in a microwave oven.
Door Switch If the microwave does not heat, one of the door switches might be defective. Microwave ovens normally have three door switches, if any of them fail the microwave does not turn on and does not heat. Check the switches for continuity with an Ohm meter.
Magnetron If the microwave oven doesn't heat the magnetron tube might have burned out. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. If the microwave oven is turned on when it is empty this can cause the magnetron to burn out. Once it is burned out it has to be replaced, it's not repairable.
High Voltage Capacitor If the microwave doesn't heat the high voltage capacitor might be defective. The high voltage capacitor works with the high voltage diode to convert the output of the transformer to DC voltage and to double the output voltage. If the capacitor is burned out the entire high voltage circuit stops working properly. The high voltage capacitor can be checked with a special VOM meter which has a capacitance testing capability. Be aware that the high voltage capacitor can retain a charge of more than 3,000 volts and can injure or kill a person if not handled properly. Only trained technicians should perform this type of testing.
High Voltage Transformer If the microwave does not heat, the high voltage transformer might be burned out. Microwave ovens produce a very high voltage in order to power the magnetron antenna, which emits the energy that cooks the food.
Thermal Fuse If the microwave doesn't heat the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Thermoprotector If the microwave doesn't heat the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Main Control Board If the microwave doesn't heat the main control board may be defective. This is not common. When a microwave doesn't heat the problem is usually within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
Oct 01, 2012 | Maytag MMV4205 Microwave Oven
Replaced 20amp fuse that was blown. new fuse did not blow, but oven is still dead.
If your microwave oven doesn't seem to work at all, check these: Fuses Door switch Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it. Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work
Sep 22, 2012 | Cuisinart CMW-100 Microwave Oven
Oven not working. Replaced an element, but oven will not heat up. The stovetop works fine, but the oven does not heat up.
check the continuity or resistance.
Now if its zero reading try to check your termination and also check the fuse or thermal cut out or thermal overload if it is busted or burn try to used also your tester.
But if there a resistances try to reset.
Mar 04, 2011 | Frigidaire FMV156DC Microwave Oven
Microwave stopped heating up the food. Everything works except for the heating mechanism.
Check the door safety interlock switches. Remove the cover to find these small micro switches on the side away from the hinges.
Need more help ... post a comment here
thanks for using
Nov 02, 2009 | Frigidaire PLMV169DC Microwave Oven
Does everything but heat food.
Sounds like the magnatron tube or it's fuse.
Aug 11, 2009 | Kenmore 80809 Microwave Oven
Frigidaire Professional series microwave won't heat
The most likely problem is the magnetron. Check your warranty in owners manual, I believe you have five year warranty on magnetron.
Mar 15, 2009 | Frigidaire FMV156DC Microwave Oven
Appears normal
ya this is the same problem i too had...everything will seem to right but the part required for heating might be damaged internally...try changing i did the same...
Sep 19, 2008 | Frigidaire GLMV168K Microwave Oven
Frigidaire GLMB209D Microwave Oven Logo
287 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
