Question about GE Refrigerators
Have a ge profile side by side refrigerator not making ice. is there a reset for this?
    Top Expert:
  • GE Master
  • 51,960 Answers
Failures of this type usually result in replacement of the ice maker assembly.
Posted on Apr 29, 2019
SOURCE:
  • 184 Answers
SOURCE: ice maker will not dispense ice.
ON THE AUGER MOTOR IS A COUPLER THAT SLIDES INTO THE AUGER WHEN THE BIN IS INSTALLED. SOMETIMES, THE COUPLER WILL ROUND OUT THE FLAT SIDE OF THE CENTER HOLE. THIS WILL CAUSE THE MOTOR TO CONTINUE TO TURN, BUT THE COUPLER WILL REMAIN STILL DUE TO THE RESISTANCE OF THE BIN AUGER. ALSO, BE SURE THE ICE IN THE BIN HASN'T MELTED TOGETHER BINDING UP THE AUGER. IF NECESSARY, REMOVE THE ICE AND START OVER WITH FRESH ICE. YOU MAY NEED TO REPLCAE THE COUPLER OR AUGER MOTOR.
Posted on Apr 22, 2008
MNTECH
  • 1543 Answers
SOURCE: GE Profile Fridge Model No. PSC25MSWA SS not making ice
Check to see if there is any obstruction (object of any kind) in the ice cube mold area. If nothing found, you will have to replace the icemaker, as individual repair parts are not available.
Posted on Aug 04, 2009
DeBruce
  • 145 Answers
SOURCE: Can I get a replacement door for my GE Profile Refrigerator
Warners Stellian in Minneapolis can help.
For cleaning DeBruce Polish is the answer.
DeBruce Polish is Odorless, Non-Toxic and non abrasive and perfect on stainless steel, glass cook tops, polished granite marble and more. DeBruce Polish is Odorless, Non-Toxic and Non Abrasive. DeBruce is perfect on stainless steel, glass cook tops, polished granite marble and more. We buy DeBruce at debrucepolish.com.
Posted on Mar 05, 2010
  • 19 Answers
SOURCE: Ice maker in our GE profile refrigerator is not working
Ice maker Diagnostic Test:
- Remove the ice bucket
-Turn the ice maker off, wait 15 seconds than turn it back on
-Press the ice paddle three times, this will begin diagnostic test.
-PLEASE DO NOT TOUCH ICE MAKER DURING DIAGNOSTICS
-In 3 minutes you should see the rack inside turn 360 degrees
-AND the ice maker bowl should fill with water
-IF either DID NOT work, call 1-800-GE-CARES for ice maker replacement. A service call is approx $80. The $80 will be deducted from the part/labor if you choose to purchase/install parts from the service technician. If not, you will pay for the service call. Good luck.
Posted on Apr 05, 2010
imufo2
  • 3773 Answers
SOURCE: GE Profile 25.6 Cu. Ft.
I'm Leo
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Posted on Jul 28, 2011
Profile ice maker stopped making ice
ice maker for ge profile wont' make ice.Unplugged elect supply from both waterin the door coil and ice maker coil.Plugged water in the door elect to ice maker valve coil and pressed water in the door input sw out front and got water to ice maker so this let me know it wasn't the solonoid valve.Got another ice maker unit plugged in and mounted waited several days still no ice.
Sep 27, 2009 | GE Profile PSW26P Stainless Steel Side by...
Aug 04, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Makes ice in bin, but won't dispense ice or water?
is the child lock on that would make the dispensers not work, also is the door closed and not bllocked by anything, if thiese are not the case I would reccommend resetting the unit.
Dec 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile refrig side by side Model GSS 20iEMCC, not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
df
Dec 26, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
My GE Profile makes ice but then the ice cubes melt!
repl main board and make sure your out let is properly wired and grounded those main boards are sensitive when not grounded
Oct 29, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
175 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
R.A. Ellis
R.A. Ellis
