Question about Pioneer Car Audio & Video
Rest buttons for pioneer vsx9700 - Pioneer Car Audio & Video
My pioneer plasma tv in standby mode and wont turn on
Try restting it by unplugging the tv for a few mins and it should rest to original factory default settings but leave it unplugged 10-15 mins to be sure.
Dec 18, 2011 | Pioneer PDP-4270HD 42 in. Plasma...
Our receiver (pioneer vsx-405) will not power on. Push the power button once and you get the power stand by light coming on but when you hit the button again the stand by light goes off and nothing comes...
Usually a fault like the you ask will indicate a bad transistor in the amplification section. I suspect that the control circuit is sensing a fluctuation in the power supply and going in to protect mode. (assuming that the protect circuit itself is working properly) If a voltage is too high the unit will go in to protect mode to prevent damage to the speakers and the rest of the unit. I would take the unit in to a local repair shop and get a estimate of repair charges. Expect a 60 to 80 dollar repair charge depending on how many parts need to be replaced and what the repair labor rate is in your area.
Good luck...
Jun 14, 2010 | Pioneer VSX-405 Receiver
My Pioneer DEH-2000MP now has the worng AM frequency spacing, ie. rather than tuning in 580AM, it tunes to 576AM and the station is fuzzy. This appears to only effect AM, not FM. Stereo worked fine until...
Get to the set-up menu by pressing the source button until just the clock is displayed, no music just the clock. Now press and hold the "func" button until "Menu" appears. Now scroll thru the various items using the up & down or the side to side buttons. I believe you will find the item for US or Europe or like Alpine reads Area 1 for US and Area 2 for the rest. Good luck.. Mark
Aug 18, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
I NEED TO KNOW ARE THE COLORS MEANING FOR PIONEER AVIC N2 WIRING
Red = power Organ = battery Blue with a strip =remote
Blue antener ( the rest are speakers )
Aug 16, 2009 | Pioneer Car Audio & Video
Pioneer cdx p1280 cd changer,the cd magazine will not eject.the power is all ok,tried the rest button bt still no go.
cd changer reqs a verygood 12v source,check for a good earth&check how many volts are going to changer with a good quality voltmeter,check at changer,not head unit
Jul 03, 2009 | Pioneer CDX-P670 6-Disc CD Changer
Need to install a pioneer cd player to a DEH-1550. Can I please see a diagram?
the easiest way if u still have ur harnest in tacked in ur car go to ur radio store and get a kit and a wire harness kit and match the colors. if u dont first get a volt tester with a light first find ur poewer and constant. constant will turn ur light on auto matic. the power will turn on when u turn ur igintion. once u find them put them aside now the rest of the wires. get a AA baterry and try one wire at a time once u hear a pop thats the first speaker tape it together. and do the rest to the rest of the wires
Jul 03, 2009 | Pioneer TS-A6962R Car Speaker
Pioneer deh 6700
hello, my front panel doesn't work. Only volume is working but nothing else. Any fix? Do I need to buy a new front panel? Thanks.
Jul 04, 2008 | Pioneer DEH-P6700MP CD Player
Pioneer avic n-2
If you still need the rest of the parts call me 801 414 4566. Thanks.
Jun 03, 2008 | Pioneer AVIC-N2 Car DVD Player
Wire Color Code
what color is what on the pioneer deh-p4100
Jul 12, 2007 | Pioneer DEH-P4100
Pioneer dvd recorder dvr 310
I've seen this problem somewhere before, ran across it on a service call or something and I just can't remember where.. Just getting old I guess.. You should have a "Return" button on the remote. Press it and the "2"... That should allow you to access the unit again. What you've done basically is set the unit up as unit 2 and you could have as many as 3 identical units all operating from the same remote. So, Pioneer, in their infinite wisdom decided to make three specific designation points and allow you to switch the remote to access each one without disturbing the rest... If this doesn't solve the problem you might try calling Pioneer support, 800-421-1404 and they should clearly be able to help. Good Luck Bill
Jun 07, 2007 | Pioneer DVR-3100 DVD DVD Recorder
Car Audio & Video Logo
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
