Question about LG Refrigerators
LG french door glide and serve hinge flap stuck
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 5 Answers
If yours is the same as mine, the hood (what I believe you are calling the "flap") is not meant to open. It is there so you can see what's in the drawer, but it doesn't lift up, even with the trays above out of the way.
Posted on Apr 29, 2019
SOURCE:
SOURCE: maytag french door refridgerator
replace main control board on the bottom left in back near the compressor
Posted on May 22, 2008
  • 161 Answers
SOURCE: flap doesn't open to allow ice to drop in glass.
Your fridge is under warranty call 1-800-243-0000 option 7 for customer service.
Posted on Jan 24, 2010
  • 50 Answers
SOURCE: lg french door ice cubes
if the ice cubes get stuck together its usually because the ice maker water solinoid is letting too much water in. could have a bade water valve.
Posted on Aug 04, 2010
  • 35 Answers
SOURCE: top hinge for lg frig.
You can go to appliancepartspro and put in you model # and it will bring up a scematic of your fridge. (I could only find model # lfx25960st so you might check the # again) looks like there is several pieces to the hinge assembly.Hope this helps if so give us a 4 thumbs up.THANKS
Posted on Mar 04, 2011
thehardwa922
  • 6 Answers
SOURCE: left hand door not closing easily anymore. lubricate the hinge?
It could be the fridge is tilting forward.
Up turn the two front screw beside the door to make the fridge tilt backwards, or lower down the two back screw to allow the fridge to tilt backwards.
Then the door will automatically close by the weight of the door itself!
Posted on Jan 24, 2015
Water will not stop flowing in to icemaker
Dirt in body of icemaker water supply valve. OR. Ice maker timer stuck when it selected "add water to icemaker.
The first solution is simple, change icemaker water filter and disassimble valve to clean.
The second is simple, buy a new icemaker.
May 15, 2012 | LG LFC25760ST 25 Cu. Ft. Panorama French...
The ice from the ice maker tastes and smells funny.
Look for your Ice maker replcement cartridge at the bottom of your french doors...
Sep 17, 2011 | LG LFC25760ST 25 Cu. Ft. Panorama French...
I have an LG LFC25760ST that the door alarm continues to beep even after the door is closed. I do not have the fancy control panel with an on/off button, I only have a temperature control. Any help would...
You have a bad door switch at the top hinge cover. More than likely, a wire has come loose. Can't tell which one since there are 2 of them. You will need to disconnect the wires and check with a ohm meter.
Good luck.
Jul 24, 2011 | LG LFC25760ST 25 Cu. Ft. Panorama French...
How do I remove the lights in the refrigerator section of my LG LFC25760ST? Why would the lights not go off, even with the door closed?
this is not really a solution, but good information. this past Just a class action suit was filed against LG for knowing about the light bulb problem and continuing to sell the fridge.
Oct 15, 2010 | LG LFC25760ST 25 Cu. Ft. Panorama French...
LG french doors, bottom freezer. Water leak from
Make sure your ic maker is empty. On the bottom of the ice maker is a small button. Watch the plastic fill tube and hold the botton in. Let the ice maker cycle anmd see if the water over shhoots rne ice maker. If it does, trim 1/8 of an inch off of the tube with a raxor knife on an angle = / this should take care of your problem.
Jan 14, 2010 | LG LFC25760SB 25 Cu. Ft. Panorama French...
The upper compartment lights will not turn of when you close the doors.
this means your door switch is sticking...most likely needs replacing..
Nov 11, 2009 | LG LFC25760ST 25 Cu. Ft. Panorama French...
Refrigerators Logo
37 people viewed this question
Top LG Refrigerators Experts
Steve Allison
Steve Allison
deecee73
Level 1 Expert
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
