Question about Kenmore 3.8 cu. ft. HE3t Front Load Washer
He3t my frontloading washer stops at least 4 times during each load. the display reads f-02 or sud. i use high efficiency detergent so I dont understand why either problem occurs. I also changed the drain hose as well.
    President:
  • 1,294 Answers
Check out your outlet filter, access from the front bottom right. Next open up behind to check the pump area, also the tube which comes down from the tub. There should be some blockage somewhere. Plug off the wall first. Your need a good grip plier to release the grip clamps. Perhaps you could change to front loading powders?
Posted on Nov 27, 2007
Washer stops running and displays code SUD. The water doesn't drain until It's put on the rinse/spin cycle.
Make sure you are using HE (High Efficiency)detergent. The codes could mean your washer is telling you it has used a built in "SUD" routine during final rinse
Jul 18, 2015 | Whirlpool Duet GHW9150P Front Load Washer
Won't finish cycle 21 F- flashing on panel
F21 error code is indicating that it is taking too long to drain water.
Your details indicate that you are using too much detergent or the wrong type of detergent and causing excessive suds. The drain pump can not pump suds out. The washer requires HE (High Efficiency) detergent formulated for front loading washers.
Cut back on the detergent and it will most likely operate correctly.
NOTES:
* After four (4) minutes the "Sd" error will be displayed, and then four (4) minutes later the "F21" error code will be displayed.
* Press STOP two (2) times to clear the display.
Possible Causes:
- Using too much High Efficiency (HE) detergent and causing too much suds.
- Using NON-HE detergent causing too much suds.
- Kink in drain hose
- Debris or foreign objects in drain pump filter.
The drain filter is located behind the lower access panel.
NOTE: Disconnect the power cord before removing the lower access panel and cleaning out the drain pump filter.
Remove the two screws (key#21) securing access panel. The filter cap (key#14) is removed by turning it counter clockwise. NOTE: Be sure that all the water has pump out before removing the cap. Have some large towels handy because there will be water coming out the filter/pump once you remove the cap. Check and clean the filter and remember to reduce the amount of detergent and the washer should perform as designed
Hope helps (remember to rate and comment this free answer)..
Jun 10, 2011 | Kenmore HE2 Plus Front Load Washer
Error message sd
Sorry to read about your problem, I hope this helps you out.
"Sd" fault code in the image below. The "Sd" usually displays when too much detergent is used or the wrong type of detergent is used. High Efficient (HE) detergent is recommended. You clothes may have detergent in them that has not fully rinsed out and when you wash them the added detergent causes over sudsing.
I recommend washing the type of loads that generally causes the "Sd" to display without adding any detergent to see if it develops suds.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 05, 2011 | Kenmore HE2 Plus Front Load Washer
Water will not spin out. Code says 5d
The troubleshooting page in the owner's manual says: 5d "Sd" Suds Detected - Did you use regular detergent? Regular or hand-washing detergents are not recommended for this washer. Use only High Efficiency (HE) detergent. Did you add too much detergent? Always measure detergent. Follow detergent manufacturer's directions. If excessive suds are detected, the washer will display this code while running a suds reduction correction routine at the end of the wash cycle.The susds reduction routine removes extra suds and asures proper rinsing of your garments. If te code remains and the wash cycle dial is flashing after the recovery routine has stopped, re-select your desired cycle using cold water. Press start. Do not add detergent.
Dec 31, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My maytag clothes washer Bravo quiet series 300, keeps flashing a Sd error code. Or it may be 5d
What does the Sd code mean?
This code indicates that excessive detergent suds occurred during the cycle. The washer will not be able to spin out water with the excess suds. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the washer pauses the wash action and adds water for additional rinsing. This pause allows the bubbles in the suds to break. This process is necessary and may occur several times to eliminate the suds.
Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
Use only HE High Efficiency detergent for BravosTM washers.
Is "Sd" displayed and the wash cycle dial is flashing?
