Question about NetGear WGT624 Wireless Router
Netgear 108 Mbps Router WGT624 v3
The WGT624 worked well with a Netgear WG111T Wireless USB Adapter until a few weeks ago when it said: "Cannot connect." Now, if I plug cables directly from the modem to router to computer, I can connect. But the wireless connection from the router to the adapter does not work any more.
Can you help please. Constantin
How can i get the network key for my netgear router wgt624 v3?
Posted on Feb 23, 2008
  • 173 Answers
As you say that, you are able to go online with the modem, connect your modem- router and laptop witha cable and check if you are able to go online with the router wired first, if yes, then the w/ls settings has to be your w/ls network connection, remove your preferred wireless network and then try to reconnect again and check.. if you are not able to gon online wired with the router, disconnect power cables from modem- router , wait for 10 sec, and reconnect it , wait till all the lights come up and then reconnect, check if you are able to go online if not your router has to be reconfigured,,
plz check and revert back in case of any issues
Posted on Nov 28, 2007
Netgear wireless adapter wg111t will not work work
It's impossible that the wireless router cannot detect your wireless adapter wg111t.
You try to test another one if still have a problem connecting with your wireless router.
If that router can see another wireless network available then maybe your Netgear wireless adapter have a problem incomplete installation or the wireless device is defective.
I have encounter like this before so maybe it's the same with.
Hope my tip will help you a lot.
Please rate me.
Thank you.
Sep 14, 2009 | NetGear WG111T 108 Mbps 802.11g Wireless...
My computer freezes when connecting WIFI adapter
Does this happen if you try connecting it into all USB ports? Try another USB port. Do you know if your USB ports are 2.0?
Mar 30, 2009 | NetGear WG111T 108 Mbps 802.11g Wireless...
About 108 mbps wireless router wgt624 netgear
Jan 23, 2009 | NetGear CG814M Wireless Cable Modem...
I have a wireless netgear usb adapter and nothing else, its not installed on my computer and I want to put it on, it wont work, what do i need to get my usb wireless adapter to work??? It is a wg111t...
You first need to install the driver. You can download it here: (it should have came with your adaptor)
You must also have a wireless router available for this to work, or in an area that has WiFi available.
Jul 17, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
NETGEAR WG111T 108 MBPS WIRELESS USB 2.0 ADAPTER stopped working
What are you trying to connect your USB wireless device to?
Is it to a wireless hot spot?
or to a Wireless Access Point/Router?
When you find a connection, what is the signal strength?
I assume you have configured your Access Point correctly as well as making it secure. You should connect a computer to the Access Point using a network 10BaseT cable to check the Access Point configuration, especially the wireless configuration.
If you are trying to connect to a wireless Access Point and you have a weak signal, move your computer closer to the Access Point or move the Access Point to a better and higher location to give you a better wireless coverage. Note, walls can affect the wireless signals between the Access Point and the wireless network card and wireless USB device, especially reinforced concrete walls.
Jun 01, 2008 | Computers & Internet
Netgear 108 Mbps wireless usb 2.0 adapter wg111t
i had the same problem. i tryed downloading the sofware from other computer and install it on the wireless computer. finally i just connected it directly to a lan line and update drivers with windows
Apr 08, 2008 | NetGear WG111T 108 Mbps 802.11g Wireless...
Wg111t wire network
run cmd ( windoowsxp) then type ipconfig you should see an address like if not goto network conections and view all goto wireless connection -properties then tcip set for auto config and then ok make sure your router is set for WEP sercurity type in a ten digit hex code ( 28 34 f6 a7 c3) and then save . rescan for your network then log on make sure you have GOOD signal strentgh . the wg111t does not work well with belkin routers.
Dec 25, 2007 | NetGear WG111T 108 Mbps 802.11g Wireless...
Configure router via ethernet cable in first instance. Then install adapter. May need to hange MTU for AOL as ISP.
Oct 08, 2007 | NetGear WG111T 802.11g/b (E82321) Wireless...
NetGear WGT624 Wireless Router Logo
377 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
