Question about Golf
Headlights don't work on 2004 ezgo golf cart but tail lights do I have ohmed out wires and get positive reading... now what?
SOURCE:
SOURCE: I ned a service manual for a 1995 ezgo dcs golf
Our EZ GO golf cart will start and run except you have to hold the choke about half way out for
it to continue to run. What is wrong?
Posted on Apr 20, 2009
  • 10865 Answers
SOURCE: need battery wiring diagram for 1987 ezgo golf cart
Tell me what cart you have and i can help. Not all carts get wired up the same way as this link demonstrates. In the pix pay close attention to how battery one gets hooked up as this sets the pattern
http://www.updateyourdriver.com/driver/?t202id=211793&t202kw=webcam&gclid=COTM4t-ZsJwCFQxM5QodWjoflQ
Posted on Aug 19, 2009
  • 166 Answers
SOURCE: Electric Golf cart only shutters and inches forward
so many possibilities...
does it roll fairly freely? (checking to see if the brakes or rearend seized up)
Are there any "bad" sounds like things grinding? (Connection between Motor and rearend, axle splines...)
If all that is solid, it is likely in the controller.... (it takes a solid charge right... No bad batteries in there or loose connection? might want to check all the battery connections to make sure none are burnt...)
1997.. does it have the electonic speed control by that year? the other possibilty is that the accelerator is not working corectly. they used a resistor system on old ones that has contactors that would get worn out.... Newer ones control a potentiometer(sp) that controlled the speed.
Only a few real components to check, but if you are not mechanically and electically inclined, could be tough to isolate.
peace,
Posted on Mar 07, 2010
  • 34 Answers
SOURCE: I need a wiring diagram for a 1986 ezgo golf cart,
use this link http://www.vintagegolfcartparts.com/cgi-bin/gallery/gallery.cgi?func=show&file=200332&Category=100013&Page=1
Posted on Apr 21, 2010
  • 34 Answers
SOURCE: Rear axle fluid for 1983 ez go electric golf cart?
Regular 90 weight gear oil. Fill until it reaches the fill hole.
Hank, The cart man
Posted on Apr 22, 2010
Looking for wiring diagram for 1999 TXT EZGO golf cart controller?
There are a ton of them available, apparently:
https://www.google.com/search?q=1999+TXT+EZGO+golf+cart+controller&oq=1999+TXT+EZGO+golf+cart+controller&aqs=chrome..69i57.1143j0j4&sourceid=chrome&ie=UTF-8
Aug 02, 2017 | Golf
Wheres the ground go on healights on a ezgo 3 wheeler
Never had a ezgo 3 wheeler to work on before but sounds interesting. If this is an electric cart then wire ground to a negative battery that gives 12 volts from where positive is connected. If gas cart wire to frame or neg post of battery.
Mar 28, 2017 | Golf
How do I connect 36 volt battery charger to electic golf cart?
Maybe you have an Ezgo cart? Black is negative, white is positive, and the small red wire is connected to the white inside the charger receptacle.
Sep 04, 2015 | Golf
I need a service manual for an EzGO TXT
Service manuals are sold by EZGO but expensive. You might download some wiring diagrams from fsip.biz and buggiesgonewild.com.
Aug 13, 2015 | EZGO TXT Golf Cart Golf
Why is the EZgo Charger fault light is on
Have all battery checked
xxxxxxxxxxxxxxxxxxxxxx
Jul 18, 2014 | Dual Pro 36V 25Ah Golf Cart Battery...
Club car brake light not working
2008 precedenmt golf cart dash light keep coming off an on
Mar 02, 2013 | Power Equipment Solutions 2002 Club Car DS...
Golf Logo
Top Golf Experts
FastHarley
FastHarley
ray gallant
ray gallant
Kardoc
Are you a Golf Expert? Answer questions, earn points and help others
