Question about Zenith Televison & Video
How do I adjust back light on Zenith Z212b - Zenith Televison & Video
2 Suggested Answers
SOURCE:
  • 161 Answers
SOURCE: TV reception band no longer works
all analogue signals going out means EVERY analogue signal is gone in the TV band. these are now apparently assigned to emergency services in some states.
Posted on Jun 14, 2009
Zenith TV B27A24Z, Vert Size Adjust
To do this adjustment, you should enter the service mode option. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Service mode entry, adjust and exit procedure to many popular brand TVs are given.
Feb 27, 2014 | Zenith Televison & Video
My zenith television has black n white but should be color
old if it has a manual tuner there will be a fine tune adjustment.
It would be behind the channel selector knob or in some cases
very close. If the tv loses color try this first.
re-post if you need more info.
Mar 10, 2013 | Televison & Video
My 42" Zenith plasma flat panel television model
You can check the va, vs adjustment, but alot of plasmas does this, my first thought would be the y sus board, it also could be the panel which is not worth fixing, if it is really bad, check voltage and if this isn't out then Y- board is the next thing to check.
Jan 27, 2011 | Zenith P42W24B 42 in. Plasma Television
My zenith lcd tv has lost its blue tint. most
the light polarizer on the blue lcd panel is fried due to excesive dust and heat, and therefore need to be replaced. unfortunately, zenith may not sell individual parts of the optical engine, so you'll have to replace the whole optical engine.
Dec 17, 2009 | Zenith E44W46LCD 44" Rear Projection...
Zenith Z25X31D Verticle Adjustment
open up the set and on the board there are 2 small potentiometers mounted on the board called Vert-Linerity and Vert Height, I believe the adjustment of the Linerity control will fix your issue
Sep 17, 2009 | Zenith Z25X31D TV
Jun 14, 2009 | Audio Players & Recorders
Adjust Convergence on Zenith B27A11Z
You don't adjust convergence through a service mode on one of these sets. With a conventional CRT, convergence is done by physically adjusting the convergence rings on the neck of the tube, and the position of the deflection yoke near the bell. You would also need a crosshatch generator to provide the required test pattern for adjustment.
Feb 09, 2009 | Zenith B27A11Z 27" TV
I have a Zenith C27A24T the picture is out of focus.
If there is no other problem, he probably touched the focus adjustment in the back of the set. Open up the back and locate the flyback transformer (part with large red wire coming out the top). There will be 2 adjustment controls on it. One should be labeled screen, the other focus. Adjust the focus until crisp.
Dan
Sep 04, 2008 | Zenith C27A24T 27" TV
Zenith Z212B CD clock radio
Have you done the presets on the memory. Do that then select the station you want to wake up to. Hopefully its fm. Per the instruction manuel . Set or adjust the alarm time if necessary. Press the Alarm on/off button if necessary until one of the alarm indicatior either the note or alarm appears on display when the buzzer alarm is selected. While the alarm time display is flashing press the tuner button to select am, fm, or tv band. The selected indicatior appears in the display ( Note : you can only select the band when you have selected wake to music. While the alarm time display is flashing press one of the preset buttons to select the station you wish to hear when the alarm goes off.
Apr 17, 2008 | Audio Players & Recorders
R57w46 zenith
Hello Was wondering if you ever found anything out how to reset the IC Screen Numbers or what the factory numbers all are on the Zenith Rear Projection TV Model # R57W46? I have the same problem ! My 2 year old son, not knowing how he did it cuze only a technecian is suppose to get into this screen, but he did change numbers in the too. I called zenith themselves and no luck ! My screen is bowed , etc.. Any Help ?
Jan 16, 2007 | Zenith R57W46 57" Rear Projection...
Televison & Video Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
