Question about LG Audio Players & Recorders
I just powered up my LG HT806 home theater system after I used it earlier today, but it isn't coming up. The fuse is ok but I saw little smoke coming from the screen display inside. What could have caused it and the solution to it? Thanks
    Dedicated:
    Visited the website for 20 consecutive days.
  • 280 Answers
Hello henry
this device now require some electronic service and
caused by the incoming ac energy most of the time
Posted on Apr 29, 2019
SOURCE:
  • 3 Answers
SOURCE: home theater system connections
Hi
I have the same tv but my dvd surround is a toshiba, that shouldn't matter though. When I watch a dvd I go to component 2 which is where I have my dvd connected on the input of the tv when I watch tv and want the surround on I go to component 1 which is the tv input then on my dvd player I go to auxillary and I can watch tv in surround. I don't know the LG home theatre system but you should be able to select your inputs like between dvd, tuner, aux. Flip between them and you should get sound. hope this helps.
Posted on Jan 19, 2008
tech48
  • 624 Answers
SOURCE: Panasonic home theater system pt760
Make sure you have put the transmitter for the wirless speaker in the slot on the back of the reciever, it is a slim white device that is about 3 to 5 inches long?? and maybe half an inch thick. and make sure it is put in the right way.
Then make sure the wireless speaker is plugged in to the wall outlet.
If this does not work for you it may require being taken in to an authorized panasonic service center. when one part of the wireless system fails (transmitter or reciever) they both must be replaced. they are not interchangable from one panasonic to another.
They have a code in each unit that lets the wireless speaker that came with it only work with the reciever it was sold with.
I have even seen times where the store that sells them swapped the transmitters of two units and then they had two customers very mad at them because the wireless speakers did not work for either person.
Let me know if I can be of any more help.
Posted on Jun 19, 2008
SOURCE: LG Home Theater System LHT754 no sound
All you are currently doing is getting sound OUT from the LG HT system. If you want sound from your cable or satellite, you have to run a seperate audio cable into the back of the LG system. If you are running a cable line straight into the TV you need to run an audio cable OUT of the TV so you get sound via the LG system.
SOURCE: Getting F61 in Display of Panasonic SC-HT700
I have gotten the f61 error code on my SC-HT700. No idea what the problem is.
Posted on Nov 04, 2009
SOURCE: push power protector showing up in sony dvd home theater system
Always be the audio amplifier IC damaged
Posted on Jun 24, 2010
NO AUDIO OR VEDIO ON MY LG DVD RECEIVER
Even though the fuse checks OK, the power supply may have failed.
Dec 01, 2014 | LG Audio Players & Recorders
Lg network 3d blu ray home theather model# lhb336 problem/boot and please wait
Check working condition hardware. May be malfunction Main Boar or AMP. Unplug cable (wires) attached from Power PCB Board and main board to AMP PCB Board. Turn ON, if again comes message " Please wait" and unit sot down itself- Malfunction main board. If unit booted UP -OK -replace AMP board. Parts are available on our web
Dec 12, 2012 | LG LHB336 3D Wi-Fi Ready Bray Home Theater...
RCA DVD Home Theater System popping noise now wont turn on
if no any power indicator the first place to be check is the power supply where in the fuse get blow. if the fuse blown with darkened color that was mean has shortened line, might the amplifier circuit get damaged that cause of popping before it totally down.check for bad amplifier ic and shorted diodes.
Jul 26, 2012 | RCA Rtd315w Dvd Home Theater System...
Ive hooked everything up like it should be and no sound from tv, game, or anything but the radio and dvd. What do I do next...
I cant narrow this down too a specific problem but here are a couple i can list off the top of my head
A. The outlet, or powerstrip is offB. There's a blown fuse somewhereC. Power cord or some other cord isn't plugged inD. There's A Manufactering defect.
Feb 26, 2012 | LG Audio Players & Recorders
THE PLAYER JUST WENT SILENT SO I OPENED IT AND I SAW THE FUSE SEEMS TO HAVE BLOWN. COULD IT BE A BIG PROBLEM OR DO I JUST NEED TO CHANGE THE FUSE
Yes, it's big - the fuse doesn't blows unless something inside got shorted. You will need to test the components to find out what happened: either one of the amplifier circuits failed or the power source itself got shorted.
Jul 24, 2011 | LG LFD790 System
I have and lg tv and a samsung home theater
optical audio cable from home theater to tv. can be purchased on line for a few bucks.
Dec 21, 2009 | LG LHT854 Theater System
My power won't come on and my cd are inside my 5
unplug and hard reboot should be a button in the back reset
Dec 05, 2009 | LG 1000W XM-Ready 5.1-Ch. Home Theater...
Sony davs 500
Does its standby light lit?
Can you mention what fuse you checked and found OK. Please write fuse circuit number like F600, F201 etc
Nov 08, 2008 | Panasonic Home Theater System System
Home theater won't respond to power button.
i had the same problem, just returned it to the store and they gave me a new one
jeff
Aug 22, 2008 | LG LHT854 Theater System
21 people viewed this question
Top LG Audio Players & Recorders Experts
Marvin
Marvin
PNiss
Mike Duncan
Mike Duncan
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
