Question about Hitachi CMP420V2 42 in. HDTV-Ready Plasma Television
Flickering Screen I just got a used Hatachi CMP420V2 from my inlaws. The TV worked fine at their house but when I brought it home and hooked it up, the screen Flickers. It flickers about every half a second. I hooked up the DVD and the same thing happens.
How do i turn off pal
Posted on Oct 01, 2009
Did you get it from another country?
PAL = OTHER 50hz
NTSC = US/CANADA 60hz
if you live in lets say U.S.A and you hook up a PAL tv (europe/other) it will flicker cause its not compatible.
Do you catch my drift?
Posted on Dec 01, 2007
TV flickers when playing a Super NES
either the optics cable that you are using or the optics port on the NES is faulty.. try finding a new cabkle on ebay
Dec 05, 2012 | Nintendo Super NES Console
I have a Phillips TV and can't get any channels on it all other TVA in house are working fine when I try the auto programming and try to select cable it says indicator is available for diigital b
First thing to do is see if a DVD etc. hooked to a rear input works.
If it does you may have to go into the menu of the set and set it back to regular cable to be able to program it.
If a cable box is used here you could also connect from its rear audio/video jacks (most models have that) to a set on the rear of the TV and bypass the issue altogether.
Apr 03, 2012 | Televison & Video
I just bought a 55 Inch Rear Projection HD Mitsubishi TV. 2002 model year. It appeared to work fine yesterday at the guys house before I bought it then I brought it home and I have a flickering going on....
It's not a banged-out connection, something is wrong with the analog inputs (and only them, the rest of the tv is ok) - probably caused by a faulty capacitor either in the corresponding power line or the signal path itself, normal problem for a tv of that age. You will gonna have to open it and see where the problem is.
Apr 29, 2010 | Televison & Video
Hooking up pc through hdmi - red flickering image
The format from the PC needs to be an HDTV format: 480i, 480p, 720p, 1080i or 1080p. Other formats will generally not work. You may need to get the latest drivers from your video card manufactures website to correct the problem. I hope this was helpful, best wishes.
Apr 18, 2010 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
I brought my ps3 home from my office and it was working fine there but will only turn on and nothing will display on the tv. I use hdmi on the tv in the office and was trying to use the 3 prong at the...
You must go back to the origional place you used the HDMI last, and do all the setting up & hook up again, to get a picture, THEN set it to component, or AV, and THEN turn off shut down, Now it will work at the other place OK.
Feb 23, 2010 | Sony Playstation 3 (PS3) Console
PS3 Works on HD TV without Sound, no sound or display on a reg TV
when u connect ps3 to your tv turn on main switch now red led will come on press and hold touch button ps3 will come on keep your finger on the button and ps3 will turn off again factory settings are now reloaded this will work because i often change from standard v to hd tv
Jan 18, 2009 | Sony Playstation 3 (PS3) Console
Played ps3 on my brothers hd tv
do u have hd?
if not u need to change ur settings to video instead of hd! but when i had to i needed it hooked up to hd first then went through settings to change it or it will be blank screen!
Dec 26, 2008 | Sony Playstation 3 (PS3) Console
1999 toshiba rear projection tv blinking red light after moving
this might be a tube leak check for fluid on the necks of the tubes with your hand. if none you might have a faulty protect chip- common-
forgot the exact location but it's on the main board, it's a 16 pin chip as i remember and it is a quad op amp. if you hold your finger across the pins underside it will turn on and stay on as long as your finger is there, if so replace the chip
Dec 25, 2008 | Toshiba 50H81 50" Rear Projection...
Vizio Sound Problem
I've seen the same problem, went thought a couple of cable boxes. Turned out to be an AC line problem. Try plugging the TV into a different out, maybe in another part of the house.
Jul 16, 2008 | Vizio P4221 Television
Colors out of Whack on HD input 4 only
May need higher quality component HD cables? Tried switching Blue on Red? Just some thoughts.
May 02, 2007 | Philips 60PP9202 60" Rear Projection...
Hitachi CMP420V2 42 in. HDTV-Ready Plasma Television Logo
386 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
