Question about Toshiba Televison & Video
Toshiba VHS/DVD combo. turn on power switch,the motor for VHS player running for few seconds,then stop..sometimes,can't switch from VHS mode to DVD mode,a mode switch problem or power fuse problem?
SOURCE:
  • 308 Answers
SOURCE: Hitachi DV-PF33U DVD Player / VCR Combo
It sounds like the sensor to tell the microcontroller that the tape is moving is not working. If that is so, the VCR would probably do the same thing in FF or Rewind. If you end up taking this unit into a repair shop, have them check the DVD's software version (it should be 1.250) If below that number, have them upgrade that as well. You can check the version yourself by pressing 1,2,3,4 and then "display" on the remote while the unit is on and no disc in DVD. After noting the version, just hit "power" on the remote to exit this mode.
Posted on Jan 01, 2007
SOURCE: VHS player stops
VCR is set with blank tape..Bring up vcr control on TV with television set on Chanel #3, go to menu
Follows procedure for progamming date,time start,time finish,chanel and.speed and single recording.finally click on menu and turn vcr off. Vcr lights indicate set for taping,,.Does no start to tape at requested time and lights indication taping ready stays on ??????
Posted on Nov 07, 2007
  • 4 Answers
SOURCE: VHS tape plays for a few seconds and automatically ejects
My guess would be dirt on the rollers inside the VCR. They sesnse a jam and ejct. Try a VCR cleaner (with cleaning fluid) and see if that helps.
Posted on Feb 21, 2009
SOURCE: Panasonic DVD VHS combo DMR-EZ48V will not play region 1 dvd
This is happening because your DVD is NOT all region, you need to change the Code.
en.wikipedia.org/wiki/DVD_region_code -
www.dvdexploder.com/ -
www.dvdexploder.com/multihacks.htm
www.allformp3.com/dvd-copy.../dvd-region-code- free.htm -
www.dvd.reviewer.co.uk/info/multiregion/ -
Ok check those links out they will help you sort it.
Posted on Apr 01, 2010
  • 17 Answers
SOURCE: Panasonic DMR-ES30VS DVD Recorder / VCR Combo Troubleshooting
This is actually an easy fix what you do is you take off lid the VCR cleaning everything with a Q-tip and a little alcohol all the gears accept the head with the head you use a cloth 4 eyeglass wear that's for anti reflective lenses and a little alcohol this will not scratch your head on the VCR wipe out all dust and fuzz too around the vent in back.
Then next you take.and use white grease and grease everything that has a track area being careful not to touch heads . You even do that tracks on the side of the VCR the ones that go in to the machine
Then towards the front of machine you will see two round gears lift those up slightly and check to see if white tape is in tracks if not push it slightly with a cuetip.
Then put machine back together as tape won't work with top of machine off
Plug in and hook.up IT should work now.
Good luck
Do this before you replace a ton if part
Posted on Oct 06, 2016
VHS plays for 5 to 10 seconds then power switches off
I think you might have a problem with the VHS mechanism. Perhaps damage to the mechanical parts. If the mechanism can't perform the task it has been set after a very short period it will send a message to the electronics to shut down. This prevents further damage to the tape or system.
Jun 12, 2016 | Toshiba RDXV60KB DVD HDD VHS Recorder
How do I program a RCA universal remote to my Toshiba SD-V392 vhs/dvd combo player
Turn on device , look up the code number for a Toshiba vhs/DVD combo then press setup and hold until it blinks then press device vhs/DVDs then enter code and press off button when device turns off it is programmed
Aug 29, 2015 | Toshiba Televison & Video
Hi my Toshiba DVR20 combo plays a vhs tape for 5 seconds then turns self off any advice please
Tape transport mechanism fault. Contact any service technician. Tape do not run properly. Might be the fault of some belt/s or loading wheel.
google.com/+GopakumarGopalan
Jun 29, 2015 | Toshiba DVR20KB DVD Recorder
I have a recorder that whenever i put in video cassettes stops playing after a few seconds and turns the unit off. Can anyone help. Thanks
sounds like belts and rollers and any sensors you see need to be cleaned - it sounds like the unit thinks tape is at end and is shutting down
use qtip and rubbing alcohol to clean
try using different tape just to make sure it is not just a bad tape
Mar 21, 2011 | Toshiba RD-XV49DT DVD/DivX/VHS...
The TV turns off when i put a VHS tape in the VCR. The tape will play for a few seconds, then the Power goes off. When i turn the Tv back on the tape immediately ejects.
Possibly have a tape drive motor issue it powers down to save itself .Thats the dickens with those combo sets they are hard to look at ,you have to take it half apart just to see whats going on
Feb 16, 2011 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
How can I get VHS tapes to play?
try to run a vhs cleaner thru it and it should help alot
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Jul 20, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
DVD/VCR Combo Stuck in VCR Mode
i could probably walk this one through chat at idahoredfoxusa@yahoo.com
Jun 04, 2009 | Toshiba SD-V394 DVD Player/VCR
Stuck in Progressive Scan Mode...please help!
There should be a switch on the DVD player that is makred 'progressive/interlaced.' You need to flick this switch til it says interlaced, as obviously your TV cannot view progressive signals. It may be on the back of the player, or under a flap on the front.
Feb 04, 2008 | Televison & Video
DVD/VHS Selection
turn of the power on wall, and wait 5 mins, then try again. i had same trouble with not being able to eject or play dvd, i turned off player at wall and it worked fine again.
Sep 25, 2007 | LG V181 DVD Player/VCR
Televison & Video Logo
43 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
