Question about Baby Gear
How do you collapse the play yard for storage?
How do I fold up the playpen
It's a struggle!
Pull up on the handle in the centre of the floor till it is as high as it can go.
On each of the sides there is a plastic piece in the middle. If you feel around them you can find a little button sticking out (it's on the side facing out of the playpen). Push that little button and push down on the middle of the top bar and it should collapse. There are 4 sides to the playpen - and 4 little buttons.
Nov 28, 2012 | Kids II Bright Starts Ingenuity Sleepeasy...
Chair booster seat legs won't collapse for storage
This should help. I've included a section from the user guide for Cosco's On-the-Go Fold Up Booster (41767B)
The full User Guide can be found here: http://www.coscojuvenile.com/usa/eng/DJGFiles/ProductDocuments/87_9-25-2006_124247.pdf
Jun 01, 2012 | Baby Gear
How to fold down the cosco funsport play yard.
There is usually buttons under the cover in the middle of each side? Squeeze this and the side should collapse, then usually a pull up in the middle which reduces the cot right down. Hope it helps
Apr 16, 2012 | Cosco Juvenile Cosco Funsport Playard
The sides of my Avalon play yard Ap14 will not collapse. I have lifted up the centre & pushed on the white dots but the sides will not go down. Please help!
We encountered the same problem. Our diagnosis: we **** open one compartment to see what was going on. The problem appears to be one that involves both parts and design. The plastic cams do not function symmetrically, due partly to a weak spring, and partly to design. This can allow one or both of the cams to lock in at an angle that is too stiff for the push button (a plastic lever) to overcome with mere finger pressure. we had to pry them loose with a screwdriver. This same combination of parts and design can create the opposite problem: difficulty getting the arms to lock into place. It also creates frustration trying to fold the unit up for storage as one or more arms can re-lock very easily. Solution: Returning it is probably the best option.
Dec 24, 2010 | Avalon Baby Gear
The avalon play yard will not fold- one of the short arms will only half collapse no matter what I try.
Have you tried pulling the centre up almost all the way and then releasing the side?
Oct 29, 2010 | Toys
Need instructions on folding and storing an 8 yr old pack n play?I have cleaned it and am having trouble knowing how to fold it up so it will fit in the cover for storage?
I have one that is about this old, so if it is the same one, the instructions for how to fold it should be printed on the very bottom of the play yard. If they are not, then try to pull the center part up halfway. Next, push up on each side where the arrows are and as you do this, it should start to collapse and you should be able to fold it completely by pulling the center all the way up.
Hope that helps!
Aug 29, 2009 | Graco Baby Gear
Folding up Cosco play yard
My wife and I have the same model for visits by our granddaughter. She was having the same trouble as were you and, like you, we did not have instructions.
I'm happy to share with you what I found to close the model up for storage. It may not be the same as what the manufacturer envisioned but it worked for us.
-- With the pad removed from the inside of the Pack n Play, pull up on the red handle so as to loosen the legs;
-- Next, you will find there is a big button in the middle of each of the long sides of the Pack n Play. Start with either long side. You will have to press very hard on either side of that button; I found it helpful to use both hands, one pressing on the outside of the playpen, the other hand pressing on the inside of the playpen. Pressing these together will loosen the long support arm at the open top of the Pack n Play.
-- Do the same for the opposite long side.
-- You will also do the same, one button, one side at a time, for each of the two short sides of the Pack n Play.
-- Now pull up on the red handle in the middle, and guide the four corners so they meet and close.
-- Cover.
I found the buttons may not have fully allowed the support arms to collapse, thus blocking the Pack n Play from folding down completely. If so, try pressing the button again (both the outside and the inside at the same time).
Hope this helps!
Jan 06, 2009 | Cosco Beatrix Potter Playard Crib
Stroller won't collapse for storage
I figured out how to collapse the stroller....There is a black button about 2 inches in length underneath the handle, slide that to the left and at the same time press the 3 inch yellow button on the front of the handle....the stroller collapses forward for storage.
Oct 11, 2008 | Fisher Price Baby Gear
you also need to hold one of the middle indicator tabs on the longer side..because if you don't do that it will not shut... and make sure the 2 legs go inside with the center of the play pen
Dec 03, 2007 | Cosco Beatrix Potter Playard Crib
Baby Gear Logo
29 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Marvin
Marvin
john h
Are you a Baby Gear Expert? Answer questions, earn points and help others
