Question about Whirlpool Dryers
What does error code F04 mean on my whirlpool Duet dryer
SOURCE:
localwonder
  • 6784 Answers
SOURCE: whirlpool duet dryer error code e1
HI, the Thermistor has failed. replace it asap. this will fix your issue.
Posted on Aug 01, 2009
SOURCE: Whirlpool Duet Sport Error Codes?
My machine had the F21 code and the inlet to the pump was blocked with change, bobby pins, small rocks, pieces of fuzz and clothing. Removed the front cover of the mahine and removed the cap on the front side of the pump and cleaned this trap area out. The pump motor quit humming and the machine worked like it is supposed to!
Thanks
Posted on Sep 09, 2009
Jahn27
  • 1554 Answers
SOURCE: What does code F70 and F71 mean on my whirlpool duet?
Error code F70 means no communication is detected from the Central Control Unit (CCU) to the User Interface while F71 is the reverse; no communication detected from the User Interface to the Central Control Unit (CCU). This could simply mean a loose or poor connection between the two communicating boards.
Disconnect power to the washer prior to servicing to avoid the risk of electric shock.
Remove the three screws attaching the top panel to the rear of the washer then slide the panel rearward and lift it off the washer.
Disconnect the User Interface ribbon connector from the left side of the Central Control Unit (CCU) and clean the connector and terminals thoroughly. Reseat the connector several times to ensure a good connection between the Central Control Unit (CCU) and the User Interface.
It is highly recommended to clean and reseat every wiring harness connector from the Central Control Unit (CCU) to prevent the same problem in the near future.
Reconnect every wiring harness to the CCU and make sure all connectors are firmly seated. Slide the top panel back into position and secure it to the rear of the washer with the screws previously removed.
Let us know if the problem persists for further assistance. We will be happy to resolve your problem.
Posted on Mar 19, 2010
blueextc3221
  • 15935 Answers
SOURCE: E1 error code on a
The E1 displayed indicates the thermistor is open and needs to be replaced. The connections can be loose but the most likely cause of an E1 error is a bad thermistor.
If you're comfortable and confident in your do-it-yourself skills and have access to a volt/ohm meter you can check and replace this part yourself.
For replacement parts - head on over to SearsPartsDirect.com - PartSelect.com - or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend these sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
SearsPartsDirect is Sears' website for parts and has extensive diagrams and parts lists.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 17, 2010
Testimonial: "Thanks so much!"
TheMobilian
  • 8220 Answers
SOURCE: my whirlpool duet dryer gives
F-1 Primary control problem. Replace control See page 76
This video shows how to get to the primary control
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Nov 06, 2010
What is f03 and e02 error codes on duet dryer[not washer]?
Error codes are pretty generic between the washers and dryers. This appears to be a temperature sensor issue.
whirlpool duet dryer f03 and e02 error code Google Search
Same error on a washer
How to repair whirlpool duet error F3 E2
Aug 20, 2018 | Washing Machines
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    Error Code 01 F06
    Your fault is mentioned here.
    An F06 fault code in a Whirlpool Duet washer (the Kenmore HE3/4t's are also made by Whirlpool) usually means a motor-related problem. It usually pops up when the drum won't rotate at all or only very sluggishly. Here's the excerpt from the Whirlpool Duet Service Manual on this:
    http://fixitnow.com/wp/2008/10/28/whirlpool-duet-washer-with-an-f06-fault-code/
    May 10, 2015 | Maytag Dryers
    What does the error code E04 mean on Whirlpool AWU610 Washer-Dryer
    Any error code starting with "E" followed by numbers indicates a code meant for a service technician. Call your Duet dryer retailer or Whirlpool directly to set up a servicing appointment.
    Read more : http://www.ehow.com/list_7528706_whirlpool-duet-dryer-error-codes.html
    Mar 16, 2015 | Whirlpool Washing Machines
    On Whirlpool duet steam front loading DRYER...What does the error code F70 mean?Do you have to have a certified whirlpool appliance service professional to repair?
    F70 code says...
    Replace the machine control electronics. You should first unplug the machine and then remove and plug back in all connectors on the front panel model as well as the electronic control module.
    If that doesn't take care of the problem then it may be time to consider replacing the rear board. The FSP # 8183259
    The control board is part # 14 in the link below.
    Sears parts direct /Whirlpool-Parts/Model-WFW9400VE01
    Mar 13, 2015 | Whirlpool Washing Machines
    What do Error codes F04 and E03 mean?
    The dryer is in need of service if a code beginning with an "F" appears in the display.
    Alternating between F# and E#, the dryer control has detected a problem that requires service.
    Call for service.
    May 04, 2014 | Maytag Maxima EcoConserve Series MED6000XW
    What does F-1 mean on a Duet front load dryer? Our dryer's lights will turn on but, the dryer will not start up. At first we thought the control panel was locked out. But, it wasn't.
    The "F-1" error code means a failure occurred with the electronic controls.. This could mean that wires are broken, the electronics shorted out or a manufacturer's default error shut the washer down.
    Prevention/Solution: The electronic control panel needs replacement. Find your dryer serial number and search for the part online. This is a lengthy job that usually requires a repairman unless you have dealt with and repaired dryers before.
    If your dryer was purchased within the past couple of years, the dryer could be covered under the warranty. Visit the Whirlpool customer service page for more information or Whirlpool-Duet-Dryer-fault-codes
    Hope this helps.
    Jun 02, 2011 | Whirlpool GEW9250 Electric Dryer
    Whirlpool duet dryer error code pf
    The error code means that the unit suffered from a power failure.just make sure that all the wiring is good there is nothing loose and the circuit breaker is in good shape you should be able to turn off the dryer unplug it for a few minutes and the plug it back in this should clear the fault code.
    Feb 26, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
    Error code E6 on a Whirlpool Duet Dryer
    Whirlpool Duet electric dryer only dries clothes on heavy duty selection. what is wrong?
    Dec 16, 2009 | Whirlpool Dryers
    Dryers Logo
    71 people viewed this question
    Top Whirlpool Dryers Experts
    Craig Butler
    Craig Butler
    Marvin
    Marvin
    Smitty
    Level 1 Expert
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
