Question about NetGear WGR614 Wireless Router
Netgear wgr614 I have not being able to connect my wireless router because, the cd don't work on my computer and I don't know much about computers so I was looking for a download
    President:
  • 2,961 Answers
Just type 192.168.0.1 into your web browser address bar and then enter admin as the admin and password or admin as the password entry, you will then be able to check the settings without a cd
Posted on Nov 27, 2007
  • andrew pester
    andrew pester Nov 27, 2007
    just to add if your wireless isn't working connect via an RJ45 lan cable to do the check on the router, but it maybe that the pc wireless adapter is at fault.
Ialso have suddenlink
How to Set Up a Netgear WGR614 V5 Wireless Router
Netgear routers--like all wireless routers--give you the opportunity to access the Internet with your laptop or wireless-adapted computer from virtually anywhere in your house within range of the router's WiFi signal. Though slightly different in appearance from other router models by Netgear, the WGR614 V5 acts similar in its setup process as others such as the WGT624 or WNR1000 series routers.
Things You'll Need:
Netgear WGR615 V5 routerNetgear resource CDEthernet wireBlue network wireModemComputer
1 Prepare to install the Netgear router. Log off and shut down your computer system. Turn your Internet modem off and/or disconnect its power supply from the electrical outlet. Take out the contents of the Netgear router box and verify that all the essentials are present: the resource CD, the yellow wire and the router itself.
2 Connect the Internet modem to the Netgear WGR614 v5 router. Locate the yellow Ethernet wire running from one end of the Internet modem to the computer's Ethernet port. Unhook the computer-end of the Ethernet wire and insert this end into the port on the router labeled "Internet." After inserting, confirm that the wire runs from the modem to the router.
3 Connect the Netgear router to the computer. Grab the blue cable supplied with the router. Securely insert one end of the blue cable into one of the four "LAN" ports on the router (the "LAN" ports are labeled with numbers from 1 to 4). Insert the other end of the blue wire into your computer's Ethernet port.
4 Start your network devices. Turn on or connect your Internet modem to an electrical outlet. Wait for at least two minutes to allow the modem to fully boot. Plug the Netgear router into the wall or electrical outlet as well, and wait one to two minutes. Turn on your computer.
5 Look at the Netgear router to verify that all lights are on. The "power," "Internet" and "wireless" icon symbols on the front of the router should be solidly lit. One of the four "LAN" ports should also be lit with either a green or amber color.
6 Insert the resource CD that came with your Netgear router to launch the "welcome" screen. Select "Router Setup" from the menu to begin the "Smart Wizard" setup application. Read and follow the setup steps, including naming your SSID (secure set identifier) or "network name" and setting a level of wireless security. Finish the setup process, ending with the registration of your Netgear router.
7 Verify that your Netgear router has been set up correctly. Open an Internet browser from both the computer that is connected to the router and on a computer that has a wireless card or adapter. Surf to your favorite Internet sites to verify your connection is working. Open your "network connections" utility on your operating system and make sure it shows that you're connected to your own wireless network.
Jan 09, 2012 | NetGear WGR614 Wireless Router
Just bought a new PC with Windows 7 and the netgear wireless-g wgr614 router says it's incompatable
are you trying to run CD on new computer ?
You can do it manually without CD.
First let me know, are you trying to install the router OR you are trying to add a new computer to the existing network.
If you are trying to add a new computer to the existing network then you don't need to install the router on the computer, you just need to connect to the network.
Click Here for more information about router and networking
Feb 05, 2010 | NetGear WGR614 Wireless Router
I need the install cd or a download for a version 5 netgear wireless router
If you connect the computer to the modem , does it works ?
If it works then modem is working. now connect the computer and modem to the router.
open the set up page of the router. change the Internet settings according to the ISP.
You don't need CD to install the router, you can do it without CD also
Click Here for more information about router and networks.
Jan 09, 2010 | NetGear WGR614 54Mbps Wireless Router...
I need to install my netgear wireless router to my new computer without cd
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Jan 06, 2010 | NetGear WGR614 54Mbps Wireless Router...
No Setup CD
Are you trying to set up the router ?
You can do it without the CD. You can do it manually.
First make sure that your computer is able to go online when connected directly to the modem.
Then connect the modem and computer to the router and check the settings of the router.
Click Here for step by step solution
Nov 27, 2009 | NetGear WGR614 Router
Could not make router to work, Netgear modem adding router.
i suppose you have to connect modem to router's "source" socket and modem to socket "in wall" then reset and reconfig router and you should be ok
Nov 10, 2009 | NetGear WGR614 Wireless Router
Why isnt the setup cd working
your computer may not be setup for autorun cd to run the application after inserting cd. insert the cd, right click the cd icon in my computer. click autorun. if it doesn't run or no options, your cd may be damaged. go to netgear site and download available software for netgear wgr614
Sep 23, 2009 | NetGear WGR614 Wireless Router
Router setup
Verify the physical connection. From the modem, it should be connected to the router's Internet port, then your computer must be connected to port 1 on the back of the router. Then do a power cycle, then try to run the setup CD. If it doesn't work, you need to manually configure the router. You may need assistance from Netgear tech support. Call their toll free number
Jun 20, 2009 | NetGear WGR614 Wireless Router
Internet access not working on desktop thru Netgear WGR614 router
Make sure your desktop doesn't have static IP address. Go to Network Connections, Properties of Local Area Connection, Internet Protocol > Properties. Select Obtain IP Address Automatically and Obtain DNS Servers Automatically. Apply the changes and restart the computer.
Jan 18, 2009 | NetGear WGR614 Wireless Router
NetGear WGR614 Wireless Router Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
