Question about Kenwood Car Audio & Video
My kenwood KAC-728S is wired properly but it wont power up and I took the back off and nothing looks or smells burnt
    Master:
  • 665 Answers
Probably blown one or both of the 20 amp fuses.
http://manual.kenwood.com/files/B64-1360-00&ved=2ahUKEwj6tJye3ObhAhUkNX0KHSe2C38QFjACegQIBxAC&usg=AOvVaw0RxfGcmdfo50hnTme7xwB0
My kenwood KAC-728S is wired properly but it wont  - 4_23_2019_5_24_12_pm.jpeg
Posted on Apr 23, 2019
SOURCE:
  • 631 Answers
SOURCE: kenwood KAC-PS201T
The first thing you must do is to confirm that you have voltage at the amp. Just because the fuses look good, that doesn't mean you're getting power to the amp.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Posted on Jan 22, 2008
SOURCE: WIRING MANUAL
tough ****
Posted on Mar 31, 2008
  • 79 Answers
SOURCE: Kenwood KAC-7202 wont turn on
I have found the problem to my Kenwood KAC-7202. The amps fan was the only thing that would come on thats it. So I started checkin zener diodes cause all transistors checked out fine. So I remember readinf about a guy that had same problem and took it to a shop and they said it was some diodes. Well, thats what I was thinkin or the transformer. It turned out that 1 zener diode was no good, diode D9 1ss133. I took a zener out of an old vcr I use for parts and put it in and the fan came on as usual then the red light. Then I hooked my mp3 player to the rca input and hooked up some speakers and it works great. Hope this helps you other guys with the same problem. Check your zener diodes with a digital volt meter, if you get any measurement other than the reverse impedance which will read between 600 and 1200 ohms some lower or higher and then reverse the leads on your meter and if you get any reading it's no good and the reading will be 0-50 cause mine read 047 ohms.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/mark_b53a7494531bf96d
Posted on Feb 09, 2009
etirbynnor
  • 655 Answers
SOURCE: Kenwood Excelon KAC-X811D blinking e-03
Hello mogly20,
The amp probably won't know if it's you or the homeless guy, so try smashing a glass bottle on it like he did. If that doesn't work, I'd recommend you locate another homeless guy and buy another amp.
Hope this helps.
Posted on Aug 09, 2009
  • 9 Answers
SOURCE: KAC-8070 kenwood 4-channel power amp
Audio section
Max Power Output (4 ohms, 1kHz)
Rear 70W + 70W
Front 35W + 35W
Max Power Output (4 ohms, 1kHz, 10% THD)
Rear 45W + 45W
Front 25W + 25W
Max Power Output (4 ohms, 1kHz, 1& THD)
Rear 37W + 37W
Front 20W + 20W
Frequency Response (-3dB)
Rear 2 Hz ~ 100 kHz
Front 5 Hz ~ 50 kHz
Posted on Jun 24, 2010
Where is the ground connection on a kenwwod kac 728s
if u lay it down where u can read it right to left it would be on the left hand side. the ground would be in the middle of the three connection points
Jan 04, 2012 | Kenwood KAC-728S Car Audio Amplifier
My amp blew the 20 amp fuses. Replaced and they blew as soon as the radio kicked in. Took the back off to look for any burnt connections or blown open/expanded capacitors or resistors. It smells like...
Remove all the wires from the amp including the remote turn on wire. Once you do that, after about 30 seconds the amp will reset. Hook the power up first, then the ground then the remote. Turn the unit on and check for power WITHOUT the speakers hooked up. If you get no power by now it's a good chance that the amp is cooked. If you do get power, try hoking up your speakers first on one channel then the other channel and then bridged. If it cuts out or off when you touch the speaker wires to one channel or the other, then that channel is no good. Hope this helps.
Mar 17, 2011 | Kenwood KAC-728S Car Audio Amplifier
I have a kenwood kac-728s and two coustic 10in. subwoofers hooked to it and every time i start my car and the radio powers on the two 20 watt fuses on the amp blows.any ideas?
That is pretty much saying that the amp's power supply is shorted or at least has a low resistance path to ground which is causing the fuses on the amp to blow. The amp has protection circuitry to prevent damage to the output stage so that is not what is causing this. Is the amp new?
Dec 30, 2009 | Kenwood KAC-728S Car Audio Amplifier
Amp lights up, but no power to outputs.
channels mey be burned....does the amp smell like burnt electronics
Nov 07, 2009 | Kenwood KAC-8104D Car Audio Amplifier
Wont turn on
Deppends where it arc too, short at the case
just pops a fuse . short in side could need
new output trans ,they are screwed
to the heat sink , check output trans , and
all fuses.
Jul 05, 2009 | Kenwood KAC-728S Car Audio Amplifier
Power lite on, no sound from amp after 1hr of usage
HI DUDE UR REMOTE WIRE FUSE IS BURNT .... REPLACE IT ... AND UR SPEAKER ... OR SUB TAKES LOT POWER FROM AMP .... ....
Apr 17, 2009 | Kenwood KAC-428S Car Audio Amplifier
Kenwood KAC-8103D Power Amplifier wont turn on
it sounds to me like its burnt.but with some amps the screws that hold it in place have to be screwed into the car chassisfor grounding. be careful not to srewe into hidden wires.
Apr 14, 2009 | Kenwood Car Audio & Video
KAC-9152D random shut off
Hello, The problem your having is in the power supply section. If you want it repaired I will repair it for you. I own my own business. I install car audio/video systems in cars, trucks,etc. I also do amplifire repair. I am the cheapest repair business you will find. If your interested send me an e-mail at skinnman33@gmail.com if you have'nt allready had it fixed. I'll repair it for $40 you pay shipping. I have a website if you wanna check out but it's not even close to being finished. I got rid of my old page and server and I'm just trying different backgrounds and layouts. I'm just upgrading everything cause we are moving to a bigger facility. Again let me know. Good luck
Apr 05, 2009 | Kenwood KAC-9152D Car Audio Amplifier
KAC-X520 kenwood 1000w amp
a red light indicates you got no power check your wiring you may not have a good ground, you need the green light to come on
Oct 09, 2008 | Kenwood KAC-X520 Car Audio Amplifier
My amp powers on but no sound output..
My Clarion is doing the exact same thing...and im starting to lean towards a failure in the powersupply of the unit...it just cant produce the sound.
Aug 20, 2006 | Kenwood KAC-728S Car Audio Amplifier
Car Audio & Video Logo
35 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
