Question about Kenwood Audio Players & Recorders
Trying to connect new Sanyo LED TV FW50D48F to old Kenwood AV Receiver 106VR. Kenwood receiver has no TV input only VIDEO 1, VIDEO 2, CD and TUNER. I used VIDEO 2 for DVD and it works, CD works.
  • Franco Dosil
    Franco Dosil Apr 24, 2019
    Hi Diane, the headphone output is the only output that your new TV, Sanyo LED TV FW50D48F, that you can connect to your Kenwood 106VR, if you use this output you could cancel the TV's own sound system
    Test if you can configure the headphone output in the TV menu as an audio line output
    Another option would be to use the optical fiber output of the TV and use a digital audio to analog audio converter (example STEREN)
    I hope you find my suggestion useful
    Greetings Franco Dosil
    Hola Diane, la salida de auriculares, es la unica salida que tiene tu nuevo televisor, Sanyo LED TV FW50D48F, que puedes conectar con tu Kenwood 106VR, si usas esta salida podrias anular el sistema de sonido propio del televisor
    Prueba si puedes configurar en el menu del televisor, la salida de auriculares, como salida de linea de audio
    Otra opcion seria usar la salida de fibra optica del televisor y utilizar un conversor de audio digital a audio analogico (ejemplo STEREN)
    Espero te resulte util mi sugerencia
    Saludos Franco Dosil
  • Franco Dosil
    https://www.steren.com.mx/convertidor-de...
    Master:
  • 665 Answers
Here's the Manual:
https://www.hifiengine.com/manual_library/kenwood/106vr.shtml
Trying to connect new Sanyo LED TV FW50D48F to old - 4_24_2019_6_38_57_am.jpg4_24_2019_Trying to connect new Sanyo LED TV FW50D48F to old - 4_24_2019_6_38_58_am.jpg_mi4_24_2019_6_38_58_am.jpg
Posted on Apr 24, 2019
    Top Expert:
  • Kenwood Master
  • 51,879 Answers
The VIDEO inputs are the TV inputs.
SOURCE:
  • 192 Answers
SOURCE: Component Video inputs do not work
I started back in the day of tubes. A family would have one set and it would be a 19" black and white. There are different resolutions now. The components probably do work, but, they don't pass the 480i signal. The satelite converter's analog signal needs to be set to 480p and the DVD needs to be set to progressive if it does have that setting. If the DVD is not a progressive scan DVD, then, the only inputs that it will show on is the analog signal. Some of the dish converters have a switch on the face for changing the resolution. If yours doesn't then put it in an analog source and go to the menu and change it there. Then move it to the component input. Hope this helps.
Posted on Jun 24, 2007
SOURCE: Can't get all speakers to turn on in AV-1 function
can't seem to get the sound to come on. i knowe i have sound but will not turn on
Posted on Mar 10, 2008
PyroPCMan
  • 405 Answers
SOURCE: Connecting to Dish Network receiver/tuner
Yes!
Posted on Jun 27, 2008
SOURCE: Kenwood KA-72B Stereo Receiver HELP NEEDED.
Why not plug the cassette directly into the CD recorder? Are they trying to achieve some eqalization change? If not, then this should work. It's all analog at tape level.
Posted on Sep 04, 2008
laseramp
  • 314 Answers
SOURCE: Why is my LED TV blurry using coxial cable input
HDMI, Component Cables are recommended for hifg definition viewing. coax has many strands of copper wire with a sheathing around it of aluminum foil. at a distance of a few feet it can easily be a bad crimped connection. but the wires with a bad ground will always cause issues.
you see, coax cables are good for standard broadcasting and normal tv sets,for a quality connectyion they havre specialhmdi cables thjat use bandwiths to send colorts along eatchother like rg and b they will easily transmit clear and stable images. coax uses F-type connectors and are prone to many problems.
but in the spirit of A DIY option. getting a cable line amplifier might just clear up the blurriness by injecting a signal boost in the line. good luck.
here is my suggestion for you a 50 dollar quick fix plug and play.
http://www.amazon.com/Motorola-Signal-Booster-BDA-S4-Amplifier/dp/B000WPGRKK/ref=pd_cp_e_1
Posted on Feb 18, 2010
I have a new Yamaha AV receiver rx-v381,trying to connect an old CD DVD player, Sony dvp-nc665p. I have audio, no video. No HDMI on CD DVD player. What am I doing wrong? Help!
On my Yamaha AV receiver, DVD video (usually a yellow connector) passes through to a video output which then connects to the video input of the TV.
