Question about Magnavox Televison & Video
I have an old Magnavox TV 13prc1=0125 I do not have the remote. I would like receive channens 2 - 65 but did not know how to program the TV Can you help?
    Dedicated:
    Visited the website for 20 consecutive days.
  • 280 Answers
Hi willie i would like to help but this olds tv does not work
on free air channels
otherwise if you have a cable box just tune on 3 or 4 channel
or
Posted on Apr 29, 2019
SOURCE:
Sparky-UK
  • 129 Answers
SOURCE: programing i need a access code, one for all universal remote controll
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC4700
just right click and save as on the download links.
if this does not work you can try the search method,
you do this by either holding down the device button eg: TV or if you have one the "magic" button for three seconds, a light should then flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(www.sparky-uk.com)
Posted on Dec 30, 2007
Sparky-UK
  • 129 Answers
SOURCE: One for all universal remote model URC-3220 Attempting to program direct Tv receiver to remote. Need Receiver code number
http://www.ofausa.com/remote.php?type=URC3220
Many thanks
Mark
(www.sparky-uk.com)
robotek
  • 1512 Answers
SOURCE: Programming a RCA Universal remote to a magnavox tv
Hi tinalynn1071
I couldn't find the book anywhere for you,but did find a guide on programming RCA universal remotes, and a list of standard codes you may wish to try:)
regards
robotek
Posted on Jul 16, 2008
ronaldsuboc
  • 449 Answers
SOURCE: programming remote to phillips magnavox tv
hi!!!!
this might be help
click here
Posted on Oct 31, 2008
  • 6 Answers
SOURCE: "I need to program an old Panasonic TV with a RCA universal remote model RCR311St Help""I need to program an old Panasonic TV with a RCA universal remote model RCR311St Help"
Code For Model RCR311S Code 1003 for Panasonic TV Code 1054 for Panasonic TV Code 1062 for Panasonic TV Code 1109 for Panasonic TV Code 1170 for Panasonic TV Code 1248 for Panasonic TV GOOD LUCK THESE ARE THE CODES LISTED FOR YOUR REMOTE/
Posted on Jun 03, 2009
How do I program it to a Magnavox tv flatscreen
Programming an RCA Universal Remote - YouTube
? 2:46
https://www.youtube.com/watch?v=MZd4yBivcZ4
Nov 10, 2008 - Uploaded by alpharedecho
... how to program an RCA Universal remote for operation with your TV. ... Still in able to work or my rca flat screen and my zenith. .. ive .... I'd do it over and over and the power button on the remote just turns off in the end?.
Magnavox TV codes - Magnavox TV set. Buy, reviews ...
magnavoxtv.org/magnavox-tv-manual/magnavox-tv-codes/
Helpful Resources for Magnavox TV codes. Press and hold ... Note: If some buttonsdo not operate your equipment, try one of the other codes for your brand. TV.
RCA Universal Remote Control- Target Programming ...
Dec 25, 2015 | RCA CRK76TE1 UNIVERSAL REMOTE - With...
How to program uiversal remote for magnavox tb11qmw9a converter box
If you can not find the code most universal remotes have a search codes for correct one. Could take a lot of button pushing
Aug 09, 2014 | Magnavox TB100MW9
I have the Sylvania TV model#SST4191. I can not get an universal remote to program with it. Isn't there a sensor on the TV somewhere to read the code?
I dont know this model or how old it is. If it is an older set a universal magnavox or philips remote will work. You should find an older model remote in this case. If it is a newer tv you may use a newer magnavox or philips universal remote. If this is a flat screen, you will have to contact the manufacturer. You will be pleased to know now, that you are on the correct path.
Sep 04, 2009 | Televison & Video
Grundig PVR/ Digital TV Tuner with no external antenna?
i am living in a house where i cant place an external antina. is there any reveiver that donot require exteernal antina and we can receive channens
Jun 27, 2009 | Televison & Video
I changed the batteries in my phillips universal remote and when I did it would not work. I have a magnavox tv but I do not have the code or know the steps to fix it
You shouldn't have to do anything after changing the batteries. Philips and Magnavox are the same brand, so the Philips univeral control should work your TV without programming it. Check the batteries and make sure your new ones are in facing the right direction. Also be sure the new batteries are actually good. I've fixed remotes for people by just changing the batteries again, even though the replacements were fresh out of the package. Also, did the old batteries leak in the remote? The battery contacts may have corrosion on them. There's also the chance the TV's remote sensor is at fault. If you can, try the remote with another Magnavox TV or program it for another device and see if it's working, or try another remote with your TV. If you need programming instructions for your remote, you can usually find them on the manufacturer's website.
May 03, 2009 | Televison & Video
Trying to program Philco URC-2070 remote control
I determined that the Philco Remote Control that I wanted to program for use on a Magnavox tv was too old (20+ Years) and dead. It also did not have the features of a new Universal Remote. So, I tosed the Philco remote and purchased a new Universal Remote Control.
Thanke you..
Mar 19, 2009 | Philips Magnavox 20MT1336 20" TV
I have a rca remote (rcu404) my tv is a magnavox. I can not find my book so I need help finding the correct code to program the remote to the tv. Thanks I do not have the code book for my remote control....
Code 000 for Magnavox TV Code 004 for Magnavox TV Code 006 for Magnavox TV Code 008 for Magnavox TV Code 019 for Magnavox TV Code 062 for Magnavox TV Code 068 for Magnavox TV Code 069 for Magnavox TV Code 075 for Magnavox TV Code 076 for Magnavox TV Code 077 for Magnavox TV Code 088 for Magnavox TV Code 130 for Magnavox TV Code 132 for Magnavox TV Code 133 for Magnavox TV Code 134 for Magnavox TV Code 183 for Magnavox TV Code 219 for Magnavox TV Code 235 for Magnavox TV
Jan 14, 2009 | RCA RCU404 Remote Control
Magnavox TV remote broken - won't switch to watch DVD
There may be a manual reset button somewhere on the back of the set. If not, try unplugging it for 10 minutes and then plugging it back in. If that doesn't work, call Magnavox.
Apr 11, 2017 | Televison & Video
Televison & Video Logo
22 people viewed this question
Top Magnavox Televison & Video Experts
Demonic-2011
Demonic-2011
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
