Question about Bosch Televison & Video
Bosch 300 series power light illuminates ,but machine will not start when start button is engaged.
Model number is wfmc2201 uc/15
SOURCE:
  • 6 Answers
SOURCE: Bosch DLX series didn't drain, now no power
I had a Bosch DLX series dishwasher that had multiple problems.
First, it had greyish water in the bottom and pushing the power button did not turn on any lights. it had mostly finished a cycle, but not quite. my first thought was to clean it out. i sponged out all the water and removed and cleaned out the filters from the bottom which were all quite nasty. i found food, tiny bones, etc. I cleaned it out and that did nothing but was still probably the cause of the problem. I called Bosch tech support and asked about areset switch. There is none. They told me to switch off the circuit breaker for 30 MINUTES to reset everything. I did that which did not fix the problem.
I then examined the connector wires (connecting the electric to my house wiring) which are in the front under the kick plate, and discovered that they had MELTED! The wiring supplied by Bosch was stranded wire, and my home wiring is solid core. i trimmed the burnt stuff and reconnected it with new wire nuts. if this happens again i plan to disassemble the dishwasher's electric and replace the stranded wire with the good stuff.
That restored the electric and the lights and display. i then ran a test cycle and it seemed to just hum. my guess after googling a bit was that the float was stuck in the up position, and it was trying to drain. This site http://www.applianceaid.com/boschDW.html told me how to run the test mode.
"To start test program, press and hold both POWER SCRUB PLUS and REGULAR WASH program buttons, then turn unit on by pressing ON/OFF button. When program buttons are released, lights above them will flash. To end test program, press ON/OFF button."
The test mode tested out all functions which I think wound up reseting the float switch which actually fixed the rest of it.
Posted on Dec 27, 2008
  • 3 Answers
SOURCE: stand by light flashes red on powering up with remote and the green light flashes approx 15 or times before the screen illuminates.
thats pretty normal, it takes a good second or two to warm up and the display to turn on(at least0, you get the green flashes as you hold for on, 1 sec is a long time at times, lol, be patient, no problem with your tv!
Posted on Jun 06, 2009
  • 228 Answers
SOURCE: Hello! My Bosch Nexxt series 300 washing machine
e 13 is a door lock error if you are lucky you may have a manual release check where filter is for a red pull release this mechanically activates the door to retrieve trapped washing,if not lock will need replacing engineer visit unfortunately.
Posted on Aug 05, 2009
  • 10 Answers
SOURCE: My brand new Bosch is not draining and is showing E:13 error code
Put the washer on cold and run "TWO" cycles. There is too much soap or fabric softner.
Posted on Nov 27, 2009
richroth
  • 9472 Answers
SOURCE: Have a BOSCH 300/500 series washing machine.
The door locking mechanism has malfunctioned and/or is overheating. It is recommended that remove power from the appliance (unplug it) for 30 minutes and try again. If the problem persist, you will need to replace the door lock assembly.
Posted on Nov 26, 2010
How do I turn the child lock off on Bosch series 8
Which model do you have? On the front-loading washing machine, WAW28790IN and the WAW24440IN, press and hold the Ready in +/- button for 3+ seconds to toggle the child lock on and off. For the WAW28460AU, press and hold the Finished In +/- button for the 3+ seconds. On all of these models, this button is below the LCD panel on the right hand side. The directions for engaging the child lock are on the button or just below it in a much smaller font than the primary feature of the button.
I found most of the serie 8 ovens have a dedicated button for the control panel lock. On the HRG6769S6B, press and hold the button with the key icon (the middle button to the left of the start/stop button) for 4+ seconds to toggle the child lock on and off. For the HBG672BS1B, this button is the lower button to the right of the start/stop button. Again press and hold for 4+ seconds.
I hope this helps. Please add a comment with the model number if you need more information about the control panel/child lock for your specific appliance.
Jul 18, 2018 | Bosch Washing Machines
I have a Bosch washing manchine nexxt 300 series, when i push the on button it will not come on
Check door switch. If OK then your probably looking at a motor control board problem. Ck connections on it. It is located in the back right corner of the machine.To get to it take the back off and it will be on the bottom left.
Mar 04, 2013 | Bosch Nexxt 300 Series WFMC2201UC
Can I turn off the beeping on my BOSCH 24" Bar Handle Dishwasher 300 Series
for most bosch model, made sure unit power off before you begin the adjustment procedure step 1 on unit control panel there three button under the cancel reset label.press and hold the right cancel reset button.step2 press and hold the on/off button step3 release both button after the light illuminating the cancel reset button turn on an tone stops
Dec 21, 2017 | Bosch Home Appliances Dishwashers
Is there a reset button on a bosch 300 series washing machine
turn off the power to the unit for 45 min, that resets it
Dec 05, 2012 | Bosch Nexxt 300 Series WFMC2201UC
How do I replace glass bowl on a Bosch wfmc2201 clothes washer?
Hello, welcome to FixYa.
I'll start by saying your post indicates it is a Bosch Nexxt 300 washer wfmc2201 that you would like to "replace glass bowl".
I don't know what research you've done to bring you to the place you are now, but hopefully I'm not the first to tell you. If you are referring to either the glass inside the door or the plexi-glass outside the door, that comes as all one component.
The Bosch part # 249080 is available at several retail locations online such as "repairclinic.com" "searspartsdirect.com" to name a couple.
Unfortunately this has always been the case with Bosch/Siemens built full size laundry products when it comes to the door components (at least in the time I've been working on them, 15+ years)
Let me know if I can provide help in any other manner and I'll be glad to assist you going forward in any way I can.
Regards,
Macmarkus :)
Jun 30, 2011 | Bosch Nexxt 300 Series WFMC2201UC
Bosch 300 series washer// led code E04
Remove the access panel at the front botton right corner. There is a manual release button you can pull.
Oct 27, 2008 | Bosch Nexxt 300 Series WFMC2201UC
BOSCH WFMC2100/UC WASHING MACHINE
It tend up to be the control panel on the unit
Dec 02, 2007 | Bosch Nexxt 300 Series WFMC2201UC
Televison & Video Logo
Top Bosch Televison & Video Experts
Paul Unsworth
Level 1 Expert
Bill Boyd
Are you a Bosch Televison and Video Expert? Answer questions, earn points and help others
