Question about GPX DV7500 System
Freezing My GPX DV7500 plays fine for about 30 minutes a then starts freezingmomentarily every minute or so and sometimes stays frozen for a coupleof minutes at a time.
  • 883 Answers
Sounds like a bad solder joint that is GPX heats up, the crack starts to get bigger and cutting off electric circuit, then cool down closes the gap and current resumes. First try breaking and then making all possible connections outside then inside unit. Then, if no success, remove the circuit board and clean it with alcohol and brush then carefully look at each solder joint with a magnifying glass. If one found, simply re-solder it.
Posted on Nov 27, 2007
1999 gmc savanna 3500 van, reprogram ignigtion key
place the key in the ignition and turn on.leave on for ten minutes.once ten minutes is up security light will either flash or go out.then turn off and then on again.repeat 3 times.this is a 30 minute relearn.remember just turn the key to run not start.good luck
Dec 14, 2011 | GMC Vehicle Parts & Accessories
DVD images freeze at certain points or playback becomes choppy
sounds like you will need to clean laser, there are cleaners you can buy out of walmart for this. Don't know if they work well, I take mine apart and use soft cloth and alcohol then letting dry, works fine for me.
Dec 16, 2007 | Sony DAV-FR10W System
Only two speakers work when a CD is being played...either MP3 or regular CD's. Why are the other speakers and subwoofer not playing sounds. Model DV7500
You mean a GPX DV7500? I can't find the manual. Do YOU have it? Do all the speakers work during setup or on real multichannel sources?
If you're using analog inputs and NOT selecting any of the DSP modes you will hear just stereo.
May 20, 2011 | Audio Players & Recorders
Predators blu ray disc wont play have the latest fimware update tried 2 disks now what???????
First, some long winded history and this may not be exactly the same problem you're having but I have an Oppo BDP-83 and I tried 2 different Predators blu-ray discs from, both of which would NOT play the actual movie. I could play the previews and get to the main menu but could not play the movie itself or jump to a scene select, etc. Any option that was selected would completely freeze the player at a black screen and I'd have to hold the power button down for a few seconds to reboot it. I tried it on the most recent Oppo firmware dated May 5th, 2010 AND the beta firmware date August 24th, 2010. Nothing. I read that some people had luck turning BD-Live OFF or disconnecting the player itself entirely from the network or by just waiting it out 5-10 minutes to see if it'd start....nothing worked. I disconnected the ethernet cable, let it stay at that frozen black screen for 30 minutes while I made dinner, fed the kid, etc. The thing that seemed to finally get the 2nd disc to play (1st disc I returned for an exchange via Amazon) was to select the BD Live Extras at the main menu, and download all of the extra previews, etc. After that, the movie played just fine. It could have been a fluke, but hell, I tried everything else and this was the only thing that didn't completely freeze up my player.
Oct 23, 2010 | Sony Playstation 3 (PS3) Console
Instruction manuel needed for GPX dv7500 system please
You can get a user manual from
Just send them a search request.
Feb 18, 2009 | GPX DV7500 System
Mitsubishi WT-42313 42 in. rear projection tv
I guess I have to pay money for a solution, which is not what this website says. The only answer I got was pay money and we'll tell you. Is that true/
Sep 16, 2008 | Mitsubishi WT-42313 42" Rear Projection...
Dvd stops after about 10 minutes
it is possible the laser inside is dirt and needs cleaning....but I assume you have done that?
Jun 04, 2007 | Zenith DVD5201 Multi-disc DVD Player
Dvd problem
I have Panosonic DVD-Recorder that gets balky sometimes. It works fine if I reset it by unplugging it from the wall and letting it "rest" for a minute or more. I do not know if this applies to a player.
Apr 24, 2007 | GPX PDL705
Progressive Scan Mode Resetting
Hi, Open the CD and press return on the remote to reset it back to Interlace mode. Thanks Annarr
Jan 14, 2006 | GPX DV7500 System
GPX DV7500 System Logo
73 people viewed this question
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
