Question about Ricoh Office Equipment & Supplies
How i reset ricoh mp c2050 error code 573 - Ricoh Office Equipment & Supplies
    Habit-Forming:
    New Friend:
  • 17 Answers
U need to replace PS unit or BC unit, one of them is defective
Posted on May 15, 2019
SOURCE:
SOURCE: Ricoh Aficio MP C1500SP - functional error SC202
call ricoh serviceman he/she can fix it.
Defective tank full sensor
• Tank full lever bent or broken
• Incorrect ink suction
1. Check the harness of the tank full sensor.
2. Replace the GJ engine.
3. Replace the maintenance unit.
• The position of the tank full lever
does not stay at the tank full position
after ink initialization or air releasing.
• The position of the tank full lever is
not detected at ink suction.
Posted on Jun 23, 2008
SOURCE: Error code sc 552 on Ricoh CL7100
To clear any code on a Ricoh / Savin copier that will no reset by turning the power off / on you need to first enter the service program mode. This is a safety feature installed when repeated resets of some codes could cause damage to the machine or possible fire hazard. Most of the time these codes deal with the fusing unit. The fusing units operate at around 180 degrees celcius. Thats pretty near the point where paper catches fire so you see the need for safety there. Anyway, you can sometimes get a false fuser code if the room is cold in the morning when you first power up the copier and the machine takes longer than normal to reach operating temp. Another reason can be that maybe you didn't push the fuser back in good enough after clearing a jam and the electrical contacts did not make good contact. In these instances you can clear the code and go back to copying. Should the code come back after doing one of these resets then it means there is a bigger problem with your fuser and you need to call for a service visit to have the problem fixed.
Here is the reset for it:
1. Press the Clear Modes (yellow on most machines)
2. Press the numbers 1,0,7
3. Press and hold the Clear / Stop (red on most machines)
after a few seconds on machines with an LCD display screen you should see the screen change to display "SP mode" with a few selections. On older or smaller machines without an LDC display screen you should see a flashing "0" on the panel. This lets the machine know its ok to reset the code. Do not make any selections in this mode. SP mode if for making electrical adjustments to the copier and taking the machine out of spec can cause a lot of problems for you. Once you enter the SP mode you just need to turn the machine off / on. (make sure you do so with the main switch that you have to rock back and forth and not the button that just gets pressed to shut down the machine, the main rocker switch is often located on the front door or on the left side of the machine, sometimes covered by a swinging cover you have to lift first)
If you do not hit the keys in the right order, the machine will not go into SP mode. You can just start over with step one untill you get into SP mode.
After doing this and the code resets but then comes back again or gives you another code, you'll have to place that service call. If not then happy copying to you.
Posted on Jan 14, 2009
  • 163 Answers
SOURCE: Error code SC 548 on Ricoh Aficio 1022 copier. Need to reset m/c
sc 548- service call - fusing unit not set properly
the fusing unit connector may be loose.
u can reset the error by entering the service mode (careful -do not change anything )
to enter the service mode press [all clear](yellow button) ,[1],[0],[7],[clear](orange button)and keep the button pressed for about 5 sec.
go in copier options , then mode 5, then option 810
and execute(or 1 & ok)
(careful -do not change anything else)
Posted on Jan 16, 2010
  • 904 Answers
SOURCE: Ricoh MP C2500 Error Code SC 561 what is this?
sc561 on an MP C2500 is a thermopile error. The thermopile may need to be replaced, but first make sure it is connected properly and hasn't been moved or loosened.
You'll need to go into service mode and execute SP 5810 in order to clear the sc561 code.
Posted on Jul 04, 2010
  • 422 Answers
SOURCE: Problem with the Ricoh mp c2800 Ricoh error code
If the model ia a MPC 2800 it a controller board issue maybe the operation panel. -carl
Posted on Nov 15, 2010
What is error code sc565?
If you wish to get some details; check the site linked here. Pull up older posts......
http://electro-medical.blogspot.com/
Jun 25, 2016 | Ricoh Compatible 4 Color Set Aficio MP...
How to fix colour position in ricoh c2050
tthe machine can do autocalibrattion,
see the video
Oct 05, 2015 | Ricoh Compatible 4 Color Set Aficio MP...
Ricoh mp 1600 error 194 ricoh mp 1600 error code 194 how do I solve the problem
Having problems finding your error code. Here is a complete list of all codes for your printer: http://www.printcopy.info/?l=en&mod=free&chap=erc&brand=Ricoh&model=Aficio%20MP1600
I do find the error code for a different Ricoh model (Aficio 1018).
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Ricoh&model=Aficio%201018
Please verify your model number and error code.
Apr 21, 2015 | Ricoh Aficio Mp-1600 Copier
How to reset login name and password for ricoh 2075
The default is admin and no password.
If this has been changed you can reset the admin pass by logging in as supervisor and no password.
This form might help if you are still having trouble from there.
How do reset the administrator password on the Ricoh Aficio MP C2050
Jun 04, 2014 | Office Equipment & Supplies
I have an error on my gestetner mp c2030 with code sc222, please help me.
Problem with the yellow laser unit. Probably need a tech for that one.
May 20, 2014 | Ricoh Compatible 4 Color Set Aficio MP...
2030 sc573 code
IT TELLS YOU THE TERMISTOR HAD TO BE REPLACED & LATER YOU TO HAD TO RESET THE MACHINE
Sep 14, 2013 | Ricoh Compatible 4 Color Set Aficio MP...
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
