Question about Sony Audio Players & Recorders
Rumble noise has developed denon 5 cd player changer
Model dcm-230; now static rumble noise from both channels; put in cleaning disc but did not solve problem; noise not from amplifier as sony cd player when plugged in sound is quite clean. so not the amplifier. also this player does not detect some cd's i wanted to play.
  • Sony Master
  • 448 Answers
Hello Rob, ask, the model of your Denon, is DCM-230 or DCM320?, since I do not locate the 230 manual
From what you describe, I would try to replace the interconnected RCA-RCA cable and if it persists, you may have either a false contact on your Denon's RCA output connectors or a problem with a low-signal power supply
On the other hand you comment that it does not read some CD, it is possible that you have the laser reader low, for which it may require an adjustment or the replacement of the same, or need a more effective cleaning, than the one that makes the CD cleaner, I mean to clean the lens of the reader with a lightly moistened isop with alcohol, preferably Isopropyl Alcohol
I hope my comment has served you
Greetings Franco Dosil
Hola Rob, pregunta, el modelo de tu Denon, es DCM-230 o DCM320?, ya que no ubico el manual del 230
Por lo que describes, probaria reemplazar el cable RCA-RCA de interconexion y si persiste, posiblemente tengas o un falso contacto en los conectores RCA de salida de tu Denon o algun problema en fuente de alimentacion de baja se?al
Por otro lado comentas que no lee algunos CD, es posible que tengas el lector laser bajo, para lo cual pueda requerir de un ajuste o el reemplazo del mismo, o necesite una limpieza mas efectiva, que la que hace el CD limpiador, me refiero a limpiar la lente del lector con un isopo levemente humedecido con alcohol, preferentemente Alcohol Isopropilico
Espero te haya servido mi comentario
Saludos Franco Dosil
Posted on Apr 24, 2019
SOURCE:
  • 184 Answers
SOURCE: DCXR463GA2WW Squeak
YOU MOST LIKELY HAVE A REAR DRUM BEARING FAILING. IT IS A SMALL TEFLON BEARING THAT SLIPS ON OVER THE REAR SHAFT OF THE DRUM AND INTO THE HOLE IN THE REAR OF THE DRYER. THERE ARE ALSO FRONT GLIDES THAT SUPPORT THE FRONT OF THE DRYER. OLDER DRYERS HAVE THE FRONT SUPPORTS UNDER THE DRUM SO THE DRUM RESTS ON THEM. NEWER G.E. DRYERS HAVE A PLASTIC RING WITH THREE TEFLON GLIDES ON TOP OF THEM AND THE DRUM HANGS FROM THESE GLIDES. REPLACE ALL OR SOME OF THE ABOVE PARTS TO ELIMINATE YOUR SQUEAK.
ON OTHER POSSIBILITY, THE IDLER PULLEY THAT KEEPS TENSION ON THE BELT CAN BECOME A SQUEAK MAKER.
Posted on Apr 08, 2008
  • 85 Answers
SOURCE: Denon DCM 370 5 disc changer does not show all discs!
Probably drive belt that rotates the carosel inside is not lining up properly,or the belt that moves the laser mech into position,sounds like its just not lining up properly
Posted on Jan 08, 2009
petraman7
  • 1175 Answers
SOURCE: nad cd player cd541i noise
Hi...
That one is going to need Tech service.
I've worked on several of the NAD players.
Sounds like a focus or gain adjust needed.
Posted on Mar 19, 2009
  • 61 Answers
SOURCE: our sony hcd-hpz9 stereo will
this is done by a belt drive. i have seen the belts get old and slip. try to gently pull the door open as you hit eject. If you get it to open and find that it will not fully open or close without assistance this is the problem.
Posted on Apr 03, 2009
SOURCE: cd changer is jammed in denon dcm 360 5 cd changer
Simply remove the outer casing and remove the jammed disc
Posted on Oct 26, 2009
How do you get to the lens for cleaning
There is special disk for sale for cleaning lenses. Otherwise you will have to take apart your changer to clean lenses. If you have some experience and tools - you'll be fine.
Aug 19, 2011 | Denon DCM-280 5-Disc CD Changer
Where is the mp3 plug in for a denon DCM-280
Register and download the manual for free at retrevo.com
http://www.retrevo.com/s/Denon-DCM-280-CD-Players-review-manual/id/363ci871/t/1-2/
It's capable of playing MP3's right out of the box. See page 18.
Feb 21, 2011 | Denon DCM-280 5-Disc CD Changer
My DCM-360 has stopped playing discs after my moving house. It spins the carousel, picks up the disc and then puts it down without spinning the disc up. Laser problem or disc-spinning-motor problem or...
Had a similar problem with my Denon. When I inserted CD it takes it in but immediately stops - like it doesnt sense the CD. Same problem with Single or Multi changer. Removed cover, removed reader ( 4 screws) and found lens had fallen out. Cleaned, reinstalled with touch of super glue on rim - works fine.
Oct 12, 2010 | Denon DCM-360 5-Disc CD Changer
Denon DCM-280. Tray won't open, there are CDs in
If you don't wanna send it for service, open the chassis of the player and free the CDs from the tray. Its highly likely that the CDs came off the trays and got stuck inside.
Jul 31, 2009 | Denon DCM-280 5-Disc CD Changer
Increasing static and complete sound loss
hello you mean buzzing,humming cause is a high missing broken ground and it needs service by electronic shop............make shure is not missing any wire that must be connected or undervlotage working............saludos
Jan 08, 2009 | Denon DCM-280 5-Disc CD Changer
Jan 04, 2009 | Denon DCM-370 5-Disc CD Changer
Cd changer is jammed in denon dcm 360 5 cd changer
Nov 28, 2008 | Denon DCM-360 5-Disc CD Changer
21 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
