Question about Philips Televison & Video
After removing all three boards from my philips 42" tv why does the tv still smell like something has been burning in it like plastic ?
Possible transformer overheating
SOURCE:
SOURCE: MAGNAVOX TV BURNING SMELL TV WENT POP AND WENT OFF
Well that pop had something to do with the power components inside the TV frying. I would have to say there is nothing you can do to repair it as its dangerous to work on such things.
I wouln't waste my time bringing it to a repair shop they will probably tell you to just buy a new one.
Posted on Jan 05, 2009
pilot210
  • 39 Answers
SOURCE: on one minute then POP loud noise, burning smell
Loud popping and loss of power is common on plasma TVs and is usually either the Y sustain or Z sustain boards or buffers; in these instances the damaged part will be quite evident.
If this is an LCD you might have degraded insulation on one of the pink/blue backlight power leads causing high voltage to 'arc' to the chassis.
The loud bang and smell is actually to your advantage as in these circumstances the damaged part is usually evident. It'll just be a matter of popping the back off and sleuthing around. :)
Posted on May 19, 2009
Maytag317
  • 1136 Answers
SOURCE: Burning plastic smell
Hi, Sounds like something is wrong. Is this a gas or electric oven? Did you have to change settings from natural gas to lp?
Please let me know, I would like to try and help you.
Vic
Posted on May 27, 2009
  • 2337 Answers
SOURCE: 42 inches samsung plasma screen with sound and without image
Check this link to find the LJ41-02759A board for your TV. These boards fails quite often and the TV will power ON but with the same symptoms as yours.
Posted on Jul 15, 2009
SOURCE: Philips 42PF7220A/37 42'' TV (LED flashes red 7 times)
Five buck solution; If you have any tek skills at all and are feeling adventurous; UNPLUG THE POWER, remove the back panel; You will be faced with the mainboard. In the lower right quadrant you will see two small capacitors, like tiny yellowish coke cans. If these are bulging, there lies your problem. These must be replaced. If you have no soldering skills, take only the mainboard to a fixit shop and have them solder in the two capacitors easily found on line. No guarantee's but worth a try
Posted on Dec 14, 2009
I have a philips 42pf55000.switches off ,renove mains ,comes on again ,but no burning smell
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | Philips 42PF5521D 42 in. HD-Ready Plasma...
New lg tv plastic burning smell
I would contact the store you purchased it from,,,explain the issue and go from there...
Sep 20, 2017 | LG 42LG50 42 in. LCD HDTV
No picture and burning smell from left side
Bad COF ic on buffer board. Can usually tell which one's bad. It will look overheated or a hole in top of ic. Look at upper and lower buffer boards to see which ic is bad. Can get from Encompas Parts, Recommended replace y sustain with buffer.
Nov 26, 2011 | SNK Magnavox 42MF231D 42 in. Plasma TV
I bought philips model no. 47pfl7403d/27 in 2008 .Suddenly last month it started skipping picture but we could hear sound.After few days it started smelling like something is burning and it stopped...
Seal deal w/ ours. I took it apart and the power supply board had the burn marks on it. Just ordered another power supply board (pn: 272217100571) for ~ $100. TV back panel comes off fairly easily to get at boards.
Jun 14, 2011 | Philips 47PFL7403D 47 in. LCD TV
I have an older 42" philips tv model 42pf9966/37.
Including a fault description may help you get an answer.
Dec 16, 2017 | Philips Televison & Video
My 42" inch fried something
Ur tv still have picture,just have convergence problems wright?This tv is fixable,the tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.Replaced all these parts on the tv convergence board,will solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Dec 16, 2010 | Mitsubishi WT-42311 42" Rear Projection...
Screen distorted and burning smell
Those dead resistors that the cause,u are smelling burning plastics.Try website Tvrepairworld.com to buy a whole convergence board for the replacement.The Samsung/Akai are using the same convergence board.
Jun 06, 2010 | Akai PT4250A 42" HDTV
Jul 15, 2009 | Philips 42PF7220A 42 in. Plasma Television
Picture focus and color
Your TV set just blew out whats called the convergence IC's. These, both (2 IC's) will need to be replaced, and since you smelled something burning, there are most likely bad resistors as well on this board. You will need also a service manual for sure to do touch-up convergence alighnments. If you do not have any electronic serviceing experieng or any knoledge on repairing printed circuit boards, Play it safe and call in a pro to assist you with this repair. Safety is Number one on the list! Good Luck
Mar 29, 2007 | Philips 60PP9202 60" Rear Projection...
Televison & Video Logo
21 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
