Manua.lshttps://www.manua.ls > weather stations > Ascot
To install and set up the Ascot AUK-WS-32 weather station, you should begin by securely mounting the sensor unit in an elevated outdoor location, ensuring it is ...
Ascot AUPWE10 Projection Alarm clock. To change the main time and date. Push the Mode button until the temperature display is shown at the top. Then hold the mode button in until the the day function flashes down the bottom. Move to required field by pushing the mode button again. Adjust date and time displays using the arrow keys.
Was the main 30 amp fuse checked/replaced? The main fuse would on the starter relay. To locate the starter relay, follow the cable from the battery's + terminal.
to set the time: switch to timedisplay and hold the "S" key for three seconds, then adjust with the arrow key´s
to set the date: same prcedure as time but first switch to the date display