Feb 11, 2017 | Sony Audio Players & Recorders
How to hookup kenwood system w/receiver,cd/dvd etc HELP?
basic setup is simple
connect the kenwood an test it out with speakers
then get some cables to connect it to your tv
you need a cable or 2 , rca phono connectors likely
from the receiver video an audio out to the tv audio video in
you might have 2 sets on each
2 outs an 2 ins
it wont matta which you choose
turn the tv to aux or video input 1 or 2
May 03, 2015 | Televison & Video
My 27" Sanyo DS27800 when
U using the RCA AV cable Y,R,W plug into those tv video input holes wright?Tries another RCA Y,R,W AV cable,see if it work?U have tools like a soldering iron,a roll of solders,also can u do basic soldering?Tries take some alchahol clean the Yellow input hole and take the tv aparts resolders it connections joints,now the video out it should work again,if not yellow input hole might be shorted require replacing.
Jan 27, 2011 | Sanyo DS27800 27" TV
I have a Kenwood 106vr receiver. almost right after the warranty expired whenever I'd crank some power through it it would switch off with only the stand by light flashing. i put the receiver in storage...
It sounds like you blew it up. Ten years of sitting didn't heal it.
Does it come up with NO speakers attached? If not, it's cooked. Sorry.
If it does come up you need to isolate the short being presented by the speaker(s).
For the future, I'd take it easy on the volume and take a hint from its reactions. An audio device only has so many self-protecting emergency shut down cycles in it.
http://www.retrevo.com/support/Kenwood-106VR-Receivers-manual/id/478bh948/t/2/
Jan 06, 2011 | Kenwood 106VR Receiver
How to hook up a kenwood audio-video surround receiver vr-405 to a 46" Bravia tv?
hello all you need is a good pair of RCA cables.
Use the audio output on the TV
run it to the VIDEO 1 input on the receiver
as for your DVD player vcr etc you can either run them directly to the tv as it will output whatever sound is playing to the receiver.
or
use the receiver as a video switcher and connect your components directly to it.
remember your receiver will need to be set to the input you use. ie: video 1 / dvd etc..
Hope that helps
Jan 10, 2010 | Kenwood VR-405 Receiver
Trying to hook my Wii up using the AV audio Jacks
Connect the Wii to your television. Then connect the variable audio output from the TV to the audio in on the monitor section of the receiver. Then use the TV/SAT input selection on the receiver and dolby prologic 2 as your sound mode.
Dec 23, 2009 | Sony STR-DE575 Receiver
Kenwood vr-405 receiver
I have the 405 as well. My TV has an optical out and I run that straight to the 405 optical input. I set the input selector to DVD/CD (not DVD)and presto! TV audio out my speakers. It all comes down to the audio connections on your TV.
Mar 23, 2009 | Kenwood VR-405 Receiver
Havin problem utilizing multiple inputs into Sanyo TV (avg-3259g)
if your tv has no AV IN AND OUT connections, purchase a converter from eletronic shops just around your area.
this will make you convert AV into RF signal and feed that to your tv. you have to go on a channel and search for right frequency the will search for you.
Dec 31, 2008 | Sanyo DS13204 TV
Mar 02, 2008 | Audio Players & Recorders
No HDMI Output
My configuration:
ZONE 1 (living room)
DishNetwork Dual Tuner DVR Tuner 1 [S-Video out] -> [S-Video in] ONKYO TX-SR875 [HDMI out] -> [HDMI in] Sony KDS-60A3000 rear projection TV
ZONE 2 (living room)
DishNetwork Dual Tuner DVR Tuner 2 [Composite Video out] -> [Composite Video in] ONKYO TX-SR875 [Composite Video out] -> [Composite Video in] Samsung AQUOS LCD TV
Problem:
ONKYO receiver stops sending video signal to my ZONE 1 Sony TV through the HDMI connection. ZONE 2 may still receive video. (NOTE: the issue might be related to the upconverter circuitry?)
Symptom:
I couldn't see any video, but I could hear the Tuner 1 audio through my ONKYO. An important clue is that I couldn't see ONKYO's on-screen display menu on my TV when hitting the [Setup] button on my remote. But, I could see my TV's Sony-based menus and display options.
Solution:
1. Put all ZONES in Standby mode using the remote. Hit these buttons on remote: [Receiver], then [Standby]. [Receiver], [ZONE2], then [Standby], [Receiver], [ZONE3], then [Standby]. You should NOT see any lights on the ONKYO except maybe one red led near the power button.
2. Pull the power plug out of the back of the ONKYO, and leave unplugged for 20-30 seconds. Turning off any power center it is connected to isn't enough. You MUST unplug the power from the back of the ONKYO for 20-30 seconds.
3. Reconnect the power cord to the ONKYO.
4. Using the remote, set ZONE1 to a video source known to be working. If you don't see video, try leaving the power cord off for a longer period.
I know it sounds too simple to work, but that's what brought the video back for me the few times the video stopped displaying. Hope it works for you.
Jan 06, 2008 | Onkyo TX-SR875 Receiver
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
rigger094
Mike Duncan
Mike Duncan
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
