Question about NorStar Lands Phones
Norstar phone M7310 keeps saying calling 24 later how do I remove that
SOURCE:
SOURCE: reset Norstar M7310 System Administration password
This works, i just did it today!!
Press Feature 985
Press the 9 Key
Enter RESETSMPSWD (73738767793) using the dialpad
Press YES
Once you have RESET the password, it reverts to the default.
See Below
If your system uses 2 digit extensions use 120000
If your system uses 3 digit extensions use 1020000
If your system uses 4 digit extensions use 10020000
Posted on Jul 03, 2008
SOURCE: nORSTAR m7310
To Log Into System Programming:
Press FEATURE * * 2 6 6 3 4 4
Enter Password: 2 6 6 3 4 4 Display will read: " A. Configuration"
Using the navigation keys, as displayed below, follow the next simple steps:
Press: NEXT Display will read: "B. General Admin"
Press: SHOW Display will read: "1. Sys speed dial"
Press: NEXT Display will read: "2. Names"
Press the SHOW Display will read: "Set names"
Press: SHOW Display will read: "Show set:__"
Enter the extension number of which you wish to change the name Display will read: "<##:name>"
Press the CHANGE softkey
Using the dial pad spell out the name Ex: If you need the letter K press the 5 key twice and then press # to confirm the letter. Continue until the entire first name is spelled. (note: you are limited to 7 characters)
Press: NEXT (if you fail to do this step, the name will not be saved!!!)
Press the RLS key
Hope this helps!
Posted on Jul 27, 2008
ynotphone
  • 192 Answers
SOURCE: call forwarding for NorStar m7310
You have to know how to get into programming, and it depends on the type of telephone lines you have... if you have regular analog lines, on a out bound call transfer there is going to be line degragation. Meaning that the outgoing call is not going to be of the best quality.
Secondly, you have to see how many telephone lines you have, if you have 3 analog trunks, with a call forwarding to a cell phone, you will be using up 2 lines... 1 incoming and 1 outgoing to your cell. This leaves 1 trunk for incoming or outgoing callers.
Posted on Mar 19, 2009
ynotphone
  • 192 Answers
SOURCE: how can i change my extension nuber (norstar M7310)
Sorry can you clairify this question...
-> You need a new extension number for your set?
-> You need a new extension on your set so you can see when they are on their phone?
If it is the first, there are many things that you need first, too much to explain at the moment. But you need to have the password and a template for your phone to make changes.
If it is the second, press:
- Feature * 0 and any button to find out what is on the button, look for an empty button or one that you want to overwrite,
- then RLS,
- press FEATURE * 2
- press the button where you want to add this new extension
- dial the extension of the new person
Voila you are done!
Posted on Jun 03, 2009
consultel1
  • 860 Answers
SOURCE: I have a Norstar Meridian with M7310 phones. When
sounds like your telephones not programmed for handsfree.
Programming2.gif is done on 7310, 7324 and 7316 type sets.Enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you want to change to handsfree.
Press the show key (top right arrow)
The display should say LINE ACCESS
Press the next key (bottom right arrow) .
The display should say CAPABILITIES.
Press the show key (top right arrow) .
The display say foward no answer.
press the next key 3 times (bottom right arrow)..
The display should say handsfree. Press the show key.(top right arrow) change from none to auto
Press the release key when finished
Posted on Sep 15, 2009
What module do I need to purchase to get called ID on my M7310
The Norstar 616 system was made before CLID was readily available. You could however, purchase a Nortel CICS system with CLID card(s). CI trunk cards handle up to 4 lines per card making the capacity of the system 8 lines by 16 stations.The CICS system will work with the existing m7310 sets you have so you wouldn't have to incur the cost of new telephones.
Jul 13, 2010 | NorStar Meridian M7310 Phone
I have a nortel norstar M7310 phone. we have used
Feature #85 (Note #FEATURE CODE deactivates that feature code)
Nov 17, 2009 | NorStar M7310 Corded Phone
Have Norstar M7310 5 line phone 2 lines say they
You need to unplug something, just not the phone.
The two lines are probably conferenced together. Go find the gray Nortel cabinet and pull the plug on it.
Carl
Oct 30, 2009 | NorStar Meridian M7310 Phone
Can you change the password on NORSTAR M7310? I have the restricted line (long distance phone call) and I would like to remove that restriction. Can you help me? thanks Brandon
Yes u can change the password.
Go to system programming by Fetature **266344 password will be 266344.
Keep pressing next until display shows restrictions.
press show there it will ask for COS password press show there u press 00
u will get a pasword press change as per ur requirement.
Jun 26, 2009 | NorStar M7310 Corded Phone
Norstar m7310 phone problem
Sounds like a **** button.
Unplug the phone and rake (pull your fingers across) the face of the phone...
The button that you have programmed for your accountant sounds like a good place to start looking.
Apr 25, 2009 | NorStar M7310 Phone
What is a Norstar Overlay Template?
right top Show
right bottom Next
left top Heading
left bottom Back
Mar 23, 2009 | NorStar Meridian M7310 Phone
Lands Phones Logo
18 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
Thomas F. Schneider
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
