Question about Whirlpool Dryers
How many cu ft is my Whirlpool dryer ggq8858hq0?
SOURCE:
  • 10865 Answers
SOURCE: What cu. ft. size is my Whirlpool top loading
hi there. the best way to determine this is to measure the inside length, height and width and you will get cubic feet. Just be sure to convert each measure to feet. For instance 2 feet 4 inches = 2.33 feet.
Posted on Jul 28, 2009
SOURCE: Admiral 6.5 Cu. Ft. Super Capacity Electric Dryer not drying load
does the admiral aed4475tq have a reset button it will not turn on it is only 9 months old
Posted on Jan 01, 2010
aasc
  • 1606 Answers
SOURCE: Whirlpool 25.6 cu. ft. side by side with overflow
You have a bad water filter . Replace it by turning the knob on the lower kickplate and remove old filter . The rubber seal on the old filter has worn out causing the leaking seal to drip into the drip pan causing it to overflow .
Posted on May 23, 2010
  • 17 Answers
SOURCE: What is the cu. ft of my Whirlpool duet washing ma...
3.7 CUFT
Posted on Aug 11, 2010
rickead1
  • 1998 Answers
SOURCE: My whirlpool cabrio he 4.5
Error Code - Ld Problem - Long Drain Solution - When the machine consumes 5 minutes or more to drain out water to where the operating pressure switch resets
Posted on Sep 02, 2010
What is capacity of my whirlpool duet ggw9250pw1? I don't see the answer identified. thank you
The Whirlpool Duet ggw9250pw1 looks like it has a 7.0 cu. ft. capacity. This is based on two different sources. The first has the GGW9250PW1 in a list of parts for 7.0 cu. ft. capacity Whirlpool dryer models. See http://www.appliancepartspros.com/search.aspx?model=whirlpool%20duet%207%200%20cu%20ft%20super%20capacity%20electric%20dryer .
Similarly, the related electric dryer, GEW9250PW1, is shown as having a 7.0 cu. ft. capacity at AJMadison.com: https://www.ajmadison.com/cgi-bin/ajmadison/GEW9250PW.html .
I hope this helps.
Nov 27, 2017 | Whirlpool Dryers
Can you tell me what year and capacity/cu. ft this dryer is? Kenmore mod. 110.74642400 s/n 1505525.
Looks to me like a 7 cu ft model whirlpool type dryer with filter in the top (very dependable for over 50 years) this one is around 10 years old and is one of the best out there.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 23, 2012 | Dryers
Whirlpool dryer model #LG7681XSW2 what is the cubic ft of this dryer? 22000 BTU...serial # MAO143334
Hello, about 7 cubic feet or roughtly 1.918 feet X1.918 feetX1.918 feet equal 7.048 cu/ft. I hope this help you. GB....stewbison
Sep 22, 2011 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
Looking for cu ft for this dryer. I am having to buy a new dryer and want to make sure I do not down size. Could you please help.
Whirlpool dryers in this series are about 7 cu. ft.
Here is the user manual and it lists suggested maximum loading by articles of laundry (number of towels, sheets, etc.) on page 4 :
http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%208522243.pdf
Good luck.
Mar 02, 2011 | Whirlpool LGB6300 Gas Dryer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Sm8525079 what is the capacity of this washer and what is the capacity of the matching dryer?
Hello.
The capacity of your washer is 3.2 cu ft and the dryer is 6.0 cu ft. This is pretty much a standard for newer top load washers and dryers. You can get bigger but it is not that much bigger.
Jul 22, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool 6.5 cu ft 5 cycle is not timing and drying clothes qui
First I would check to make sure your vent is not clogged or kinked. As far as the timer, the only fix would be to replace it. Unless of course you have the feature that detects the dryness and that would put you back at the venting problem. Good luck.
Apr 17, 2009 | Whirlpool 6.5 Cu. Ft. Super Capacity Gas...
Dryers Logo
48 people viewed this question
Top Whirlpool Dryers Experts
Craig Butler
Craig Butler
Marvin
Marvin
Smitty
Level 1 Expert
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