This indicates the washer was not able to clear all the excess suds from the washer. Re-select your desired cycle using cold water. Press Start/Pause. Do not add detergent.
Is "Sd" displayed and the wash cycle dial is not flashing?
If "Sd" is displayed and the wash cycle dial is not flashing, allow the machine to continue running, even if it appears that nothing is happening. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the wash action will pause to allow the bubbles in the suds to break, and the washer will add water for better rinsing. This rinsing process is necessary and may occur several times to eliminate the suds.
Is the drain hose kinked or clogged?
Make sure that the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Remove any blockage from the drain hose, drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose.
To remove the error display, press Power/Cancel or Pause/Cancel once.
If Power/Cancel or Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start/Pause.
NOTE: If the error remains on the display, and all of the other questions above have been checked, call for service.
Dec 27, 2010 | Maytag Bravos 3.8 Cu. Ft. Washer
My washer (whirlpool duet) seems to cancel in the middle of load cycle. Most often the word "suds" is displayed. It is not the amount of detergent or the type because I use very little High Efficiency...
SUDS LOCK (Overdose of Detergent detected during the Wash Cycle)
The motor control unit senses a suds lock condition by analyzing the current draw on
the drive motor. If "Sud" is displayed a potential suds lock is detected. This may
signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
ERROR CODES
DISPLAY EXPLANATION AND RECOMMENDED PROCEDURE
Suds
6 - 7
Potential Causes
• If too much detergent was used, run the unit through a Rinse/ Spin cycle then a
Normal cycle without adding any detergent. This should clear the unit of the
excess detergent.
• Check the drain hose and make sure it is not plugged or kinked
• Check Wire Harness connections to the Drain Pump, Pressure Switch, and
Central Control Unit (CCU)
• Check/ Clean Drain Pump Filter of foreign objects
• Check Drain Pump
• Check the Pressure Switch
• Check CCU
Oct 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Cabrio washer is showing a 5d error and not spinning or draining well. What is the problem?
Sep 03, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Code f 02 and it is normally in the drain cycle.
This error code indicates that drain times are longer than expected.
Make sure the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Remove any blockage from the drain hose, drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose.
Use only HE High Efficiency detergent. Using non-HE detergent, or more than the manufacturer's recommended amount of detergent, can cause excessive suds. The excess suds will slow or stop the removal of water from the washer.
Mar 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Window reads SUD, don't know what to do.
Sud means ----------- SUDS LOCK (Overdose of Detergent detected during the Wash Cycle)
The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.----------- to resolve this problem ---------
If too much detergent was used, run the unit through a Rinse/Spin cycle, then a Normal cycle, without adding any detergent. This should clear the unit of the excess detergent. globul1a.gif Check the drain hose and make sure it is not plugged or kinked. globul1a.gif Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU) globul1a.gif Check/Clean Drain Pump Filter of foreign objects globul1a.gif Check Drain Pump globul1a.gif Check Pressure Switch globul1a.gif Check CCU
thanks.
Apr 01, 2009 | Maytag MAH6700A Neptune High Efficiency...
F 02 ERROR
Try cycling the washer a few times without a very small load of clothes and no detergent. I assume that you are and have beenm using only HE type detergent and I suggest you try using about 1/2 to 1/3 the amount called for until your system is purged of any and all remaining detergent in the lines. Here are the manufacturers reccommendations to address your problem..
“SUD” (Suds Routine)
When excessive suds are detected, a suds routine
automatically starts. This routine removes extra suds and
assures proper rinsing of your garments. “SUD” is displayed
during rinsing and at the end of the cycle to inform you that
Suds Routine was activated. Use only HE (High Efficiency)
detergents.
Hope this helps you..
“F02” (Drain Problem)
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
washer or disconnect power.
Check the following:
Is the drain hose kinked?
Is the drain hose frozen?
Is the drain hose clogged?
Is the drain hose more than 96" (2.4 m) above the floor?
Sep 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
66 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
