Question about EliteGroup Intel Pentium 4 Processor 506&ECS P4M800-M7 Motherboard (506P4M800M7)
Hsf irs running
Hsf is running but it wont boot no beep just nothing ,have check all d hardware even tested it on another pc all are ok im suspecting d mobo .cables ide are connected no loose wiring pls help
  • Joey Serrano Mar 30, 2009
    when powered on cpu fan working, hard drive working but the monitor led is just blinking but the monitor is working fine with other pc, i tried installing a 128mb pci vid card with a 350wattts psu after booting it up theres no display the monitor led is just blinking, helpppppp
    Problem Solver:
  • 6 Answers
Motherboard Problem:
...Just dismount your Motherboard from the cpu case and Tick with the handle of screw driver at back..
Things to tick::
Mounted Capacitor, Diode, etc: specially from the cpu place
Question: Why??
Answer: Because some motherboard i already fixed is the same problem for this situation..And all of them still working until now.
Posted on Oct 08, 2009
  • 95 Answers
CPU or motherboard would be my guess. Try resetting the bios with the onboard jumper. Also could be a memory problem.
Posted on Nov 28, 2007
Black screen green dots
What was the last thing you did on your computer before this happened?
Did you change any system settings in the BIOS?
Did you add new software? or update any software or drivers?
Did you add any new hardware?
Is your system BIOS infected with a virus?
Because it appears that your PC is hanging up during the Power-On-Self-Test [POST]
Here's what happens; when the power is turned on, the computer BIOS [Basic Input/Output System] runs a POST (Power-On Self-Test). It is a diagnostic testing sequence that the computer runs to determine if the hardware [like the mouse, keyboard, hard drive, etc.] is working properly.
If the necessary hardware is detected and found to be operating properly, the computer begins to boot; If the hardware is not detected or is not operating properly, the BIOS issues an error message.
The error message may be a text on the display screen and/or a series of coded beeps, depending on the nature of the problem.
The series or pattern of beeps may vary...they may be in a number of long or short beeps or a mixture of long and short beeps, or even one long continuous beep, depending on what type of BIOS is installed.
Since POST runs before the computer's video card is activated or the integrated graphic chip on the main board, it may not be possible to progress to the display screen.
So if an error is detected during the POST it will halt the boot process because the hardware is essential for the computer's functions.
How many beeps do you hear during the initial POST?
You may have a burned out video chip/card; or corrupt drivers; or even an IRQ [Interrupt Request] conflict.
Nov 26, 2013 | Acer Computers & Internet
2 loud beeps then shuts down
Have you checked it with batteries does it run the same way
Sep 02, 2013 | HP Pavilion Computers & Internet
Gateway GT4010 boots then starts beeping and shuts off
First check your power supply section and check your power fan that is running properly. if ok then the suspected area is your processor section. please check it if its collar fan nor running properly then clean up or change that. and the other advice is please check your processor pin which are too tiny. be careful about these.
Apr 08, 2010 | Gateway GT4010 (RBGT4010) PC Desktop
Computer dead and beeping
If it beeps and not boot then it is the post routine telling you there is a problem. The post routine is run when you turn the power on to ensure the computer hardware is ok to run. The manufacturer of the bios routine can tell what is wrong by the type, number and duration of the beeps. Look up the code meanings and it will indicate the problem. If this sounds like nonsense to you then give the make and model of your machine and what the beeps sound like. ( beep beep beep delay beep beep beep) etc. and I'll look it up for you.
Aug 10, 2009 | Computers & Internet
Dell Dimension XPS PC Desktop won't boot
Vista is available in 32 and 64 bit os.
if your system ran xp which was most likely 32 bit. And you have installed a 64 bit version os.
this will be your problem, also Vista requires more system RAM/Memory to run it.
If you get 1 beep at startup, it states the system is ok.
Alternatives are device drivers incompatability.
Check M$ website, regarding vistas minimum system requirements.
Mike @ Compurepair.
Jun 11, 2009 | Dell Dimension XPS PC Desktop
Ni signal...no boot...no beep...need help
after the test of the JKPF, if it doesen't beeps, it means that the MOTHERBOARD SI broken...sry for you :(
May 12, 2009 | Intel Motherboard
PC will not boot
Dear John:
Tell me your board manufacturing date & CPU details. I can help you out..
Jun 21, 2008 | Intel Motherboard
My ayatem is restarting automatically
If it is just shutting down for no reason while you are working with it, then the first suspect would have to be the memory.
Run a memory diagnostic on the computer ,memtest is a good program for thes and it will let you know very quickly if your memory has problems.
The fact it boots means nothing since the memory etc are not 100% checked, just a quick test and nothing more.
Hope that helps.
Apr 11, 2008 | Computers & Internet
Acer ast180
The beeps that you are hearing are messages created by the POST (Power On Self Test) to indicate that something is wrong. If you know your motherboard type it is possible to find the documentation explaining what 3 beeps mean.
Because we don't know the motherboard type (At least for now) let's use the common sense.  Did you verify that the power supply is properly connected to the drive?  Can you confirm that removing the second Hard drive it boot again ok? In some type of BIOS 3 beeps means memory problem. By accident did you touch the memory? Are all the ribbon cables well plugged in?
Oct 20, 2007 | Acer Aspire™ T180 PC Desktop
Computers & Internet Logo
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
