On the computer keyboard by nextech is there suppose to be keyboard lights and if so how are they turned on
Hi
The usual lights for a keyoard are the 3 above the number pad. they will be labelled to correspond with the following keys:
- CAPS Lock
- NUMBER Lock
- SCROLL Lock
When they are pressed once the light will go on, meaning that function key is active. So if the CAPS Lock key was pressed and the light is on, then any letter key (A to Z) you press appear as a capital in documents. Press CAPS Lock again and the light goes out and the letter will type lower case.
The NUMBER LOCK is for the keypad to the right (not the number across the top and above the letters). This function ensures the numbers will appear instead of their alternate function, such cursor and Page UP/down, Home, and End.
SCROLL Lock is not used much, but it can be used in Excel to hold the current selection. For example, you want scroll about the sheet using the cursor keys, but want to keep the current cell selected. So with SROLL lock active, when you use the cursor key's, the sheet will move in the direction you want while leaving the selected cell selected. Try it and you'll see what I mean.
I hope this helps.
