Question about HP OfficeJet 6110 All-In-One InkJet Printer
HP Officejet 6110 - Scanning Error. Cannot connect to PC
The printer and fax work fine so obviously it is connected to my PC OK, but when I try to scan, nothing happens for about one minute, then it says" Scanning Error. Cannot Connect to PC". I'd appreciate any help you can give me.
  • snewman31 Nov 28, 2007
    Awesome! Nice job. This did the trick and everything is working well now.
    Thanks a lot.
  • 298 Answers
Uninstall and Reinstall the software
1 On the Windows taskbar, click Start, choose Programs or All Programs
(XP), choose Hewlett-Packard, choose hp officejet 6100 series, then
choose HP Uninstaller.
2 Follow the directions on the screen.
3 If you are asked whether you would like to remove shared files, click No.
4 After the program finishes removing the software, disconnect your
HP OfficeJet, and restart your computer.
5.Do not reconnect the Officejet now
6 To reinstall the software, insert the HP OfficeJet 6100 Series CD-ROM into
your computer’s CD-ROM drive, and follow the instructions that appear.
7.After the software is installed reconnect the usb cable and allow the
computer to detect and install the software
If this doesnt work then get back to me
Posted on Nov 27, 2007
  • Eugene Merritt Nov 29, 2007
    You neglected to rate this session as
    solved it is necessary for bookeeping
"Cannot connect to PC" is the message that I am
have you tried uninstalling all the HP software for the all in one - and then re installing the software and drivers ?
if not, try it ..
if it still does not scan , go to this site and read .
i hope this helps .. if it doesnt , please advise what operating system you are using and if you have current updates for the OS. if not please update Windows to current level available from MS.
ps: i hope you purcahsed a UPS to avoid power downtime from local electricity company.
i hope this hleps
thanks for using FIXYA
Mar 23, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Fax set up -I've used this model for years and now
do you have dsl filters installed? the fax should go to unfiltered line not the filtered dsl line.
Jul 17, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Keep getting scanning error message
How do you have the HP6110 connected to your system? This problem can sometimes be caused by using to long a cable between the computer and the multifunction printer. I would use a short cable (6 foot or less) to make sure that it's not a communications problem. This ususally manifests itself with an error message while scanning although the printing function work ok.
Apr 23, 2009 | HP OfficeJet 6110 All-In-One InkJet...
How do I fix an "error 442" on the fax part of my hp 6110 all-in-one
Per HP:
An error occurred during transmission after one or more partial pages were sent. The sending machine was unable to restart the control channel connection(handshake) before sending more data. This error typically occurs when the receiving fax disconnects after receiving part of a page. It can also be caused if the receiving fax is using a fax format incompatible with the HP fax (usually during color faxing).
Try the fax at a different time when telephone line conditions have improved.
Apr 19, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Inability ro scan to new laptop
Before scanning from the printer front panel, make sure your Solution Center is properly installed. Try scanning from the Solution Center first. The status of the printer should say ready before scanning.
Mar 04, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Fax will fax or receive fax
If it is a Officejet 6110 All-In-One first run a fax test:
Press Menu/Setup> Press the right arrow key to locate Tools> Press OK> Now press the right arrow key to locate Run Fax Test> and press Ok.
Check to see what has failed and correct what ever has failed in the fax test.
And follow the below mentioned steps to connect the All-In-One according to your setup:
Good Luck
Oct 01, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP officejet 6110 all in one scanning
LOOKS LIKE YOU HAVE A MECHANICAL PROBLEM , need to check the motor , guidance path where the bright light travels , needs to be serviced , hope this helps
May 05, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
619 people viewed this question
Ben Johnson
